Results 1 to 9 of 9
Thread: Shifter Install problem
08-02-2009 #1
- Join Date
- Feb 2009
- Posts
- 64
Hi Guys
I just installed a B & M Quicksilver (part # 80688) into my '77 Firebird with a 700R4 trans.
The car is not yet driving but in "dry shifting" I have had a few issues: First up, the shifter is very difficult (stiff) to manouvre/shift. Also, it seems to ratchet through two gears at times on both up and down shifts. In addition, it will not downshift into the lowest gear...ie, it selects three and not four speeds.
I have followed all instructions including the removal of the pin that allows conversion from three to four speed. I have also set the tranny cable with the transmission in park, so I do not believe that there is an alignment issue.
I am using the stock transmission cable that was there with the original TH350, changing the appropriate brackets etc with Shiftworks and Bow Tie Overdrives kits.
I have done a similar install before on my '70 T/A with a TH400 and it works flawlessly. What gives? Any suggestions?
Rich
08-04-2009 #2
- Join Date
- Dec 2008
- Location
- Lehigh Valley Pa
- Posts
- 1,269
When I put my shifter in it took me quite awhile to get everything just right. I would put the trans and shifter in park and check to make sure the swivel slides in and out of the bracket for the trans selector nice and easy. Then I would put it in first and do the same. Then into nuetral. I have some vids I posted of the install. It was for a 200-4R but might still help.
http://www.youtube.com/watch?v=_mOyawc5qd8
http://www.youtube.com/watch?v=E22QTanMYxc
http://www.youtube.com/watch?v=bP19-M4znmY1996 Federal Cadillac hearse
1988 Eureka Chevy hearse
08-05-2009 #3
- Join Date
- Feb 2009
- Posts
- 64
Hey Stickman
Interesting videos. Saw a couple of possible areas where my problem could be..........will check them and let you know.
Thanks for sharing.
Rich
08-05-2009 #4
- Join Date
- Aug 2004
- Location
- England
- Posts
- 1,042
I have a sticking problem with that I'm taking it out and replacing .Check the spring on the rh side .
08-07-2009 #5
- Join Date
- Feb 2009
- Posts
- 64
Paul67: is that also a Quicksilver shifter? If so, which spring are you referring to? Do you have a picture?
Have you gotten it sorted out? What was the problem?
Rich
08-07-2009 #6
