View Full Version : Recommended gear oil?
69TAPoser
08-19-2009, 04:28 AM
What's the best gear oil for a Ford 9" with a Detroit Locker center? And how much do I need? (I am a new to Ford rears)
Phil
Yoda4561
08-19-2009, 04:49 AM
The detroit locker isn't too picky. You can pretty much use whatever you want. A good 80-90 weight is fine for light street duty, 140 weight for towing and street/strip stuff. Dino/syn shouldn't make much difference, the synthetic will probably stay more stable under towing loads and high speed use. Capacity is 2.5 quarts, in practice a little less with aftermarket carriers and leftover oil from the last fill. You won't need any sort of friction modifier or other additives since the detroit locker doesn't use clutches.
big gear head
08-19-2009, 06:05 AM
I use 75W140 with mine. I don't know if it makes any difference or not, but I use the heavier oil to try to cut down on the noise from the locker.
JEFFTATE
08-19-2009, 01:21 PM
I'm gonna' try Torco RGO 85-140.
I haven't used it yet , but I've heard good things about it.
