View Full Version : Zbar removal!
blinky1911
04-03-2005, 05:20 PM
Is there an easy way to remove the zbar? I need to pull the zbar out in order to get my drivers side header out.
nancejd
04-03-2005, 05:23 PM
If you are pulling the engine anyways, just start pulling it out, the z-bar just pops out.
Rick Dorion
04-04-2005, 04:44 AM
I can just get to the nut on the frame bracket from the engine compartment; then undo the linkage and it pulls out. It was easier when I had the oil filter off.
dennis68
04-04-2005, 06:17 AM
I back off the lock down on the frame bracket, and disconnect the linkage from the pedal then pull the zbar and lower linkage together.
blinky1911
04-04-2005, 07:28 AM
Thanks guys I will give this a try tonight.
