View Full Version : Building a Console: What Materials to use?
70chevelle406
08-11-2009, 04:52 PM
I plan on building a custom console for my 70 Chevelle to house my Hurst quarter stick and guages. What materials would be bust to use?
XLexusTech
08-11-2009, 05:04 PM
Fiberglass would be my Go to. I have seen wood and sheet metal used often
FULMNTE
08-11-2009, 05:09 PM
www.classictruckconsoles.com is where I got my unfinished console. Check the 71 Monte in the customer pics, it's mine
70chevelle406
08-11-2009, 07:17 PM
VEry COol. I'm gonna have to save up and pick one of these bad boys up! Thanks Andreas
wellis77
08-11-2009, 08:28 PM
I may be picking one of those up myself, thanks for the link.
FULMNTE
08-12-2009, 05:28 AM
You are welcome... They make a nice product...
Since I have a standard Tremec in my Monte, the shifter position was way forward....
Smock67
08-12-2009, 10:48 AM
Hmm i wondering how that would look in the Bird... i may have to pick on of those up after my car is running and all kinks are taken car of.
Adam@Autoloc
08-12-2009, 11:55 AM
MDF and fiberglass...ill warn ya..the fiberglass is a PITA
FULMNTE
08-12-2009, 01:27 PM
Please let us know why?
jackfrost
08-13-2009, 10:10 AM
hmmm... i've found fiberglass is pretty easy to work with. just wear gloves, and know you'll be doing a LOT of sanding.
I think it depends on what sort of design you want. if it'll be mostly square, then go with steel or MDF. if you want it to be rounded or curvy, then make a frame out of MDF and stretch fleece over that you can fiberglass, similar to the way sub boxes are made. that's the approach I'll likely be taking.
also, take a walk through the junkyard, and see what's available. you might be able to get one that's close to what you want and modify it to work.
venturabeachpup
08-19-2009, 04:00 AM
Here's a technique I've used to build some fiberglass parts that can be addapted to building your console. Build your frame with small wooden slats. Cover them with clay and shape the clay to the shape and dimensions that you want. Then the clay gets covered with a couple inches of plaster. Let the plaster dry hard and then remove the clay and wood.
You should end up with a plaster mold that can be lined on the inside with fiberglass resin and cheese cloth. Let the fiberglass harden and break off the plaster. Now you have a lightweight, in the rough, fiberglass console that you can work with.
It's a lot of work but the sky is the limit on shaping it and the part comes out pretty. (and lightweight)
George
09-02-2009, 09:37 PM
The way to go is wood/wire frame then use Lycra or an old t-shirt or some kind of stretchy cloth.
The clothe goes over the frame to create curves and what not, then fiberglass over it.
Ive used this technique for making custom subwoofer boxes and it is very easy and very cool. The end product is very custom with curves and turns that you cannot duplicate with wood/metal. Plus its light and easy to sand/paint use body filler, etc, top with adhesive and leather/vinyl.
