View Full Version : Questions on a SFI plate for a L92/4L80e combination
josht
08-21-2009, 02:44 PM
So I have a 2007 L92 and a 2005 4L80e with a stock 4L80e converter.
The L92 has a flexplate, do I need a 4L80e spacer?
I was thinking of buying a SFI flexplate but am confused on what will work.
I found a 4L80e TCI flexplate part # 399754 168 tooth.
The listing says for LS1, LS2, LS6 & LS7 all GM GEN III LS engines.
Are there any other 4L80e SFI flexplates?
So does this part work for my application?
Do I need to use the GM spacer?
When I get the correct converter how do I order it correctly?
Do I order a 4L80e converter with the 4L80e bolt pattern and the longer shaft?
Are all LS flexplates 168 tooth as I need a starter?
thanks
Steve Chryssos
08-24-2009, 08:48 AM
That'll work.
I'm not sure if you need to use the bushing. All of the converters we sell are custom built. In your case we supply a converter with the billet front cover set up for your L92.
You will be disappointed with the stock converter. It's big, heavy and has a very low stall. Robs lots of power and doesn't like to spin.
