View Full Version : Question about Cam Douglass's Camaro
johnm
03-30-2005, 11:19 AM
I have a question, hope someone might know this one. Did Cam Douglass have to do any tubbing or suspension work done to the rear of his camaro to get the 11inch wide tires and wheels to fit correctly? Same thing with Brandon Vivian's Trans Am.
John
DB Z28
03-30-2005, 12:27 PM
When I saw it. only the seat belt area was reworked in the wheel well. 11in rims do fit on a second gen with little work.
zbugger
03-30-2005, 12:45 PM
They fit, but it is tight. The bump at the seat belt bolt is one spot of trouble, and the other is the wheel lip. It usually has to be rolled. I've seen a few 2nd gens with 315's on the back, and yes, it does look good. Don't expect an easy perfect fit though. All cars are different. Some guys can get it to work, while others can't. Measure your car several times to make sure you can get it all in there correctly.
rickk
03-30-2005, 06:50 PM
i have the part # s for the american tt 2s 17/11 that fit the 70 - 73 camaro . call if you need help. 214 908 2100
thanks rick kirkindall cover car 2004 nov popular hot rodding
03-30-2005, 10:32 PM
I was pokin around his car this week and it didn't look tubbed, it looks like it would rub the quarter lip if lowered more. It sits right below the lip.
