View Full Version : Lt1 e-brake brackets
Ishmael
08-09-2009, 08:35 PM
Is there a place to get just the ebrake brackets - the pieces that are attached to the back of the caliper on a 95 camaro pbr caliper that houses the spring and is unfortunately held on by an allen key in what must be some sort of weird size that GM made or rust out so they would be impossible to get out and frustrate the crap out of me? Please let me know where I can two right hand cages before I lose it.
Samckitt
08-10-2009, 05:02 AM
You talking about the bracket that holds the E-brake cable? If so, a few years ago I looking into getting them from a GM dealer to switch from a "center pull" to a "front pull" setup (or vice versa, can't remember). Found out it was cheaper to find the complete calipers from a junk yard. I think I got 2 calipers for like $25.
Ishmael
08-10-2009, 08:41 PM
I got the calipers used but you wouldn't believe what I had to go through to the get the brackets off. I finally went over to my neighbour's to use his torch. But since I bought a left and a right and need two rights and junk yards are few and far and have been picked of camaro parts I had to order a used bracket in from the states that cost more than a used caliper. Nuts.
