View Full Version : 68 Camino, front wheel size..
sagacious
08-17-2009, 05:54 AM
im looking to see the widest tire/rim combination i can fit on my '68 el camino. (front) 15'' rims. backspacing, etc. help! thanks. btw, i have drums now and plan to add discs later if that makes a difference.
derekf
08-17-2009, 06:31 AM
It's not the 15"s you're asking about, but I had 275/40-17s on 17x9.5 wheels (Cragar Soft 8s) on my 69.
sagacious
08-17-2009, 07:13 AM
What was the backspacing on those rims? I WOULD get 17's but i already have centerline auto drags on it with 295/50/15s on back that actually fit after i rolled the inner fender lips. looks good like it is. but im basically running bicycle tires up front. not my style, so i gotta change 'em. :)
derekf
08-17-2009, 09:50 AM
Summit says they're a 5 inch backspace.
sagacious
08-17-2009, 10:20 AM
is it safe to assume a 15x9.5 with 5'' backspace and 275/50/15 tire combo would be the same as yours?
derekf
08-17-2009, 10:39 AM
Never safe to assume :)
I'd expect you'd have more sidewall bulge with your 50-series tire; not sure how much though or if it'd rub on yours. The 275/50-15s I had on the back (also on a 9.5) had some serious bulge going on but I think it varies by manufacturer.
Otherwise should be pretty similar.
USAZR1
08-17-2009, 11:11 AM
That wheel size will probably have interference issues with the A-arms.
My 69 Elky had 17x9's w/5" backspacing and 275/40/17 Kumhos. Clearance was really tight and I had to go to buttonhead fasteners on the inner wheelwells. IMO,a 17x9.5 really needs 5.5" backspace on the front.
sagacious
08-17-2009, 11:41 AM
thanks a lot for the information guys, this is my first elky. ive had a nova for several years and i know that thing inside and out. does anyone know what the bolt circle dimensions are for elkys? dont know if it takes truck or car rims.
454ragtop
08-17-2009, 04:08 PM
Bolt pattern is same as Chevelle, 5 on 4 3/4".
