View Full Version : Triangle area NC, plasma cutter
brans72
08-02-2009, 04:02 PM
I was wondering if anyone here might have a plasma cutter to rent/let me borrow or you come cut for me the floor from my chevelle. I live in Durham,NC and trying to do this correctly yet the easiest way without having to buy one. If anyone can help me out please let me know. Brandon
Pro Stock
08-03-2009, 07:58 PM
I you can't find a plasma cutter have you thought about an air powered nibbler or a ziz wheel, either one would do a good job.
Dale
brans72
08-04-2009, 03:28 AM
yeah I have a air saw,ziz wheel,and saw zaw but figured for doing a full trunk,2 1/4's, wheel wells and full floor plasma would speed things up alot!!!! I have been looking at craigslist but no really good deals for me yet in decent distances. I am hoping someone from NC area will pull through and give me a hand here.
Mike Holleman
08-04-2009, 04:16 AM
Brandon, When I do a floor or trunk pan I do use the plasma cutter for the rough cuts, but my finish cuts are done with rotary cutter. Much better control and a cleaner finished edge. In past years I had no plasma cutter and did several pan jobs with the grinder, drill and rotary cutter. It is not that much faster and speed does not always equate to quality.
Mike
brans72
08-04-2009, 04:57 AM
Mike what is a rotary cutter? I have both ziz wheel and 4 inch grinder from Matco. Shame your not closer to lend me a hand with your expertese there. Brandon
Mike Holleman
08-06-2009, 05:39 AM
Brandon, A rotary cutter is what you are calling a ziz wheel. I have several from small right angle to my fav a Dynabraid 4" model. You can also convert your 4" grinder to one. I use the Dynabraid most of the time with a 1/32" wheel. Cuts fast and wears out fast as well.
Mike
Restomod
08-06-2009, 03:35 PM
I agree with Mike, the ziz or a sawzall will give you a better edge (less clean up) to weld back to.
