View Full Version : PB Blaster, Liquid Wrench, WD-40
BA.
09-08-2009, 04:52 PM
I was wrestling with rusted bolts tonight and I was curious if any of these is really better than the other for rusted/frozen bolts.
b-man
09-08-2009, 05:07 PM
Of the 3 you listed, PB Blaster.
Other = better: Kroil
http://www.kanolabs.com/google/
novaderrik
09-08-2009, 06:04 PM
GM heat valve penetrant, also sold under the "Liquid Wrench" brand. not the regular Liquid Wrench, but the "foamy" Liquid Wrench or something like that.
Yoda4561
09-08-2009, 06:18 PM
PB has always worked best for me, an overnight soak with PB, a few light taps with a hammer, and I haven't had a bolt (well that wasn't already stripped to oblivion) that I couldn't remove.
shmoov69
09-08-2009, 07:26 PM
PB and heat and a hammer.
Or a drill and tap after it breaks! Lol!
LateNight72
09-08-2009, 07:30 PM
LPS KB 88
Best stuff on the market.
MuscleRodz
09-08-2009, 08:08 PM
Kroil is the best imo, but a little harder to come by
shep
09-08-2009, 08:34 PM
I forgot about Kroil and voted PB. I think Kroil works better.
wellis77
09-08-2009, 08:39 PM
Kroil is my fav as well. I think I got it at Eastwood???
406 Q-ship
09-08-2009, 10:17 PM
The GM Heat Valve Lube works great but when I got a free sample of PB Blaster.......damn that will loosen bolt on the Andra Doria with an overnight soak.
Pro Stock
09-08-2009, 10:27 PM
A good propane torch and lots of heat
Dale
BonzoHansen
09-09-2009, 06:29 AM
Kroil or PBB. WD40 is not a good penetrant.
moreHP
09-09-2009, 07:14 AM
I use the Kroil too. And it smells good! LOL!
Eric Howell
09-09-2009, 10:12 AM
Nuts off
http://www.phelpsweb.com/phel9_6a.htm
Also like Kroil.
BA.
09-09-2009, 11:24 AM
Alright! Looks like I've learned a thing or two today!!
Thanks for voting!
9deuce9rr
09-09-2009, 11:30 AM
agreed!
Diesel
09-09-2009, 06:20 PM
PB Blaster ,I heard that 50/50 ATF and acetone is better than commercial stuff, anyone try it?
MonzaRacer
09-10-2009, 03:20 AM
I wouldnt use pbblaster to start a fire, rippoff.
If it takes allnight to soak in.
Cyclo Break Away
Kano Aero-kroil
Sea Foam Deep Creep
K&W Knocker Loose
The gm heat valve lube is from Chevron, just like port fuel injector cleaner is Techron.
My favorite stop gap to sprays is heat a pure synthetic motor oil.
Oh nad if you have WD40 on certain military bases, your fired.
Way down on my list way way way down are liquid wrench products.
dadto2jays
09-10-2009, 06:19 AM
When I was doing the frame off on my 71c10 I used pb blaster and it worked great and whatever could not break loose used a torch and it came off...
Brandon Miller
09-11-2009, 05:43 AM
Dad used to have some old stuff called Knock 'Er Loose. That stuff was the bomb.
sniper
09-13-2009, 02:19 PM
A friend of mine turned me onto Kroil. Haven't used any other product since. I get it from a local HVAC warehouse.
