View Full Version : OFFICIAL: wheel/tire picture thread... show em off!
mikeith
09-02-2009, 07:15 AM
Ok so i think this CAN have the potential to turn into a sticky worthy thread. there are alot of threads asking will this look good on this etc. so this is a chance to both show off what you have aswell as inform others of what they can do to thiers.
things you need to post if you can:
- wheel size front/rear
- tire size front/rear
- make/model of tire
- make/model of wheel
- offset or backspacing
with that being said lets see what you got! :cheers:
xxxturbo6
09-02-2009, 09:43 AM
I guess I will start this off!
These wheel & Tire sizes will fit onto a stock suspension G-body Buick regal without modifications and rubbing issues!
I made this a little easier to copy and paste so everyone can just add there measurements.
CAR: 1986 Buick Turbo regal- T-Type
1). Wheel size:
FRONT: 18" X 9.5"
REAR: 18" X 10"
Back spacing:
FRONT: 4.75"
REAR: 4.75"
2). Tire size:
FRONT: 255 / 35 ZR18
REAR: 285 / 40 ZR18
3). Make/Model of tire: TOTYO / Proxes T1R
4). Make/model of wheel: CCW / Classic's
https://www.pro-touring.com/forum/attachment.php?attachmentid=32230&d=1251495646
https://www.pro-touring.com/forum/attachment.php?attachmentid=32232&d=1251495878
mikeith
09-02-2009, 10:30 AM
thanks thats a perfect example
first gen fan
09-02-2009, 10:48 AM
18x12 w 345 tires in rear and 17x8 w 255 45 in front.
NOGO
09-02-2009, 12:14 PM
I like xxturbos format so I copied it.:idea:
CAR: 1967 Chevrolet Chevy II Nova. I have a stock front clip with zero offset disc brakes, and my rear axle is narrowed 1" from stock.
1). Wheel size:
FRONT: 17" X 7"
REAR: 17" X 8"
Back spacing:
FRONT: 4.25"
REAR: 4.625"
2). Tire size:
FRONT: 215-45-17
REAR: 245-45-17
3). Make/Model of tire: Dunlop Direzza Z1 Star Spec
4). Make/model of wheel: Vintage Wheel Works V48
https://static1.pt-content.com/images/pt/2009/09/3764959200_b576bc5dae_b-1.jpg
street3285
09-02-2009, 12:46 PM
CAR: 1970 Chevrolet Chevy Nova. Chassis Works subframe with Baer Track Kit. Rear G-bar with rearend shortened to 55" axle flange to axle flange. Mini-Tubbed.
1). Wheel size:
FRONT: 19" X 8"
REAR: 20" X 10"
Back spacing:
FRONT: 5.0"
REAR: 6.0"
2). Tire size:
FRONT: 245-35-19
REAR: 305-35-20
3). Make/Model of tire: Nitto 555 Front - Nitto 555R Rear
4). Make/model of wheel: Rushforth Fuels, Smoked Titanium Center
NOT A TA
09-02-2009, 05:40 PM
CAR: 1970 Pontiac Firebird
1). Wheel size:
FRONT: 17" X 9.5"
REAR: 17" X 11"
Back spacing:
FRONT: 5.5"
REAR: 5.75"
2). Tire size:
FRONT: 275 40 17
REAR: 315 35 17
3). Make/Model of tire: Yokohama AO32 soon to be replaced with different DOT R tires
4). Make/model of wheel: American Racing Torque Thrust II with Rad Capz TA center caps www.radcapz.com (http://www.radcapz.com)
https://static1.pt-content.com/images/pt/2009/07/WheelNutzonThe14Carshoot1021-1.jpg
https://static1.pt-content.com/images/pt/2009/08/Firebird0052-1.jpg
formula
09-02-2009, 06:06 PM
Ok, finally had the chance to get much better pictures...
CAR: 1978 Pontiac Firebird Formula
1). Wheel size:
FRONT: 19x8"
REAR: 19x11.5"
Back spacing:
FRONT: ???
REAR: ???
2). Tire size:
FRONT: ??? / ?? ZR19
REAR: 325 / 30 ZR19
3). Make/Model of tire: ???
4). Make/model of wheel: Forgeline TA3
Boesch
09-03-2009, 06:59 AM
Intro 3 Piece - C6 corvette 19 front and 20 back
https://static1.pt-content.com/images/pt/2008/09/Boesch_Corvette_2-1.jpg
https://static1.pt-content.com/images/pt/2008/09/Boesch_Corvette_1-1.jpg
https://static1.pt-content.com/images/pt/2008/09/IMG_1329-1.jpg
daredvl22
09-03-2009, 07:53 AM
First gen fan - can you provide more details on what you did to make that rear set up work? (IE) Mini tub obviously..DSE??? I really like the stance and overall look. What about back spacing, etc. Sweet ride!
RYU
i'll be able to contribute to this in about 2 weeks (hopefully sooner not later!)
I'd like to add though another parameter for BBKs. I'm finding myself searching for BBK friendly rims which are just more concave on the spokes normally or have the wheel face further out.
Big Brake Kit (BBK) = Yes or No?
If yes, which one = ??
My $0.02
EDIT:
66 Malibu Chevelle, Roja Formula 7 in silver with polished lip. (These wheels are almost 10yrs old)
18x8 +0mm offset (after 1.5" spacer to clear bbk)
19x10 +8mm offset (after 1.75" spacer to clear bbk)
Big Brake Kit = C6 Z06
https://static1.pt-content.com/images/pt/2009/09/P1040914-1.jpg
https://static1.pt-content.com/images/pt/2009/09/P1040916-1.jpg
https://static1.pt-content.com/images/pt/2009/09/P1040933-1.jpg
Finch
71 Camaro, Rushforth Livewire with Smoked Titanium Centers
18X12 rear with 335 KDWs 5 1/2 BS
18X10 front with 295 KDWs 6 3/8 BS
Sorry, Teaser pic only for now.....
https://www.pro-touring.com/forum/attachment.php?attachmentid=32343&stc=1&d=1251992889
The WidowMaker
09-03-2009, 07:46 PM
finch, did you get the two piece widened (18x12), or did you go three piece?
Tim
b-man
09-03-2009, 08:35 PM
'64 Pontiac Tempest
Not at final ride height yet. Still under construction, will update pics later.
-18X9" front and rear
-245/40-18 front - 275/40-18 rear
-General Exclaim UHP tires
-O.Z. Racing Ultraleggera (cast aluminum, weight = 20.8#)
-40mm offset = 6.57" backspacing
- Using 27mm (1.063") thick adapters up front to correct backspacing and convert bolt pattern to 5 on 120mm, new Moser axles drilled for 5 on 120mm in the rear.
-No rolled or trimmed wheel well lips.
https://static1.pt-content.com/images/pt/2009/07/DSC02904-1.jpg
https://static1.pt-content.com/images/pt/2009/07/DSC02905-1.jpg
https://static1.pt-content.com/images/pt/2009/08/DSC02955-1.jpg
https://static1.pt-content.com/images/pt/2008/11/oz_ultraleggera_mblk_ci3_l-1.jpg
RYU
09-03-2009, 09:29 PM
Nice setup! I'm going a similar route. Got any pics of how the front C6Z06 fits on an 18" wheel?
'64 Pontiac Tempest
Blitz
09-03-2009, 10:08 PM
Finch and B-man.
Did you guys run into any problems with fitment of the wheels over the Z06 brakes?
a73formula
09-03-2009, 10:20 PM
1). Wheel size:
FRONT: 17" X 9.5"
REAR: 17" X 11"
Back spacing:
FRONT: 5.5"
REAR: 6.75"
2). Tire size:
FRONT: 275 40 17
REAR: 315 35 17
You car is so sweet. I had 17x8.5 fron and the 17x11 on mine
a73formula
09-03-2009, 10:21 PM
1). Wheel size:
FRONT: 17" X 9.5"
REAR: 17" X 11"
Back spacing:
FRONT: 5.5"
REAR: 6.75"
2). Tire size:
FRONT: 275 40 17
REAR: 315 35 17
Awesom car(that posted better, sorry)
b-man
09-04-2009, 03:35 PM
Finch and B-man.
Did you guys run into any problems with fitment of the wheels over the Z06 brakes? My 18" O.Z wheels swallow up the Z06 brakes like they're nothing, tons of room between the spokes and the calipers. Not every 18" wheel design will fit over them, but mine were a slam-dunk.
Pic of the backside showing how the spoke shape curves outward and away from the calipers:
https://static1.pt-content.com/images/pt/2009/09/DSC02946-1.jpg
Up front the adapter moves the wheel out by a little more than one inch providing more caliper clearance, but even without the adapter they would easily clear the calipers.
Before buying my Z06 brakes I printed out the templates provided on the KORE3 website to check for adequate clearance.
Here's a pic with no calipers in place taken during the front suspension install (SPC control arms-ATS spindles), that's the best I can do for right now until the braking system is completed.
https://static1.pt-content.com/images/pt/2009/08/DSC02950-1.jpg
minendrews68
09-04-2009, 05:30 PM
1). Wheel size:
FRONT: 17" X 7"
REAR: 17" X 8"
Back spacing:
FRONT: 4.25"
REAR: 4.625"
2). Tire size:
FRONT: 215-45-17
REAR: 245-45-17
3). Make/Model of tire: Dumlop Direzza ZI Star Spec
Really nice looking nova...
Carl
Yelcamino
09-04-2009, 06:20 PM
This is going to be a :cool: thread!
Here are my two. They both have aftermarket suspension components mounted in stock locations. They both have the rear outer fender lips trimmed and rolled with no other mods.
1966 Chevy El Camino
Intro Pentia wheels
Front – 18 x 8 (4.75” back space)
Rear – 18 x 10 (5.5” back space)
Nitto NT555 tires
Front – 245/40-18
Rear – 295/45-18
1966 Chevy Chevelle
Forgeline SP3P wheels
Front – 18 x 8.5 (5.2” back space)
Rear – 19 x 10 (5.5” back space)
BFGoodrich KDW tires
Front – 255/40-18
Rear – 295/35-19
parsonsj
09-04-2009, 06:57 PM
One of my all time favorite pictures of my car. John Ulaszek shot it.
265/35/18 Pirelli P-Zero Corsa on Kinesis K18
mell69
09-04-2009, 06:59 PM
Herb you have without a doubt the most badazz 66 Chevelle I have ever seen. I like it more and more every time I see a picture of it. Simply awesome.
Mike Bahr
GregInAtl
09-04-2009, 07:52 PM
As seen in other posts here;
Heres the set up on my GN;
F- Boss 338- 20x8.5 w/ 5.25 BS and 7/16 wheel spacer, 245/35-20
R- Boss 338- 20x10 w/ 6.25 BS and 1" adapter, 275/30-20
firewood
09-04-2009, 08:01 PM
Here's one from my main hangout, impalassforum.com. I friggin love this car.
https://static1.pt-content.com/images/pt/2009/09/DSC00523-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSC00487-1.jpg
22x11 with 15mm OS in the rear and the fronts are a 9" at 20 mm. Toyo proxes 4 265/30/22 and 305/25/22 in the rear.
More of a slow touring kinda thing...
dmc69
09-04-2009, 09:01 PM
that is a bad azz imp.
JRouche
09-04-2009, 10:44 PM
Ok, Ill contribute, only a rear shot, Im working on the front now :) JR
62 Nova.
Rear- 285/40/17 on BS 10" wheels 5.75" BS
Front- 235/45/17 on 8" wheels 4.75" BS
Wheels are Billet Specialties SLC62
Tires are Goodyears.
https://static1.pt-content.com/images/pt/2009/05/h-3.jpg
https://static1.pt-content.com/images/pt/2009/04/wheels1-1.jpg
Living room shot when they came home. Yea, gotta bring the new tires and wheels in the house :) And my wife and I have been together long enough that it almost didnt even phase her when she came home and saw a set of wheels in the living room LOL Thats when you know you are married and not still in the dating phase :) Oh, not to mention I rested them up against her wall (yea, she is inside, I get the outside which includes all the garage) and wall painting. Ooops!
https://static1.pt-content.com/images/pt/2009/07/wheels-1.jpg
GRNOVA
09-05-2009, 07:52 AM
Cool thread,
Here is my 1965 Nova.
Wheels are Rushforth RATED X
Wheel size Rear 20 x 12 w 6.5" bs
Front 18 x 8 w 4.5" bs
Tires Michelin Pilot Sport
Rear 335 30 ZR20
Front 225 35 R18
BWV
09-05-2009, 10:09 AM
Did you have to put mini tubs in for that tire in the back?
TERMN8OR
09-05-2009, 11:16 AM
Forgeline SP3P
19s in rear and 18s in front
https://static1.pt-content.com/images/pt/2009/09/DSC_0112-1.jpg
thedodgeboys
09-05-2009, 12:25 PM
CAR: 1970 Dodge Challenger
Make/model of wheel: Billet Specialties SLG23
1). Wheel size:
FRONT: 18" X 9"
REAR: 18" X 11"
Back spacing:
FRONT: 4.75"
REAR: 5.5"
Make/Model of tire: Nitto 5552).
Tire size: Tall Wide
FRONT: 235/35zr18 25 10
REAR: 285/40zr18 27 11.5
https://static1.pt-content.com/images/pt/2009/09/DSC_0012-1.jpg
https://static1.pt-content.com/images/pt/2009/09/100_0738-1.jpg
https://static1.pt-content.com/images/pt/2009/09/100_0708-1.jpg
GregInAtl
09-05-2009, 12:34 PM
Firewood, amazing, everyone else's are awesome too. Epic thread.
impalatpi66
09-05-2009, 03:29 PM
b-man
09-05-2009, 03:49 PM
.....utilizing a set of custom-built and painted 17X8" steel wheels.
I had these wheels built and painted back this way in 1999 so the 17" low-profile tires and wheels would look like a set of 14" rims with redline tires mounted on them until you took a closer look.
I went with the same size tire all around so I could rotate them, plus at the time I didn't want a look that was 'over the top' for my 'sleeper' daily driver.
- 17X8" wheel size front & rear
- 235/45-17 tire size front & rear
- Steel GM factory 15" wheel centers welded into 17X8" hoops
- Zero offset = 4.5" backspacing
https://static1.pt-content.com/images/pt/2008/10/DSC008461-1.jpg
https://static1.pt-content.com/images/pt/2008/12/DSC02393-1.jpg
https://static1.pt-content.com/images/pt/2008/10/DSC008391-1.jpg
https://static1.pt-content.com/images/pt/2008/10/DSC008421-1.jpg
https://static1.pt-content.com/images/pt/2008/11/DSC008451-1.jpg
Yelcamino
09-05-2009, 06:13 PM
Mike Bahr
Thanks Mike! I appreciate it! :twothumbs
Yelcamino
09-05-2009, 06:15 PM
Definately a cool pic of a really cool Chevy II!
akrapovic
09-06-2009, 12:03 PM
Wheel make:
Intro G Cubes (lathe+tig=modified caps)
Wheel size:
18x8 (4 3/4")
18x10 (6") (mini tubbed/4 link type suspension)
Tires:
BF Goodrich G-Force KDW
235/40/18
295/35/18
https://static1.pt-content.com/images/pt/2009/09/DSC01401-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSC01423-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSC01424-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSC01425-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSC01427-1.jpg
MikeNSX
09-07-2009, 06:35 AM
My '70 Chevelle with Bonspeed Huntington wheels.
17x8 front (4 3/4 backspace) and 17x10 rear (5 5/8 backspace). Tires are 245/45-17 front and 275/40-17 rear.
https://static1.pt-content.com/images/pt/2009/09/IMG_0254-1.jpg
dandsgcuda
09-07-2009, 10:17 AM
Here is my set up on my 71 cuda
Rocket racing Boost hypersilver
Front 17x7 215 55 17
Rear 17x8 255 50 17
kuhmo ASX
first gen fan
09-08-2009, 05:53 AM
I minitubbed the rear by making new frame rails which were moved in 4" from stock and they go up 4" higher in the car so I can tuck them. I have room for 16" of tire whenever they make them. We sprayed a reflex truck bedliner on when the metalwork was done because I plan on driving this car all over when it is done. The top pic gives you an idea of how much room we gained as the outer wheelwell was not cut out yet.
https://static1.pt-content.com/images/pt/2009/09/DSCF2267-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSCF2370-1.jpg
Tony_SS
09-08-2009, 06:13 AM
CAR: 1979 Monte Carlo
1). Wheel size:
FRONT: 17" X 8"
REAR: 17" X 9.5
Back spacing:
FRONT: 3.5"
REAR: 4.5"
2). Tire size:
FRONT: 245 / 45 / 17
REAR: 285 / 40 / 17
4). Make/model of wheel: Centerline Retro
https://www.pro-touring.com/forum/vbpgimage.php?do=full&p=3670
DJ Red Barron
09-10-2009, 05:39 AM
I guess I will start this off!...
Good job starting this thread off with a bang, Scot. :cool: As I've said on the other boards, your car looks soooo bad ass with that setup.
Here's my info:
CAR: 1986 Buick Grand National
Wheel size:
FRONT: 18" X 8" (+ 1.25" Spacers)
REAR: 18" X 10"
Back spacing:
FRONT: 4.50"
REAR: 4.75"
Tire size:
FRONT: 245 / 40 ZR18
REAR: 285 / 35 ZR18
Make/Model of tire: Nitto NT555
Make/model of wheel: Boze Forged Mesh
Brakes: Stock (For now)
Aftermarket Spindles: Stock (For now)
https://static1.pt-content.com/images/pt/2009/09/09-1.jpg
https://static1.pt-content.com/images/pt/2009/09/02-1.jpg
https://static1.pt-content.com/images/pt/2009/09/03-1.jpg
https://static1.pt-content.com/images/pt/2009/09/04-1.jpg
Oh yea... 1st post from a new guy here. I was told about this place by xxxturbo6. I see a few other familiar faces here so far, too. :smoke:
Bryce
09-10-2009, 06:10 AM
CAR: 1965 ford falcon
1). Wheel size:
FRONT: 16" X 7.5"
REAR: 16" X 7.5"
Back spacing:
FRONT: 4"
REAR: 4"
2). Tire size:
FRONT: 245 / 50 R16
REAR: 245 / 50 R16
3). Make/Model of tire: sumitomo
4). Make/model of wheel: stock 95 mustang, powdercoated black, im running a half inch spacer on each wheel with 3" long studs.
5). Suspension Modifications: stock spindles with my own custom double a-arm front suspension. rear is stock springs with a 9" housing.
daredvl22
09-10-2009, 08:12 AM
That would explain it! Nice work. I'm doing a DSE mini tub, so I guess I'll stick with the measly 315's .....lol.
shizzy
09-10-2009, 11:04 AM
what size tires are you running?
tones2SS
09-10-2009, 02:53 PM
Nice vehicles DJ RED BARON!!!
Welcome to the site as well. I have a question for you. How do you like the JEEP SRT 8? I like'em, but never got to test drive one, just looked at them on the dealer lot. Thanks!
brandonc707
09-10-2009, 05:47 PM
CAR: 1967 Camaro RS
1). Wheel size:
FRONT: 18" X 8"
REAR: 18" X 9"
Back spacing:
FRONT: 4.875"
REAR: 5.25"
2). Tire size:
FRONT: 245 / 40 /ZR18
REAR: 275 / 40 /ZR18
3). Make/Model of tire: Nitto /nt555
4). Make/model of wheel: Billet specialties /Apex
https://static1.pt-content.com/images/noimg.gif (http://img33.imageshack.us/i/sananselmo09009.jpg/)
https://static1.pt-content.com/images/noimg.gif (http://img31.imageshack.us/i/sananselmo09001.jpg/)
https://static1.pt-content.com/images/noimg.gif (http://img197.imageshack.us/i/sananselmo09007.jpg/)
https://static1.pt-content.com/images/noimg.gif (http://img182.imageshack.us/i/camaro3.jpg/)
1-CLN-SS
09-10-2009, 05:59 PM
86 Grand National
19x8.5 and 19x10
245/35 and 305/30
Falken FK452
HRE 895R
https://static1.pt-content.com/images/pt/2009/09/Newstance0211-1.jpg
https://static1.pt-content.com/images/pt/2009/07/Newstance017-1.jpg
96 Impala SS
22x9 and 22x11
265/30 and 315/25
Pirelli PZero Nero
Asanti AF116
MikeNSX
09-10-2009, 06:24 PM
Front 245/45-17
Rear 275/40-17
DJ Red Barron
09-11-2009, 03:05 AM
Thanks a lot tones! :)
I absolutely love the Jeep. It's been my daily driver for a little over two years and next to the GN, it's the most fun vehicle I've had. Go drive one. It will hook ya!
DJ Red Barron
09-11-2009, 03:07 AM
86 Grand National
19x8.5 and 19x10
245/35 and 305/30
Falken FK452
HRE 895R
96 Impala SS
22x9 and 22x11
265/30 and 315/25
Pirelli PZero Nero
Asanti AF116
I saw your GN on the TurboBuick board. Looks great. And the SS is very bad ass!
1-CLN-SS
09-11-2009, 05:35 AM
Thanks Barron,just trying to keep up with you and others on the TR board.
tones2SS
09-11-2009, 09:27 AM
Thanks DJ! They both look like fun rides. Thanks for the info.
Do you know if they are continuing the Jeep SRT 8 production into 2010? Thanks again.
buickfunnycar.com
09-11-2009, 09:47 AM
Rushforth Superspokes w/smoked titanium powdercoat and exposed hardware.Stock GM spindles.
Fronts:
18x8 (4.875" b/s)
245/40 Nitto N555's
Rears:
18x10 (5.625" b/s)
275/40 Nitto N555's
https://static1.pt-content.com/images/pt/2008/07/DSC05657-1.jpg
money shot,lol:
buickfunnycar.com
09-11-2009, 09:56 AM
Bonspeed Huntington's w/flat grey powdercoat.Stock GM spindles.
Fronts:
18x9 (5.5" b/s)
275/35 Nitto N555's
Rears:
18x10 (5.75" b/s)
305/35 Nitto N555R drag radials
https://static1.pt-content.com/images/pt/2008/12/DSC05986-1.jpg
Fordman
09-11-2009, 10:41 AM
CAR: 1968 Mustang fastback
1). Wheel size:
FRONT: 17" X 8"
REAR: 17" X 8"
Back spacing:
FRONT: 4.75"
REAR: 4.75"
2). Tire size:
FRONT: 255 / 45 /ZR17
REAR: 285 / 40 /ZR17
3). Make/Model of tire: Pirelli/P-zero assimetrico
4). Make/model of wheel: American racing/Torque Trust II
https://static1.pt-content.com/images/pt/2009/09/DSC05651-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSC01070-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSC01066-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSC01062-1.jpg
Fordman
DJ Red Barron
09-11-2009, 11:44 AM
Thanks Barron,just trying to keep up with you and other on the TR board.
You're doing a fine job, sir. :cool:
Glad to help out. If you have any specific questions, feel free to ask away. I drive mine a lot (43k miles in 2 years), so I can probably give a decent answer to anything you might be looking to know.
From everything that I have read thus far, yes, 2010 production will continue. In fact, dealers can start ordering '10 model SRTs now.
Rumor has is the '11 model will not exist while SRT gets everything ready for the newly designed Grand Cherokee in 2012. Rumors are also indicating a 6.4L 500+- HP HEMI. If that last part comes to be, I WILL be trading up. :6gears:
Blitz
09-11-2009, 04:46 PM
That might be the best car Ford ever made!
tones2SS
09-12-2009, 08:08 AM
John, your cars are always so cool to look at.
Awesome collection.:1st:
buickfunnycar.com
09-12-2009, 09:41 AM
Thanks man...:twothumbs
BIGX69
09-12-2009, 11:15 AM
SUNOCO TWIST:machine:BOZE HI OCTANE 18X12 335 18X8.5 245
mikeith
09-22-2009, 07:33 PM
anyone running the following?
18x9 with a 245/35-18 on front
18x11 with a 295/30-18 on back
prine68
09-23-2009, 05:00 AM
CAR: 1968 Chevrolet Camaro. I have a Hotchkis lowering kit which lowered it 2 in. front and 1.5 in. in the rear.
1). Wheel size:
FRONT: 17" X 8"
REAR: 17" X 9.5"
Back spacing:
FRONT: 4.75"
REAR: 5.5"
2). Tire size:
FRONT: 235-45-17
REAR: 275-45-17
3). Make/Model of tire: Nitto NT555
4). Make/model of wheel: Vintage Wheel Works V40
CarlC
09-23-2009, 06:48 AM
Car: 1968 Camaro. Stock fenderwells and tubs.
Wheels: Vintage Wheel Works V45
Wheel Size: 17" x 9.5" x 5.75" BS on all corners.
Tires: Kumho Ecsta XS 285-40-17 on all corners. 275 would be an easier fit.
tranny
09-23-2009, 11:47 AM
69 camaro convertible
frt-budnik 18x10, 6.125" back space, 275/35R18 pirelli
rear-budnik 18x12, 5.5" back space, 335/30ZR18 pirelli
I have not finished the car, but the fronts look to be really tight. We shall see when the time comes
T-CHRGD
09-24-2009, 03:16 PM
CAR: 1987 Buick Regal Turbo-T
1). Wheel size:
FRONT: 17" X 8"
REAR: 17" X 10"
Back spacing:
FRONT: 4.5"
REAR: 4.75"
2). Tire size:
FRONT: 245 / 45 R17
REAR: 275 / 40 R17
GOODYEAR F1 GS/D3
BOZE PRO TOURING
Gunmetal center
Polished lip
Custom engraved center cap
GEN_X
09-25-2009, 06:54 AM
First off these are not my cars. I made these for reference only. I am currently working on putting some more together. I will post them later.
GEN_X
09-25-2009, 12:56 PM
Here are 2 more
goob8869
09-25-2009, 06:03 PM
1967 Camaro
Boze Tach
Front: 19x8 4.75 bs Nitto 245/35/19
Rear: 19x10 4.5 BS Nitto 285/35/19
REAR SUSPENSION
rear end shortened for the 4.5 BS
Prodigy Bar with QA1 coil overs
FRONT SUSPENSION
Tubular a arms
QA1 coil overs
IT IS NOT TUBBED BY THE WAY
Hemidart1
09-25-2009, 09:03 PM
1967 Charger
Front:
245/45/17
Eagle Alloy 17x7
Rear:
255/55/17
Eagle Alloy 17x8
first gen fan
09-25-2009, 10:05 PM
custom 4link w room for 16" tires. 345 35 18 in rear and 255 40 17 in front on bonspeed wheels. Super clean stock looking minitub in rear.
https://static1.pt-content.com/images/pt/2009/09/DSCF2861-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSCF2741-1.jpg
SpinOne
09-26-2009, 04:08 PM
19x8 Front
20x10 Rear
245/35/19 Front
275/35/20 Rear
Nitto 555
Rushforth Rated X
Brushed Center/Polished Lip
5.00" BS Front
5.75" BS Rear
This is my first post but I have been on here as a guest for a while reading posts and learning.
Big thanks to Jon at Driverzinc for hooking up the wheels.
I want to go lower in the front I just gotta figure out what to do with my headers. They are about 3" off the ground right now...
https://static1.pt-content.com/images/pt/2009/09/Elco1-1.jpg
https://static1.pt-content.com/images/pt/2009/09/Elco2-1.jpg
https://static1.pt-content.com/images/pt/2009/09/Elco3-1.jpg
muthstryker
09-26-2009, 04:28 PM
good god... that elky IS BADAS$! HOLY SHIET!
Blitz
09-27-2009, 08:32 AM
That is a nice El.
41565 chevelle
09-27-2009, 08:57 AM
Got to go with the shorty headers!!! Looks sweet!
USAZR1
09-27-2009, 01:24 PM
Man,that is a beautiful El Camino! Makes me want to build another one,soon.
My suggestion on headers would be the Sanderson intermediates. They really tuck in tight and just about eliminate ground clearance concerns. I've run them on lowered El Caminos,both sbc & bbc,with excellent results.
firewood
09-27-2009, 08:11 PM
I personally feel than everyone that owns a Gm B-body should also own a G-body. They are natural stablemates. In particular, these two pictured represent the highest form production took each chassis to. My goal is to have a G-body wagon to go with my B-body wagon.
Someday.
uneek1976
10-28-2009, 03:22 AM
17x8 front and rear
245\45\17 front
275\40\17 rear
goodyear gatorbacks
eagle alloys 212
4.5" backspacing front and rear
Belltech spindles stock springs
Belltech rear springs
Morgan
10-28-2009, 09:07 AM
17x8 fronts w/ 235/45s
17x11 rears w/ 315/35s
Rims are Amercian Racing Torque Thrust IIs that have been painted
Tires are Yokohama AVS Sports that have had the sidewalls smoothed and redlines vulcanized on.
buickfunnycar.com
10-28-2009, 09:32 AM
Them are waay cool Morgan,dig the whole look!:1st:
usa-69z
10-28-2009, 01:44 PM
My 69 combo ( wheels now sold !) looking for new ones now ,ideas welcome !
18 x 10 - 5.75 b/s 275/40 nitto
18 x 8 - 4.75 b/s 245/40 nitto
KWC FORGED (INTRO)
https://static1.pt-content.com/images/pt/2009/10/MYCAMARO24THOCT09011-1.jpg
Scatpack
10-28-2009, 06:50 PM
KWC FORGED (INTRO)
Never seen these wheels before, but they're going on the short (growing) list. Beauty!!
gearheads78
10-28-2009, 08:48 PM
Intro V-rods paint detail by me
18 x 9 with 6.5" backspace using Pontiac hubs and C6 brakes
18 x 10 with 6.625" backspace with 72 Cutlass rear
255-40-18 Toyo T1R
285-40-18 Toyo T1R
The only cars I can see this working on is other 66/67 Olds The fender and 1/4 design brings the wheel wells a good way in from the flares in the body. Only way I could run less BS is cutting the car or raising it
https://static1.pt-content.com/images/pt/2009/10/ebaycutlass008-1.jpg
https://static1.pt-content.com/images/pt/2009/10/ebaycutlass009-1.jpg
https://static1.pt-content.com/images/pt/2009/10/ebaycutlass0361-1.jpg
qwk406
10-29-2009, 08:21 PM
Any 68-69 chevelles out there? Looking for wheel/tire ideas, so many unbelievably gorgeous cars on this site, I need to do something so I can set mine apart from the masses. I've got a lot of new stuff going on it to make it more pro-touring, looking to do a set of wheels next any pics would help make an incredibly difficult task a little easier!
kevin kolesar
11-01-2009, 11:03 AM
Intro Rally
Front 17 x 7 with 4.0" BS Wilwood brakes
Rear 17 x 8 with 4.5" BS Ford 9" Wilwood brakes
225-50-17 Kumho Ecsta SPT
255-50-17 Kumho Ecsta SPT
gearheads78
11-01-2009, 07:09 PM
Intro Rally
Nice...I have always liked that wheel
firewood
11-02-2009, 02:31 AM
I love to see less comon vehicles like this. Very nice! More?
gearheads78
11-02-2009, 05:32 PM
thanks
BuickGS
11-08-2009, 06:15 PM
My 72 Buick GS w/ 17x8s front and 18x9.5s rears. Everything SC&C and KORE3 sells!
Can anyone guess the wheels? They were from Discount Tire a couple of years back.
RYU
12-17-2009, 10:21 PM
updated post #11 with pictures for reference.
driftinblzr
12-18-2009, 05:05 AM
3rd Gen Firehawk (Ronal R-15)
17x9.5" 5.5" BS
275/40-17 Goodyear GS-CS dry rotted tires (for mock-up only)
1" spacers (front)
1.5" spacers (rear)
Later, Doug
vsefiream
12-29-2009, 01:08 PM
I am guilty of not having the wheels mounted on the car yet but I have mocked them up and they fit :). They are Jongbloed 214's, I like the old school look. They're 17x 9 front and 17 x 11 rears wearing 275 40 17's and 315 35 17's. I like how the black hoops make the wheels look like they have stock like tall tires mounted.
https://static1.pt-content.com/images/pt/2009/12/DCP_4288-1.jpghttps://static1.pt-content.com/images/pt/2009/12/DSCF0987-1.jpg
AndrewNTX
02-22-2010, 03:57 PM
CAR: 1963 Ford Falcon Sprint.
Wheel size:
17" X 7"
Back spacing:
4.75"
Tire size:
215-45-17
Make/Model of tire: Bfg KDW2
Make/model of wheel: American Racing Salt Flat
AndrewNTX
02-22-2010, 04:06 PM
CAR: 1988 Ford Mustang LX Coupe
Wheel size:
Front 18" X 8"
Rear 18" x 9"
Back spacing:
Front 5.75"
Rear 6.75"
Tire size:
Front 245/40-18
Rear 275/35-18
Make/model of wheel: Moda R6
krz-fasc3
02-23-2010, 09:44 PM
1973 Corvette
Wheels: 18x7.5 20x8.5
Tires:245/40/18 285/30/20
Had to use 1" spacers, lowered 4"s front and back
JJEH
02-23-2010, 10:21 PM
Wow... i see alot of hot wheels in this thread... :twothumbs
Here are mine...
https://www.pro-touring.com/forum/vbpgimage.php?do=full&p=7309
7x16" w/ 205/55R16 (factory z26)
I was thinking about 18" wheels... but i love these one :)
For the wintertime i use boring 15" crosslaces...
cees67
02-24-2010, 04:55 AM
Wheel size:
Front 18" X 8"
Rear 18" x 9"
Back spacing:
Front 5.75"
Rear 6.75"
Tire size:
Front 245/40-18
Rear 275/35-18
good lookin notch man!!
gearbanger
02-24-2010, 05:46 AM
17x8 front 5" BS
18x9.5 rear 5.5" B.S.
Intro Vista
245/45/17 front
295/45/18 rear
Nitto 555
No mini tubbing (yet)
66 Chevy 12 bolt in rear
Front is tall spindle swap which pushes things out about 3/8"
eptroller
02-24-2010, 12:15 PM
That looks sick!! I love it! Great stance and that deep dish in the back looks wicked! Great job! :twothumbs
NASH JUDGE
02-24-2010, 09:16 PM
pretty cool....any other suspension mods ?
17x8 front 5" BS
Intro Vista
245/45/17 front
295/45/18 rear
Nitto 555
2blownstangs
12-20-2010, 06:13 PM
here are a couple to bring this thread back
https://static1.pt-content.com/images/pt/2010/12/107_0859-1.jpg
https://static1.pt-content.com/images/pt/2010/12/107_0860-1.jpg
https://static1.pt-content.com/images/pt/2010/12/107_0323-1.jpg
https://static1.pt-content.com/images/pt/2010/12/107_0319-1.jpg
JRouche
12-20-2010, 10:25 PM
I already posted my wheels/tires but it was still in the garage. Now shes on the road. So, some road (or off road) shots. JR
62 Nova.
Rear- 285/40/17 on 10" wheels 5.75" BS
https://static1.pt-content.com/images/pt/2010/11/a-1.jpg
https://static1.pt-content.com/images/pt/2010/11/h-1.jpg
https://static1.pt-content.com/images/pt/2010/11/i-1.jpg
https://static1.pt-content.com/images/pt/2010/11/z-1.jpg
NASH JUDGE
12-24-2010, 12:56 AM
Intro Matrix
19x8 245 35 19
20x10 305 35 20
PT Goat
12-24-2010, 07:52 AM
Intro Vista 17x7 (4.75") and 18x8 (5") on 225/50 and 255/45 BFG KDW redlines.
Coursey
12-27-2010, 09:09 AM
Inrto Vista 17x7 (4.75") and 18x8 (5") on 225/50 and 255/45 BFG KDW redlines.
Where did you get the KDW Redlines?
Evldoer
12-29-2010, 02:46 AM
My turn with another Nova.
Intro Pentia's
17x7 up front with 4.5" B.S.
18x12 in back with 4.5" B.S.
https://static1.pt-content.com/images/pt/2010/07/100_17721-1.jpg
https://static1.pt-content.com/images/pt/2010/10/100_1596-1.jpg
Bryce
12-29-2010, 06:47 AM
https://static1.pt-content.com/images/pt/2010/11/tn_full_DSC03452-1.jpg (http://www.motortopia.com/photos/586412)
here is my new set up.
17 x 9.5 with a 275/40/17 in the back
17 x 8 with a 245/45/17 in the front
PT Goat
12-29-2010, 07:52 AM
http://www.dbtires.com
baggedK
01-11-2011, 08:55 AM
Althought not your typical PT setup, I want to share anyway. Slowly... but surely this project is coming along.
Fitment:
22x9 front with 6.5" backspace 245/30/22
22x9 rear with 5.5" backspace 255/30/22
UMI 4035-B solid front sway bar (1.25")
KYB KG4515 front monotubes
KYB KG5507 rear monotubes
OEM spongy worn out saggy butt springs
Next upgrades on my "to-do" list:
ECI Narrow-Track disc conversion (unless I can get an answer from Wilwood regarding their products and track width change)
Possibly Airride- or at least drop coils from OPGI since they seem to be the only place I've found to sell 2" and 3" drop springs.
I get a little rub up front when turned at full lock when going through dips/driveways but it's manageable until I can narrow the front track alittle. As for the wheels, they Raceline and use a Centerline Forging- they weight about 61lbs with tires mounted each... I was very suprised when I brought them home.
https://static1.pt-content.com/images/pt/2011/01/213934ClariceFront-1.jpg
https://static1.pt-content.com/images/pt/2011/01/213935ClariceRear-1.jpg
I know most of you won't like this setup.... but I have done some homework and it's not a daily driver or full PT competition car, it's a fun cruiser and I still have quite a few plans for improvements- as everyone knows, it just takes time and money.
zx10intn
01-11-2011, 12:01 PM
i like it man, as soon as my wheels show up next week i will be running 22 on my chevelle. not the best for the track, but hey, if its jsut cruising and showing, do whatever makes it look best in your eyes, even if theyre 30" lol
TheJDMan
01-12-2011, 05:20 PM
Morgan,
What is the backspacing of those wheels?
Morgan
01-13-2011, 07:34 AM
Steve,
Rear wheels have a backspacing of 6" and the fronts are 4.07"
Morgan
01-13-2011, 07:37 AM
Steve,
I should mention that my car is no where near stock as far as the chassis goes so please don't go ordering the same wheels thinking they will fit. My car has a custom full square stock frame with a full custom floor pan, a Currie HD narrowed rear and a C.A. Chassisworks front clip. I actually ordered the wheels and tires then had the chassis built around them (of course this was back when 17s were HUGE and nobody was running them LOL).
TheJDMan
01-13-2011, 04:08 PM
Thanks Morgan,
I'm tubbing my 68 and installing a Prodigy triangulated 4link with a narrowed 12 bolt and DSE or Art Morrison front sub-frame. I'm not a big fan of 18" and bigger wheels but I love the look of your wheels. It reminds me of the old Trans Am racers. To be honest I would stay with 15" wheels except that would severly limit my brake size so I'm compromising on 17". What gear ratio are you running in rear end? Do you have more photos? I would love to see what it looks like from directly behind. I went to your web site but the Camaro's images are frustratingly ghosted under other images so it is hard to get a really good look.
Yelcamino
01-13-2011, 05:10 PM
Here's my new Forgeline GA3 wheels and Falken tires...
Morgan
01-13-2011, 06:19 PM
Thanks Morgan,
Steve,
I just went to my build site (www.strokerss.com) and realized that i don't have any good shots from the back there either. I'll take some this weekend and post them up for you. I should have done that after i put the drag radials on anyway. Thanks for the compliments on my car's look. A '60s Trans Am racer is exactly what I was going for - as if GM built a limited edition SS Camaro with a 383 Stroker designed for Trans Am series racing and in order to get it approved they had to make it in a convertible just like the pilot Z28.
rudyt5000
03-13-2011, 09:12 AM
Boss 338's
18x8 4.5 b.s 245-40-18
20x8.5 5.25b.s 255-35-20
Roadbuster
03-13-2011, 09:36 AM
18x9 and 18x11 Forgeline S03 wheels with 255/35R18 and 305/35R18 R888 rubber
https://static1.pt-content.com/images/pt/2010/10/CIMG3429-1.jpg
colt zantop
03-13-2011, 09:51 AM
heres mine...........
IFORGED evolutions
18x7.5 front and 18x9.5 rear
baggedK
11-20-2011, 04:44 AM
UPDATE:
The 22's are long gone and 17's have taken their place.
17x7 & 235/45/17
17x8 & 255/45/17
https://www.pro-touring.com/attachment.php?attachmentid=51419&stc=1&d=1321734504
https://www.pro-touring.com/attachment.php?attachmentid=51420&stc=1&d=1321734505
robin93784
11-20-2011, 04:57 AM
will be finished somday!
rivs68
11-20-2011, 07:15 AM
https://static1.pt-content.com/images/pt/2011/11/ry3D400-9.jpg
https://static1.pt-content.com/images/pt/2011/11/ry3D400-10.jpg
Boze Alloys "Injected"
front 18 X 8 nitto 555 245-40-18
Rear 18 X 10 nitto 555 275-40-18
No tubs, rolled lips...
solarguy09
11-20-2011, 08:17 AM
Man you guys have some SWEET Cars.......
This is my car with Jason's wheels Photo shopped in.
They are being Built now, and the Suspension will be Coil Overs and fully Adjustable to get this Stance...
I tried to wait to show the Real thing, but it will be a Month or So before any Pictures of it in Person...
Off came the 15" Enkei's and on go the Rushforth 18", and 19"s, with a little extra stuff underneath to go with them, haha..
I am so excited, it is hard to think sometimes..
But I have to keep focused to fund my habit....
SLO_Z28
11-20-2011, 09:41 AM
https://static1.pt-content.com/images/pt/2011/09/DSC_0604-1.jpg
Summit Legend wheels. 17x8 with 235/40, and 17x9 with 275/40. Soon to be 9's on the front with 275's.
TheJDMan
11-20-2011, 06:15 PM
Forgeline WC3 gunmetal center polished hoop 18x10 275/35-18 front 18x12 335/30-18 rear.
https://static1.pt-content.com/images/pt/2011/11/Camaro1-2.jpg
https://static1.pt-content.com/images/pt/2011/11/Camaro2-2.jpg
Rod
11-20-2011, 07:50 PM
RE-DONK-ULOUS
looks better!!! and probably rides WAY!! better
aussietony
11-21-2011, 02:39 AM
These are my road wheels 18 x 7 intro and 18 x 9.5 intro
514665146551467
these are my race wheels 18 x 8 & 18 x 9 showwheels.
The WidowMaker
11-22-2011, 02:21 PM
3 piece rushforth wildsides. 20x11 315/35/20 rear, 19x9.5 275/35/19 fronts.
https://static1.pt-content.com/images/pt/2011/11/IMG_3185-1.jpg
https://static1.pt-content.com/images/pt/2011/11/IMG_3187-1.jpg
https://static1.pt-content.com/images/pt/2011/11/IMG_3195-1.jpg
Lenie
11-22-2011, 03:01 PM
Do you have a pic of a complete side view of the car? Very nice set up.
91svtcoupe
11-26-2011, 08:00 AM
Heres my True Forged Wheels on my T top Build
https://static1.pt-content.com/images/pt/2011/11/0682-1.jpg
91svtcoupe
11-26-2011, 08:02 AM
Purchasing these Wheels for the Next Project.
https://static1.pt-content.com/images/pt/2011/11/5d84c465-1.jpg
https://static1.pt-content.com/images/pt/2011/11/d9435891-1.jpg
https://static1.pt-content.com/images/pt/2011/11/f60da739-1.jpg
https://static1.pt-content.com/images/pt/2011/11/4cb28223-1.jpg
PRO TC
11-26-2011, 11:32 PM
https://static1.pt-content.com/images/pt/2011/11/DSC00050-1.jpg
nova6speed
12-06-2011, 09:24 PM
1967 Chevy Nova with a TCI front end with coilover shocks and a Hot Rods to Hell Truckarm Suspension with a mini tub
Vintage Wheel Works V40s
Fronts: 17X7 with 3.75 BS and Kumho Ecsta XS 245/40/17
Rears: 17X9.5 with 4.5 BS and Kumho Ecsta XS 285/40/17
https://static1.pt-content.com/images/noimg.gif (http://rides.webshots.com/photo/2255591980102138415ycTGZJ)
https://static1.pt-content.com/images/noimg.gif (http://rides.webshots.com/photo/2175572450102138415yZElZf)
DirtShark
12-06-2011, 10:30 PM
Really nice looking car...
solarguy09
12-16-2011, 02:20 PM
Just mounted the fronts....18x8.5 Rushforth Superspokes
Flush 71
12-16-2011, 02:52 PM
Specs? wheels and suspension
usa-69z
12-17-2011, 01:49 PM
rushforth superspokes , 18 x 10 & 18 x 8 waiting on some forgelines as a 2nd set for xmas !
https://static1.pt-content.com/images/pt/2011/11/STRIPESBARRELCARFEST021-1.jpg
solarguy09
12-18-2011, 05:50 PM
A second set ??? Wow...Go man Go... I would too, if I could...
a set of my Rushforth's and Yours would be nice...
Coursey
12-19-2011, 05:24 AM
BOZE 20 22S
https://static1.pt-content.com/images/pt/2011/10/LEESDODGE2010119-1.jpg
What model truck is that?
I dont think i have seen one.
I like it!!!!!
solarguy09
12-19-2011, 08:09 AM
I like it!!!!!
I have seen it on here before, and i said WOW ,the last time.....
WOW..Sweet Truck..Big rims that fit Perfect..
6D9 Matt
12-20-2011, 09:57 AM
That is one SWEET truck. Wow. Gorgeous...
71OLDS
12-30-2011, 10:18 PM
18x8 18x10 NewGen500 wheels
255 45 18 Nitto 555s, 305 45 18 Nitto 555R drag radials
https://static1.pt-content.com/images/pt/2011/12/NewGen5002-1.jpg
https://static1.pt-content.com/images/pt/2011/12/NewGen5001-1.jpg
https://static1.pt-content.com/images/pt/2011/12/NewGen50010-1.jpg
https://static1.pt-content.com/images/pt/2011/12/NewGen5005-1.jpg
Rod
12-31-2011, 12:39 AM
heres mine
https://static1.pt-content.com/images/pt/2011/12/IMG_6042-1.jpg
ctsvmongo
01-30-2012, 10:35 AM
I love this and would like to know where or how you had this done? Can you buy the wheels this size anywhere now? Awesome look, I've been trying to figure out how to keep this look but get rid of the not so awesome red lines. Thanks!
ctsvmongo
01-30-2012, 12:54 PM
solarguy09
01-30-2012, 03:30 PM
Ok, the beast is home...
Rushforth Super Spoke
18x9 in front, and 19x10 in the back..
dmc69
02-04-2012, 01:50 PM
1969 Camaro
Boze Tach
Front: 18x8
Rear: 18x10
REAR SUSPENSION
Detroit speed 3' drop leaf springs
FRONT SUSPENSION
Hotchkis 2' springs
Kore3- z51 brake kit.
Not mini tubbed.
tubbed69
02-05-2012, 07:22 AM
new Boze Speedstershttps://static1.pt-content.com/images/noimg.gifhttps://static1.pt-content.com/images/pt/2012/02/P1000587-1.jpghttps://static1.pt-content.com/images/noimg.gif
Henesian
02-06-2012, 07:41 PM
https://static1.pt-content.com/images/pt/2012/02/IMAG0320-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMAG0316-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMAG0318-1.jpg
1976 T/A with Year One 17x9 snowflakes with 4-7/8"(0 offset) backspacing and 275/40/17 Kumho Ecsta ASXs all around.
Not quite as nice as your guys' cars, but it's a smog legal canyon-carving machine, with that college student style budget written all over it :D.
NASH JUDGE
02-09-2012, 10:28 PM
Cool T/A ! Thanks for sharing. Keep it up.
Joe A Sanfilippo
02-11-2012, 05:18 PM
Very Nice Cars!!
Joe A Sanfilippo
02-11-2012, 05:21 PM
Intro Pentia wheels
Nitto NT555 tires
Front – 245/40-18
Rear – 295/45-18
1966 Chevy Chevelle
Front – 255/40-18
Rear – 295/35-19
Love them!! Very nice!!
robbie9999
10-12-2012, 10:31 AM
what are these wheels ? and size please ?
WAREWOLFTA
10-18-2012, 07:17 AM
THESE CARS ARE BEAUTIFUL.....BRE SNOWFLAKES are being made..
18x9 FRNT
19X10 REAR
79 TRANS AM 455 STROKED TO A 498.
HELLCAMINO
10-19-2012, 10:58 AM
Just a set of Boss 338's here, can't afford the high dollar "bling"!
https://static1.pt-content.com/images/pt/2012/10/IMG_20120730_154943-1.jpg
Grim
10-20-2012, 11:44 AM
For the Low budget guys like me.
These supposedly are exclusive to Discount Tire. Summit Racing has them. Summit price matched the online price of Discount tires at $129 on the fronts and $133 delivered plus tax.
MB "Old Schools"
Front 17x8 4.5 Back space (zero offset) with 245/40 17 BFG G-Force Comp2
Rear 17x9.5 5.5 Back space(zero Offset) with 275/40/17 BFG G-Force Sport comp2.
The fronts were 21lb just about on the button. the rears were 21.9lb.
Car is stock suspension as pictured (sagged) but upgrading the brakes and needed the clearance of 17's. No fit problem at all.
Wheel Werkes
10-21-2012, 07:02 AM
Love that black truck!
Nice cars guys!
Lenie
10-21-2012, 11:24 AM
Forgeline's
https://static1.pt-content.com/images/pt/2012/10/blackcar017-1.jpg
https://static1.pt-content.com/images/noimg.gif (http://imageshack.us/photo/my-images/831/blackcar031.jpg/)
https://static1.pt-content.com/images/pt/2012/10/blackcar032-1.jpg (http://imageshack.us/photo/my-images/838/blackcar032.jpg/)
migg400
10-21-2012, 01:10 PM
Nice!!
Forgeline Wheels
10-23-2012, 06:44 AM
Forgeline's
Lenie, this looks great! When you get this project completed, please be sure to alert us. We'd really like to add this car to our website and share on social media. Thanks!!
maxxom
11-02-2012, 08:19 PM
https://static1.pt-content.com/images/pt/2012/11/photo11-1.jpg
https://static1.pt-content.com/images/pt/2012/11/Houston2012062900268-1.jpg
qnitro
01-01-2013, 03:00 AM
Lenie, I f'n love your bird..
Forgeline's
LeighP
01-02-2013, 12:27 AM
Well, my Firebird is probably more Resto-mod than PT, but heres some pics with the 17"s on it.....
CAR: 1971 Firebird - Pro-Touring F-Body GT suspension all around.
1). Wheel size:
FRONT and REAR : 17" X 9"
Offset front and rear - 0
2). Tire size:
FRONT & REAR : 255 / 50 x 17"
3). Make/Model of tire: Nitto INVO
4). Make/model of wheel: Year One - Honeycomb
Very good value, if you like factory styled wheels, but they are not particularly light.
Lenie
01-02-2013, 10:17 AM
Thanks Kevin, appreciate it.
Buryingthesun
09-14-2013, 09:35 AM
Here is my 1967 Firebird
Fronts 17x8.5 5" bs 255/40r17 Falken Azenis Rears 17x8.5 5" bs 275/40r17 Falken Azenis slight rubbing on fender hardware because of the ride height. That has since been resolved with some modifications to the wheel wells/fenders. Factory rear ride height, QA1 coilovers up front
gearheads78
09-15-2013, 08:04 AM
my latest
17 x 8 and 17 x 9 TeamIII / ET wheels on a stock 69 SS
Enzo Damico
09-15-2013, 04:43 PM
8228482285Coys 18 /9.5 285 and 235 18/8
BuddyP
09-15-2013, 06:26 PM
Boze Lateral-G's with Smoke centers and Polished hoops. 18x9 front, 18x11.5 rear
sanman
09-16-2013, 08:12 PM
823568235782358
These are 18x8's front 18x9's rear wrapped in Nitto 245/40's front 275/45's rear. Upper and lower tubular with QA1's front. Hotchkis 1 1/2 drop leave's with Hotchkis frame connectors. Love the handle love the car.
sanman
09-16-2013, 08:18 PM
823568235782358
Forgot to mention the wheels are Showheels Streeters.
71 Gun
11-27-2013, 12:17 PM
Been wanting the Mini-Lite look for years now, but with bigger rim sizes than 15"s
Front:
255/45/18
Rear
285/40/18
Hotchkis TVS system installed with 2 inch drop, slide-a-links traction control, and Nitto Tires.
I still swear I could have gotten 295's+ in the back though :ssst:
860758607686077
krwyellowz28
12-23-2013, 07:44 PM
This thread is full of amazing cars... I almost don't want feel like my cars are worthy, but here I go:
1979 Firebird 301/TH350
Suspension:
- Stock front springs with almost 2 coils cut off and Bilsteins
- 2" blocks in the rear with Bilsteins
Wheels:
- 17x9 YO Snowflakes
Tires:
- Front 245/45/17
- Rear 285/40/17
https://static1.pt-content.com/images/pt/2013/12/20120508_200318_638-1.jpg
https://static1.pt-content.com/images/pt/2013/12/20120508_200004_629-1.jpg
1970 GTO Judge LS1/4L60e
Suspension:
- Front all stock with QA1 single adjusts and LS1 brakes
- Rear is currently saggy stock springs and Bilsteins, but have Hotchkis springs to install soon.
Wheels:
- Front 17x7 Boyd Coddington Smoothie II, not sure on BS
- Rear 17x8 Boyd Smoothie II's, not sure on BS
Tires:
- Front 225/?/17
- Rear 255/?/17
https://static1.pt-content.com/images/pt/2013/12/IMG_20130505_174441_836_zpsd55bd972-1.jpg
https://static1.pt-content.com/images/pt/2013/12/IMG_20130504_161515_251_zpsc1e67931-1.jpg
https://static1.pt-content.com/images/pt/2013/12/IMG_20130507_111925_012_zpsd97a1b76-1.jpg
1996 Impala SS stock LT1/4L60e
Suspension:
- Front Eibach Pro-Kit with 1/2 coil removed, Bilstein HD shocks
- Rear Eibach Pro-Kit, Bilstein HD shocks, and PMT extended tubular rear suspension w/adjustable uppers
Wheels: Torq Thrust II's
- Front 20x8" not sure of BS
- Rear 20x10" not sure of BS
Tires:
- Front 275/35/20 (too wide for an 8" rim... I'll go with 255/35 next time)
- Rear 295/35/20 (perfect to stay away from the rubber band look)
https://static1.pt-content.com/images/pt/2013/12/IMG_20131105_205602_993_zpsbfbba930-1.jpg
https://static1.pt-content.com/images/pt/2013/12/IMG_20131105_205527_993_zpsecbcb044-1.jpg
robbie9999
12-23-2013, 08:28 PM
275/35/20 rear. 20x10
235/35/19 front 19x8
Q1 coil overs standard height
Asanti 505 concave not best choice specially for lip on muscle cars should have picked better design live and learn
Guisseppe69
12-11-2014, 09:35 PM
1). Wheel size:
FRONT: 18" X 9.5"
REAR: 18" X 10"
Back spacing:
FRONT: 4.75"
REAR: 4.75"
2). Tire size:
REAR: 285 / 40 ZR18
What are the off set of your rims pls?
one_lo_one
12-12-2014, 12:52 PM
Had 2002 Z06 Wheels originally and then we started a complete rebuild on the car and are now doing 19x8 and 20x10 Rushforth Livewires. The frame has a 1-1/2 mini tub done to tuck the wheels more now since it was so tight with the 18x10.5 and 17x9.5 that the Z06 wheels had.
GS163
12-13-2014, 03:24 AM
https://static1.pt-content.com/images/pt/2014/12/N4-1.jpg (http://s781.photobucket.com/user/GS163/media/N4.jpg.html)
https://static1.pt-content.com/images/pt/2014/12/FullSizeRender-1.jpg (http://s781.photobucket.com/user/GS163/media/FullSizeRender.jpg.html)
stangreen
12-18-2014, 05:40 AM
Weld RTS 77b. 17x8. 17x12. B.s.4.7 with 345/40/17
69LSX
12-28-2015, 01:04 PM
18" Circle Racing Billet Rallyes
121440
69496
01-07-2016, 08:58 PM
121923
Not the best pic. Rush forth 18x10 and 18x9, 265/35 and 295/35.
jy211
01-08-2016, 05:00 AM
http://imageshack.com/a/img911/7169/QLWsvk.jpg
Rushforth Rated X - matte black, polished lip
19x8 - 4.75 BS
20x10 - 4.25 BS
Sarky427
04-08-2018, 03:53 AM
What size tires are you running on the 19/20 set up ?
pitts64
11-24-2018, 06:11 PM
My favorite, ET Vintage V in proper scale to the body..
beadblaster
11-27-2018, 08:44 PM
17x11 v45 vintage wheel works
Shawn0331
11-28-2018, 11:13 AM
Ambit FF4's. Flow formed 18x10.5 with +15mm of offset. 21lbs each and were only 600$ for all 4! Best bang for your buck.
https://static1.pt-content.com/images/pt/2018/11/160a05f5d721435cae2fe272c8501886original-1.jpg (https://beta.photobucket.com/u/ShawnG0331/p/160a05f5-d721-435c-ae2f-e272c8501886)
https://static1.pt-content.com/images/pt/2018/11/cca47a03aaa54aa69cc3d9a0646f1727original-1.jpg (https://beta.photobucket.com/u/ShawnG0331/p/cca47a03-aaa5-4aa6-9cc3-d9a0646f1727)
https://static1.pt-content.com/images/pt/2018/11/29c1326efa084ffeae50e96d1dceed1eoriginal-1.jpg (https://beta.photobucket.com/u/ShawnG0331/p/29c1326e-fa08-4ffe-ae50-e96d1dceed1e)
The.BlackBowtie
01-31-2023, 05:54 PM
I tried to contact you about the anvil spoiler but I am too new to reply there.
thedugan
02-01-2023, 05:27 AM
Rushforth SuperSpokes
18x9 -- 275/35/18 in the Front
19x12 -- 325/30/19 in the Back
205133
