View Full Version : Vette IRS in 70chevelle
SShep71
03-30-2005, 11:33 AM
Will a Dana 44 Corvette IRS stand up to 500Hp? With some modifications of course. Im thinking about putting one in the Chevelle.
I am going as far a a new frame and everything, whats an IRS gonna hurt? Right? If it wont wrk Im thinking of trying a lil something with a ford 9" rear center section, and a bunch IRS parts. FEEDBACK PLEASE!!!!
-Shep
pav8427
03-30-2005, 04:43 PM
if your easy on the low end torque and high rpm 6 speed launch's it would at
least be fun for awhile.
once you made the swap atleast you would have replacement parts if you didnt hack up a factory set-up to bad
doug
USAZR1
03-30-2005, 07:22 PM
-Shep
A good Dana 44 can handle a lot more than 500hp. Some of the stroker & turbo ZR-1's and Vipers are making almost twice that. Those two cars actually use what is known as a Super 44. Stay away from plain jane Dana 44 gearsets(use Super 44 units),buy some billet spindles and steel or chromoly halfshafts,and you should be good to go.
03-30-2005, 10:29 PM
If your going to do a custom set up where your making brackets and such you might want to look into a Mopar performance Dana 44 center section. The are built as a race replacement for Vipers.
The offer several gear ratios, stout posi unit and cost under $1400. I can get them for abit cheaper. Pn P05007402 is for a 3.73 unit. Just a thought if your worried about breakage.
