View Full Version : 1969 Nova, front wheel/tire fitment - help!
69LT1Nova
08-03-2009, 07:25 AM
I need some help wheel and tire gurus! I'm stuffing 18's under my Nova, and having no luck getting them to work. The car itself has been lowered 2" in the front, 1.5" in the rear with a complete Hotchkis TVS kit - including the TVS tuned Bilsteins. Wheel specs: ghetto IROC knock-offs, 18x8 with 4.5" BS. Tire specs: Kumho 245/40/18s. I tried 245/45s... wayyyy too tall.
Keep in mind, these ugly wheels are my "around the shop" rollers that I picked up for $200. Curbed, peeling, and all around just not my style... but I think they saved me a ton of cash on my new wheels by pointing out that 4.5" BS on an 18x8 ain't gonna work with a 245/40 tire.
https://static1.pt-content.com/images/pt/2009/08/PICT0924-1.jpg
https://static1.pt-content.com/images/pt/2009/08/PICT0925-1.jpg
As you can see, its rubbing on the rear of the wheel wells. This rubbing happens on both the inside and outside of the tire when turning either left or right. I'm wondering what will help or hurt:
Increasing the BS (I think this is the right thing to do) to 4.875 or *gulp* 5"
Going to a 35 series tire? I'd prefer not to have a rubber band for a tire
Goind to a 7" wide rim (would rather not) with a 235 or 225 width
Take my purse off, and beat in the wheel wells with a deadblow hammer for a little more clearance
From what I've read, my current set-up should work on a slightly lowered Nova such as mine... but real life is not the same as what you read on the internet...
69LT1Nova
08-03-2009, 11:52 AM
Nobody wants to chime in? C'mon, I can't be the first one that has run into this... :)
Newstalgia Wheel
08-03-2009, 12:26 PM
Have you changed your brakes on the front also? That could have you out a little farther than stock-sometimes up to .25 to .50 inch. 8's are a little funny on those cars, you need more backspacing, but you have to be careful about hitting suspension parts when you put in that backspacing. I know everyone is into the widest possible--but 7's work well on those cars!!
69LT1Nova
08-03-2009, 12:47 PM
Yes! Good question. I've swapped over to SSBC Force 10 front brakes as part of a disc conversion package.
If I were to switch to a 7" wide wheel, what tire is the right one to roll with? A 235/40? I'd prefer it to not baloon out past the rim, nor look like it's stretched to the max...
Thanks for the post!
Newstalgia Wheel
08-03-2009, 01:45 PM
If you can handle 25in of height, I like a 235/45-17 its 9in wide and looks good! If not I would go with a 225/45-17. Call if I can help you in any way!!
69LT1Nova
08-03-2009, 02:40 PM
Well... if there is any way that you can kick Vintage Wheel Works in the arse to get them to finally come out with 18's on their V40 wheels... *groan*
You convince them to finally produce them, I'll buy them from ya. :)
LS1NOVA
08-03-2009, 02:45 PM
Id go 5" BS or if you got room till it hits the tie rod, 5 1/4"
LT1Nova
08-03-2009, 05:36 PM
On my 71 I'm running 18 X 8's with a 40MM offset with a 235/50R18 cuz that's what the tire shop had used and cheap. I get just a bit of rubbing on the frame when I turn hard left I think it was. (Haven't driven yet) LS1 brake conversion, probably needs alignment, Hotchkis 1907 springs and 2207 swaybar.
08-03-2009, 07:04 PM
You could....
check your alignment and find out what your caster reading is. Reduce to gain clearence
Loosen your subframe and slide it forward, set your alignment.
modify your wells to fit.
get rims that fit. :1st:
69LT1Nova
08-04-2009, 07:17 AM
You could....
Oh, I know the alignment is screwed. I made sure of that when I fully rebuilt the suspension with Moog components, Hotchkis suspension, and SpeedTech control arms! :rolleyes:
Subframe... ugh... don't want to. I set it in there using the factory wheelbase specs, and the Alston method for squaring up the frame. Plus, the exhaust, steering box, drivetrain, etc are all in place. No thanks.
Wheel wells... I might "massage" them with a deadblow hammer just a bit to get me rolling down the road for now.
Rims. Hell yeah! Waiting for the VWW V40's to come out in 18s... waiting...:crying: I may have to settle for something else.
ProdigyCustoms
08-04-2009, 07:33 AM
The Speedtech arms add caster which pushed the wheel back in the wheel opening a bit. Increased caster is a good thing, but too much causes issue to and yours look like it is alot right now. Get the alignment done first. I would go to 4.875 BS and get a alignment, and use the 245/40/18 tires.
69LT1Nova
08-04-2009, 07:54 AM
Sounds like I need to tow this thing down to an alignment shop... 'cause I sure as heck ain't gonna be able to drive it there. :doh:
Question: how do I reduce the caster enough to get it so I can drive the car? My alignment shop is only 1/2 mile away. Toe in/out is set by the tie rods, camber in/out is by adding/removing shims... how is caster set?
ProdigyCustoms
08-04-2009, 09:45 AM
but adding more shims to the front or rear bolt move the wheel fore and aft.
69LT1Nova
08-04-2009, 09:56 AM
Gotcha! :idea: Let me try jamming some more shims in the front.
69sleeper
08-04-2009, 10:42 AM
Hey 69LT1 what size are you running in the rear?
69LT1Nova
08-04-2009, 10:48 AM
245/45/18s on the rear. Not really pushing the width limits by any stretch of the imagination. I think the 45 series on the rear gives it the right look on tire height.
https://static1.pt-content.com/images/pt/2009/08/PICT0900-1.jpg
But... with these cheap azz IROC wheels with only 4.5" BS... the meats are flirting with danger! I'm rolling the fenders as we speak.
https://static1.pt-content.com/images/pt/2009/08/PICT0911-1.jpg
This ain't gonna cut it when I get my rear disc conversion installed.
