View Full Version : Chassisworks front sub-frame question – tire size?
markd
08-15-2009, 11:32 PM
What tire / wheel combo is everyone running with a Chassisworks sub-frame?
My front tires are rubbing the fender and frame when you turn the wheels.
I have 245 / 40 / 18 Toyo R888 tires and the wheels are 18 x 9. I don’t remember the backspacing we used.
Here is what I found on the Chassisworks website about front tire size: “The system accepts factory height (25.5”) tires, with up to an 11” tire section width and 5” wheel backspacing. Acceptable sizes include: 275/45-16, 275/40-17, 275/35-18, 275/30-19, and 275/25-20. Note: 1967-68 Camaro fenders may limit tire section width to 9.5”.”
Any suggestions? Should I change the BS? Use oversized inner fenders wells?
I will call Chassisworks on Monday to get their recommendations, but wanted to see if anyone else had issues.
Mark
Roadbuster
08-16-2009, 06:31 AM
Mark
Mark,
You can easily measure the backspace. Lay the wheel face down (on something soft!), put a straight edge across the rim and measure to the mounting surface. Now you will have more information on hand when you call Chassisworks.
Oddly, I have R888s 255/35R18 on 18x9 and yours tires look wider with 245/40s.
Jon
Vegas69
08-16-2009, 08:10 AM
You don't have any negative camber in the alignment yet. That will help the outside. It won't help the inside. Are there bump stops for the steering?
