View Full Version : gutting my proportion valve
ls173camaro
07-19-2009, 08:59 PM
I have an 81 camaro. What do I need to do to gut it so i can use mt adjustable one line. Thanks Bill
07-19-2009, 09:06 PM
The rear end where the line goes to the rear brakes has a nut, remove the nut and pull out the spring and plunger, reassemble and put the adjustable prop valve in the rear line. If it's more convenient, put the new prop valve between master cyl and old combination valve. It will work and usually doesn't make the brake warning light come on, but it might.
David
Skip Fix
07-20-2009, 02:55 PM
Another option is putting a T in the front lines and the adjustable in the rear.
