View Full Version : Second Skin needs help naming new thermal product - $250 gift code
Second Skin Rep
07-22-2009, 12:29 PM
As usual, Second Skin is doing its best to bring new and exciting products to the market.
This one is certainly no exception.
Over the years we have a had a lot of street rod and race car customer come to us looking for a product that could withstand the high temperatures on the engine side of the firewall. Some cars reach levels of 1000 degrees f. and for this application, we had no product to offer them.
Now we are about 8 weeks out from releasing our newest thermal insulation mat.
This new material is a multi layer composite that can withstand temperatures in excess of 1000 degrees when as little as 2 inches of air space is provided between the heat source and the product.
At ¼ inch thick and weighing in at .25 lbs per sq foot this is going to be our best thermal insulation material yet.
The foil is about 12 mils thick with a dimpled texture to increase surface area.
The Organic fibers are capable of withstanding temperatures over 1000 degrees, and the pressure sensitive adhesive is an acrylic hybrid that will grip on to any painted or primed metal surface, as well as plastic.
When subjected to a heat source of 1200 degrees the opposite side of the panel will get reduced to around 350 f.
When subjected to a heat source in the 300 degree range, the opposite side of the panel will get reduced to around 85 f. or so.
Not only can it be used on the engine side of the firewall, but it can also be used under the car, above the exhaust or transmission to block external heat as well.
Now, all we have to do is come up with a name for it.
That is where you come in. We are offering a $250 gift code to the first person that suggests the name that we decided to use.
We are posting this offer on several different forums and will be selecting a winner in the next month or so.
We have about 8 weeks before the product is ready to ship so we can take our time and wait for the right name to show up.
Thanks for your help!
ANT
www.secondskinaudio.com
ATTENTION! THIS CONTEST HAS ENDED!
I'M GOING TO SAVE YOU A LOT OF READING, JUST GO TO THIS POST (95) TO READ ABOUT FREE PRODUCT THEY ARE GIVING OUT AS A THANKS TO OUR MEMBERS.
https://www.pro-touring.com/forum/showpost.php?p=648169&postcount=95 Thanks, David Pozzi Moderator 3/28/2010
rrunner68
07-22-2009, 12:34 PM
I'd callit something simple....
"FIREwall" comes to mind....could make a cool logo with the Fire part in all bold lettering on fire and then the wall writing in lowercase and blue and chilly looking.
mach1stang
07-22-2009, 01:00 PM
How about therm-light?
Damn True
07-22-2009, 01:05 PM
Thermal Armor
ill steez
07-22-2009, 01:07 PM
defheat (sheet, etc)
heatsink
defheat-sink
firestop
firesink
i'll think of more! sounds like a cool product!
Steve1968LS2
07-22-2009, 01:11 PM
Pyroshield
Pyrotech
Camaroholic
DampliFire
That'd probably be confusing though. ;)
<- whole 94Z is lined with Damplifier
Scott Parkhurst
07-22-2009, 01:12 PM
ThermoWall or
ThermoBarrier
1badchevelle
07-22-2009, 01:19 PM
skin graph
Hidro
07-22-2009, 01:32 PM
FireSkin
Fire-Skin Pro
Andrew McBride
07-22-2009, 01:35 PM
fireguard
Heat guard
Thermoskin
Thermal Skin
Thermal-ation
Coolskin
LateNight72
07-22-2009, 01:51 PM
Organic Burn
Natural Heat
Organic Shield
ThermoBlock
DJW32
07-22-2009, 01:55 PM
2000* T.I.M( thermal insulation material)
MAT 2000
second skin 2000
I went with 2000 degree because people will think it works up to 2000 degrees.
Kustom_dude
07-22-2009, 02:29 PM
Damplifier Vertex - Means highest Point.
How about Sound barrier names like
Subsonic - Sound barrier
Transonic - Sound barrier
Hypersonic - Sound barrier
Or Something like Mach 1 2. 3. for something like Mach 1 Pro, Mach 2 Elite and so on for future apps.
GMachineDartGT
07-22-2009, 02:40 PM
Heat Stop
Extreme Shield
Heat Saver
Heat Block
Pyro Guard
Cool Skin
bl1tzw1ng
07-22-2009, 02:42 PM
I say Imprint. Not a name like any other similar product out there, everyone will know what product is being talked about, and it has dimples.
69TAPoser
07-22-2009, 02:52 PM
ShieldSkin
ExtremeSkin
69TAPoser
07-22-2009, 02:53 PM
UltraSkin
WildSkin
UltimateSkin
69TAPoser
07-22-2009, 02:55 PM
MaxSkin
clevorguy
07-22-2009, 03:15 PM
Second Skin SPF1000+
Dave 70
clean armour,
Daves super stuff
Neutral heat skinz
Natural heat skinz
TA219
07-22-2009, 03:40 PM
Heat-Sync 1000
Heat Handler
Heat-Handler 1k
Cool-Mat
venturabeachpup
07-22-2009, 04:00 PM
Thermal K
or
K Shield
"K" Being 1000 in roman numerals....
protour_chevelle
07-22-2009, 04:05 PM
proxi-barrier..... as in close proximity heat source barrier.
minendrews68
07-22-2009, 04:07 PM
How about..
Heat Blocker Ultimate
Heat Barrier
Best Yet
Flame Out
Comfort Level +
Heat Away Plus
Heat Liner pro
Deat Heat
Kill Heat Pro
Ok one other has already come up with "heat block" (just went back and looked at all of them) don't want to copy, but I think I'll leave it in because it's different.
zbugger
07-22-2009, 04:49 PM
Keeping in line with your product line, maybe something like "Heat Wave Ultra"?
Mark68
07-22-2009, 05:21 PM
Here's some "COOL" names:
Cool-Touch 1000
Cool-Touch Mat
Heat-Be-Gone
Thermal Blocker
No Burn 1000
No Burn Mat
Steve1968LS2
07-22-2009, 05:40 PM
I would add PYROTECT to my previous suggestion :)
After all, it's protecting from heat.
:shrug:
GeoffP
07-22-2009, 05:56 PM
How about ThermalTect?
LateNight72
07-22-2009, 05:57 PM
Heat Defeat
Heat Delete
nicks67camaro
07-22-2009, 06:02 PM
Reactor Sheild
Dragon Skin
Second Wall
Firewall Wrap
Heat Tamer
Second Barrier
Temperature Tamer
Temperature Tamer Firewall Wrap
Second Barrier Firewall Wrap
(slim pickins in the "not taken" department, alot of good ones guys!)
narcotix
07-22-2009, 08:14 PM
MilMat
MultiMil
Just a play on the multi-layer 12 "mil" thickness AND the 1000 degree ("mil" in espanol) properties.
It'd be easy for folks to say in a shop environment. "Hey, order me up a few sheets of MilMat for that Eldorado over there..."
TonyL
07-23-2009, 12:38 AM
PRO-Tect (or Pro-tech)
Insuliner
Insumat
Temprobarrier
Thermulayer
Thermushield
Temperashield
Insu-shield
Serpa69
07-23-2009, 03:02 AM
Ballistic Mat
k7king
07-23-2009, 03:33 AM
cool mat
Teamwild
07-23-2009, 04:57 AM
Lets see, how about,
Outer Skin
Heat Slasher or just
Slasher
Thermal Soaker
btw the Damplifier works great!
Jim Nilsen
07-23-2009, 05:08 AM
Heat Safe , keep your heat locked up or locked out where it belongs
Or as Billy Mays would probably say " Locks the heat in ,Locks the heat out. Don't get burned by other products get HEAT SAFE today!!!!!
Radlark
07-23-2009, 06:09 AM
ProBlock- Thermal heat reducer!
jy211
07-23-2009, 06:23 AM
cold skin
cold compress
cool skin
cool compress
burn control
burn degree control
No heat shock
heat shocker
burn blocker
cool ice
Allograft
epidermis
second skin graft
67 caprice
07-23-2009, 07:04 AM
Hot Skin
Hotskin
Super Hot Skin
Thermal Skin
Cool Skin
Temp Skin
Buick Motorsports
07-23-2009, 08:12 AM
Scorch Halt
Heat Halt
Cease Fire
ThermAll
cypher
07-23-2009, 09:23 AM
thermal shield ; thermal skin ; 2nd barrier
venturabeachpup
07-23-2009, 11:56 AM
Reactor Sheild
Dragon Skin
"Dragon Skin" :1st:
My favorite. You got my vote nick67.
Taylor1969
07-23-2009, 12:26 PM
To keep with current naming conventions...
Firewall Alpha
Firewall Pro
HeatSeal
Coolifier Pro
FireBreak
FireKill
FireSeal
HeatSeal
Buick Motorsports
07-23-2009, 01:00 PM
Nuclear Skin
Krazed
07-23-2009, 01:59 PM
360 Skin
(Reduces 1000f at 2" or more to 350ish (360) degrees)
360 Skin, your All around heat treatment.
nicks67camaro
07-23-2009, 02:00 PM
"Dragon Skin" :1st:
Ha! thanks for the vote!
megaladon6
07-23-2009, 03:29 PM
Phoenix skin/liner
nowukno
07-23-2009, 04:24 PM
Volcano Wrap
Solar foil
back fire
atmosphere
Blkcamaro80
07-23-2009, 05:20 PM
Hell's Blanket
Devilskin
Demonskin
I know kinda dark, but I thought they sounded catchy
Second Skin Rep
07-23-2009, 05:37 PM
Tons to choose from!
I posted this offer on 6 or 7 sites so far. Man. I probably have about 1000 replies to go through
ANT
nowukno
07-23-2009, 06:28 PM
skinmosphere
minendrews68
07-23-2009, 06:40 PM
Man what a turn out. How about "BACKDRAFT" thermo insulating mat.?
Smitty_67
07-23-2009, 06:51 PM
Pyro-stop 1000
Heat Extreme Pyromat
pchdrive
07-23-2009, 06:54 PM
Gila Mat
Sonoran Mat
shmoov69
07-23-2009, 08:00 PM
Engine Blanket
Thermal Stop
Combustion Blanket
Combustion Liner
F.A.R.T. Sheild - Fight Against Radiant Temperatures Sheild!
Thank you, thank you very much! I'll be here all night!!
ANT
Free stuff will definitely do that...
Nessumsar
07-23-2009, 09:07 PM
IcyHot
Heat Blanket
Cold Heat
Antihot
Bodyguard
DaveO
07-23-2009, 09:33 PM
ULTI Mat
ULTI Mat-K
ULTI Mat Pro
:enguard:
MCMLXIX
07-24-2009, 01:53 AM
foreskin
megaladon6
07-24-2009, 03:56 AM
:rotfl:
pchdrive
07-24-2009, 04:44 AM
Baja mat
Mohave mat
novanutcase
07-24-2009, 12:14 PM
FIREMAN
John
eville
07-24-2009, 02:39 PM
PYRO Max Extreme
PYRO Max +P
CHILI442
07-26-2009, 12:31 PM
I think it's been posted already, but I like Therma-Shield.
25 lbs per sq/ft? Wow!
Second Skin Rep
08-05-2009, 05:28 PM
ah.. THat was a mistake
.25 lbs psf
ANT
BIGX69
08-05-2009, 05:38 PM
THERMA PRO:idea:
T-CHRGD
08-07-2009, 12:31 PM
Hell's Blanket
Devilskin
Demonskin
You think like me, my first thought :
SatanSkin
Think of the marketing options !
Yoda4561
08-12-2009, 05:01 AM
Hmmm... let's try,
Vulcan Armor
IceLiner
FrostLiner
Chill Blanket
Second Skin Rep
08-13-2009, 01:53 PM
Just an update
The product should be ready to sell in about 3 weeks.
Still looking at all the forums trying to get the best name..
ANT
shmoov69
08-13-2009, 01:57 PM
I don't know if it has been said or not, but how bout "BLIZZARD-SKIN"
T-CHRGD
08-14-2009, 02:28 PM
Didn't see this simple one (read thru twice)
FireLiner
:idea:
Tom Welch
08-14-2009, 07:45 PM
reactor wall liner
Thumpin'66
08-18-2009, 09:48 PM
Blockade
Pyro Shield
Barricade
Iamtheonlyreal1
08-18-2009, 10:10 PM
Its Late in the evening, but here it goes...
Magna Barrier
Blaze Barrier
Buffer Zone
Heat Extinguisher
Heat Away
Heat Stopper
Heat Attack
Heat Defeater
Heat Dominator
Thermal Annilation
Thermal Back Up
Thermal Attack
Thermal Defeater
Total Thermal Domination
Total Thermal Attack
Total Thermal Annilation
shmoov69
08-19-2009, 03:22 AM
Blaze barrier and heat extinguisher sound the "catchiest" to me.
cheapthrillz
08-19-2009, 07:25 AM
Dimpled Dissipator
The Ultimate Dissipator
Diffuse-ALL
Dissipate-ALL
Disseminator
70 Chevelle
08-19-2009, 04:10 PM
F block
Badley
08-19-2009, 05:44 PM
How about LAVA LINER. Kinda keeps it inline with your other products. And gives the idea of super high heat.
Taylor1969
10-31-2009, 06:45 PM
did you ever post who won?
Tom Welch
10-31-2009, 07:02 PM
flame trap
Yoda4561
10-31-2009, 07:11 PM
Haven't seen any news on their forums, I'm assuming they're still looking for/trying to pick one.
kerryt1
11-02-2009, 09:56 AM
ThermaBarrier
AustinClassic
11-05-2009, 12:32 PM
Dragons Breath
damannhw
11-05-2009, 01:40 PM
OK, Here are my additions with alot of S's :
Swelter Shield
Sizzle Shield
Second Shield
Second Sheath
Scorch Shield
Nessumsar
11-05-2009, 04:53 PM
Cool Aid
Shinny Stuff
michael6372
11-05-2009, 06:15 PM
Flame Tamer.
Ice.
Farenheit.
Frost Bite.
Fire Foil.
BTU Buster.
Quench.
Second Skin Rep
11-06-2009, 04:51 PM
Wow..
Tons of suggestions..
This name thing is taking forever though.
We had to send back the first batch of material which was made wrong.
Might be a couple more weeks before it comes in..
Keep posting!
ANT
mc84_zz4
11-06-2009, 09:15 PM
Reactor Sheild
Dragon Skin
"Dragon Skin" :1st:
I vote for Dragon Skin too.
Some more to consider, may or may not be on the 5 pages, please pardon if dup:
- Armor Skin
- Lava Skin
- Pyro Freeze
- Pyro Skin
- Pyro Trap
- Heat Stop
- Hell Freeze
jy211
11-10-2009, 05:06 AM
the company is very slow in responding to emails for sure...
Taylor1969
11-10-2009, 05:20 AM
I still like some of my suggestions...
:idea:
Firewall Pro
HeatSeal
Coolifier Pro
FireBreak
FireKill
FireSeal
Second Skin Rep
11-23-2009, 07:20 PM
Thanks for the suggestions guy!
The product arrived today and it looks good.
I am going to spend the next couple days looking over the suggestions on this and the other 10 forums we put the contest up on.
Stay tuned!
ANT
Nilater
11-23-2009, 08:47 PM
Cool Running ThermaShield
Second Skin Rep
03-18-2010, 08:32 PM
A while ago we had a contest, to help name our newest thermal mat.
Well, it toook about a year, and we never chose a name.
Right now, the name is generically called Thermal Block.
You can see it on the Second Skin sound deadening website here:
http://www.secondskinaudio.com/viewproduct.php?id_product=355
Since we never selected a winner, we decided to give away a bunch of free product to the members of the Pro-touring forum.
Up for grabs is 10 sheets of our thermal insualtion mat, Thermal Block.
Thermal Block is the best thermal barrier we offer.
This self adhesive mat is designed to face the heat source directly to reflect and dissipate heat. Lets say your headers get up to 1000 degrees f.
When applied on the engine side of the firewall, with just 2 inches of airspace between the headers and the Thermal Block, the opposite side of the thermal block will measure only 300 degrees f.
When subjected to 300 degrees f. the opposite side will measure in around 90 degrees f.
It is self adhesive, and looks awesome!
Each sheet on our site is $80, plus shipping.
For this promotion we are giving away 10 sheets FREE, all we ask of the winners is that they pay shipping charges.
If you are interested here are the rules
1. Must have a post count of 25 on the pro-touring forum-
2. Must be a Pro-touring forum member for minimum of 3 months
3. Must install all of the products we provide
4. Must install the products within 6 weeks of getting them
5. Must take a minimum of 8 pictures of the installation, and post a build log on this forum, plus one other automotive related website within 2 weeks of installing the products.
6. Cannot sell these products or use them in more than 1 car, the car that you own
7. Must have a US shipping address and agree to pay for shipping charges
8. Must contact us within 72 hours of the contests end if you are selected as a winner
If you agree and qualify to these terms, please post the following information in this thread:
1. Post your user name
2. State that you qualify to the terms and agree to follow through with them as they are written above.
3. Post a description of your car
4. If you plan on helping promote Second Skin, please including the other web site you will post your build log in.
5. You must tell us something about yourself that nobody on this forum knows about you
We will select the winners next week
Thank you everyone for your attention and participation
ANT
shmoov69
03-19-2010, 08:37 PM
1.Jimmy Spears
2. Yes
3. 69 camaro & 58 Nomad
4. Probably the HAMB or 417racing.com
5. My sons b-day was last Tuesday (1 year old!)
oh, and I love the other stuff of yours that I put in the Nomad a year or two ago!! But most everyone on here already knows that!
sunkistcamaro
03-19-2010, 08:38 PM
1. William Rice
2. Yes
3. 69 Camaro, LS1 build thread started. New floors going in sooner than later if I win. :)
4. Lateral-g, camaros.net & Chevytalk.com
5. Im finishing up my Mechanical Engineering degree this summer.
I secretly like Mustangs:guilty:
To add a little more icing on the cake I will also buy 40 sq.ft of your Damplifier for inside of my car!
1badchevelle
03-19-2010, 09:16 PM
1badchevelle (Fabian Sanchez)
I qualify and agree to terms
building a 71 chevelle
ls1tech.com & teamchevelle.com
I lived in my car at age 19 (69 camaro)sold the car to buy food and to put a roof over my head.
Topless69
03-20-2010, 04:46 AM
someone beat me to it. dragon skin
DRAGON HIDE
PHOENIX SKIN OR HIDE - "PHOENIX DIES IN A BURST OF FLAME AND IS REBORN FROM THE ASHES"
pimtina
03-20-2010, 10:56 AM
I agree to the terms! User name: pimtina aka Ron Brenton
My project is a '66 Ford Cortina. I just finished the firewall setback, floor and tranny tunnel mods for my 5.0 and T-5 swap. It is the perfect time to be installing some of your products! I'll be ordering some Spectum too!
Nobody on this site knows I'm an avid fan of punk rock music!
I'll post up some pics on The Corral.Net and I belong to several Cortina and English Ford sites where I have build threads currently. Thanks! Hope I'm a winner!!
Thumpin'66
03-20-2010, 12:57 PM
1. Username - Russ85MCSS
2. I qualify to the terms and agree to follow through with them as they are written above.
3. My car is a 1966 Chevelle SS that is now on my hoist in primer and ready for floor treatment so timing is perfect for pics and quick install.
4. I frequent MCSS.COM as a moderator and Team Chevelle as a member.
5. I have 3 daughters, 2 dogs and chickens to feed. The wife is less understanding lately of me spending money on the 66 so free product is way cool!
I am an automotive parts sales rep and can't help but brag about products that impress me.
Russ
How would this product work on an interior floor install? Is it for reflective heat only?
For a name, how about "Shuttle Mat"? Tag line could be, "Prepare your project for re-entry".
RatMalibu
03-20-2010, 02:33 PM
1. RatMalibu
2. I qualify for the terms and agree to follow through with them as they are written above.
3. 1980 Malibu BBC/T-56
4. I'm a mod at maliburacing.com so I'll say there
5. I have a mole on my......er wait, I'm a Chevy guy but secretly want a new Challenger SRT/8 ;)
jski67
03-20-2010, 03:36 PM
1. jski67
3. 1967 Camaro, fresh from paint, 489 BBC with efi, T-56, minitubbed. I already plan on using damplifier pro and Luxury liner...I was thinking this new product would be good on the inside firewall?
https://www.pro-touring.com/forum/showthread.php?t=65290&highlight=prodigy
4. Lateral G, Team Camaro, Chevy Talk, Tallahassee Muscle Car Association
5. I love guitars as much as I love cars...
shmoov69
03-24-2010, 07:49 PM
So, is there any benifits to inside the car or outside the car to prevent the heat? I was curious to know before I put the exhaust back in the camaro.
So, any winners yet? ; )
Taylor1969
03-25-2010, 07:05 AM
1. Chris Taylor
2. Yes
3. 69 camaro RS
4. Ls2.com and camaros.net
5. I need it! Car is painted, driving, and just needs interior
John Wright
03-25-2010, 08:02 AM
Let me ask this.....What do you think about using a small piece of this as a heat shield for the back of your hand/glove while welding? There is a product available that some of my guys use already, but was wondering if this might be better.
nicks67camaro
03-25-2010, 08:05 AM
Dragon Skin
I already have my second skin products (Damplifier and overkill) on my car so I can't do the write up / giveaway eligibility but you can use my suggestion if you like.
sunkistcamaro
03-25-2010, 06:20 PM
John,
I have to ask, what the are you welding in this pic?
John Wright
03-26-2010, 03:14 AM
John,
I have to ask, what the are you welding in this pic?That's not me or anyone from our shop(pic stolen from the griffin web site)...we fabricate structural steel for mid to high rise buildings and with a few pedestrian bridges thrown into the mix.
Here's our type of work with my guys in action working on a column:
https://static1.pt-content.com/images/pt/2010/03/Dsc00010-1.jpg
https://static1.pt-content.com/images/pt/2010/03/Dsc00008-1.jpg
These were columns for the Giant's stadium(@ Meadowlands) in NJ.
shmoov69
03-29-2010, 11:47 AM
?? Anything??
SicMonte
03-29-2010, 12:11 PM
1. SicMonte
2. I qualify to the terms and agree to follow through with them as they are written.
3. 1988 Monte Carlo SS...built for road racing.
4. www.montecarloss.com (http://www.montecarloss.com) username: Sicmonte
www.svtperformance.com (http://www.svtperformance.com) username: I.wish (g/f has a 04 cobra)
5. I secretly like techno and dance music...no one judge me!!!
Second Skin Rep
03-30-2010, 03:20 PM
From the look of it, that might be a silicone/teflon glove.
Those are insine for heat reduction!! Expensive material to use in a car though. I would opt for that if I could get some!
ANT
shmoov69
03-30-2010, 05:30 PM
So, any wieners yet?
Second Skin Rep
04-11-2010, 10:40 AM
Thanks for everything guys
Here is the list of the winners:
shmoov69
sunkistcamaro
1badchevelle
Buick Motorsports
Krazed
Russ85MCSS
RatMalibu
jski67
Taylor1969
nicks67camaro
SicMonte
Blkcamaro80
If your user name is on the list, please send me an email
[email protected]
The subject/title of the email needs to be ProT winner
In the body of the email put:
User name
Real name
Shipping Address
Once we get the, we will send you a coupon code to use at our site.
The code will only be good for 2 weeks.
We will need to get your email within 10 days from now. Once 10 days has passed, the offer will expire.
Thanks for your attention!
ANT
pimtina
04-11-2010, 01:29 PM
Sorry in advance for whining like a little bitch, but..... Everyone who signed up plus 3 who didn't sign up win. Everyone but me that is.
I know it was a contest and I know that there are winners and losers in every contest, just kinda sad that the loser was me.
shmoov69
04-11-2010, 06:30 PM
Awesome! You got mail!
Thumpin'66
04-12-2010, 05:10 AM
Sweet! I can't believe I won something! I can't wait to try this product and see how well it works.
You've got mail.
nicks67camaro
04-12-2010, 05:23 AM
Awesome you got mail!
Taylor1969
04-12-2010, 01:11 PM
Woot!
SicMonte
04-21-2010, 05:17 PM
ah...I just saw that I was chosen...email is on the way!!!!
Second Skin Rep
04-29-2010, 01:37 PM
Did you guys all get your material in yet?
ANT
nicks67camaro
04-29-2010, 01:57 PM
I did, havn't had a chance to install it yet. Looks really nice!
Thanks Again
shmoov69
04-29-2010, 05:29 PM
Yes, sorry I hadn't posted it yet, but I had not had a chance to do anything with it. It looks mean for sure! I've already told a dude on the HAMB to call you for a turbo that is in an A, and under the dash!
Thumpin'66
04-30-2010, 05:16 AM
Got it and took a look at it but have had no time to mess with the car since it arrived. I am also debating on if I should use it on the firewall or under the car above the x pipe or mufflers.
sunkistcamaro
06-04-2010, 08:06 PM
Has anyone installed this yet?
shmoov69
06-07-2010, 05:45 PM
It's still sitting by my kitchen right now.....sorry but I'm trying to decide where to put it and in which car to get the most benifet from it. On the 69 it needs to be everywhere, and the 58 I'm just not sure where it would be noticed the most.
I WILL let y'all know tho!
Thumpin'66
10-24-2010, 05:22 AM
I am just finishing the underside of my car to drop it back on the frame and am wondering if this mat will stick to a semi rough surface like Lizard skin? I am shooting a coat of wurth underbody seal on top of the Lizard Skin that should smooth it a bit. Spraying the Wurth coating over the mat wouldn't work, would it?
Second Skin Rep
10-24-2010, 09:34 AM
Lizard skin is a water based coating, so if you are going to apply a sound deadening mat like Damplifier Pro on top of it, you should make sure that the coating is cured first. Otherwise, you run the risk of trapping water in the Lizard skin, and promoting rust. Not something you want in a car!
The best way to do it is by applying the Damplifier Pro first, then a noise barrier like our Luxury Liner Pro on top of that. The coatings, like Lizard skin or our Spectrum coatings are best used on the underside of the vehicle (which it sounds like you are doing) no real reason to use Damplifier Pro under tre car.
Hope that helps!
KEN
SicMonte
10-25-2010, 10:49 AM
I messed up. I totally didnt use the coupon. Im not gonna lie...I forgot I even had the chance to use it. I appologize that I took this for granted.
