View Full Version : TH400 speedo gear for bigger rims?
g356gear
09-11-2009, 07:07 AM
I have switched to 18" rims and a 35 series tires and was curious for opinions on what tooth number gear I should switch out to for my speedometer to be more accurate because it seems to be waaay off. I am running 3.37's and a Turbo 400.
Jake's Performance
09-11-2009, 12:34 PM
What is your actual tire size. I need a complete tire size or the actual diameter and I can figure what speedo gears you need.
g356gear
09-11-2009, 02:48 PM
25.58" overall tire diameter with 3.37 rear gears
Jake's Performance
09-14-2009, 01:01 PM
You need a 15/40 combo.
The 40 tooth is no longer available from the dealer.
So you could go with the 15/39 or 15/41 15/39 is slightly closer.
g356gear
09-15-2009, 06:19 AM
Is this a fairly easy swap out? I have never really had to change speedo gears before. Usually on e-bay they just have single gears, how do I find a combo?
Jake's Performance
09-15-2009, 03:31 PM
Yes,
It's pretty easy to swap. You may be able to save yourself some hassle by looking at the existing drive gear on the output shaft. If it is plastic it is colored and from the color we can tell the tooth count.
We also need to know which sleeve you have, the housing that holds the driven gear.
There are two different sleeves, one for up to 39 teeth and another for 40-up.
Those are somewhat expensive. The gears are relatively cheap.
You also would want new seals, etc while you are there.
g356gear
09-17-2009, 06:41 AM
Anyone have a service manual PDf on how to do the swap?
