View Full Version : MAP sensor vacuum question
BigBlockOlds
08-05-2009, 10:42 AM
Does a MAP sensor need to have its own vacuum signal directly from the intake manifold to work properly? Or, can I Tee off another vacuum line as long as its referenced from full manifold vacuum?
Hammered
08-05-2009, 12:27 PM
Depends on what you're teeing off of. I would not tee off the same line that goes to a booster or PCV. Either could cause pressure spikes that might affect drivability. However, there shoud be no problem sharing with a similar deadhead device like a fuel regulator.
BigBlockOlds
08-05-2009, 12:32 PM
Thanks.
I had thought about the PCV line but noticed that I've never seen anything 'T'd off that line in any application and figured it was for a reason like that.
And since I plan to have the HVAC controls vacuum line going to a vacuum canister, I figured that wouldn't be a good idea either.
This normally wouldn't be a problem but in this case, my intake manifold has zero vacuum ports. I had to add one for my PCV valve but forgot about all of the other things I would need while it was off the engine. So the only one I have left now is a small vacuum port off the base of my throttle body to use.
PRRC
08-05-2009, 01:05 PM
Here's another thing to consider. Keep the line as short as possible. or as close to the vacuum source as possible
Hammered
08-05-2009, 05:57 PM
You could get a 3/4" to 1" spacer if you have enough room and tap it for a fitting.
BigBlockOlds
08-05-2009, 07:06 PM
That's what I've been looking into this evening. It looks like I'll have to run some sort of a cowl hood to clear the intake/throttle body setup I have now so I might as well go a little taller.
