View Full Version : would 245/40/18 be enough?
69projectKAOS
07-17-2009, 08:47 PM
how would the sidewall look on a 245/40/18 ?? would it look good on a 69 camaro, ?
ProdigyCustoms
07-17-2009, 08:52 PM
Perfect, that is the front tire we run on factory subframe cars on a 8" rim
69projectKAOS
07-17-2009, 09:11 PM
what is a good rim width to run front and back with stock subframe and wheel wells??
b-man
07-17-2009, 09:17 PM
245/40-18 on a 9" wide wheel.
https://static1.pt-content.com/images/pt/2009/07/OZRacingBlackpaintedwheelsfor64Temp-1.jpg
https://static1.pt-content.com/images/pt/2008/12/OZRacingBlackpaintedwheelsfor64T2-1.jpg
69projectKAOS
07-17-2009, 09:20 PM
im looking at two wheel packages right now and one is 9.5'' wide and the other is 9'' wide, and thats on all 4 tires, would that work??
class67
07-17-2009, 09:27 PM
You lost me...are you asking if a 245/40/18 will work on a 9 or 9.5 rim? I would say no, not only from a safety standpoint but it would not look good either.
class67
07-17-2009, 09:31 PM
Here's a 245/40/18 on an 8" rim
https://static1.pt-content.com/images/pt/2009/07/PICT0035-1.jpg
ProdigyCustoms
07-17-2009, 09:46 PM
The 9 and 9.5 are both to big. 8, 8.5 at the most. backspace will be critical.
I would run the rear at 9.5 with 275s
What wheels?
69projectKAOS
the wheel and tire package is an 18" rim and it says the front and rear tires are 245/40/18. what is a safe width to run front and back with stock subframe and wheel wells??
69projectKAOS
07-17-2009, 09:52 PM
i don`t even know what the brand was, i just had the link and now i cant find it, so i should go with a 8" rim in front and 9" or 9.5" rim in the rear ? and what are good size tires for both? i dont like when the front tire sidewall height is smaller than the rear, i like when the sidewall height is almost the same front and back
b-man
07-17-2009, 09:55 PM
You lost me...are you asking if a 245/40/18 will work on a 9 or 9.5 rim? I would say no, not only from a safety standpoint but it would not look good either.The recommended rim width for the 245/40-18 is 8" to 9.5".
A 245/40-18 is unsafe on a 9 or 9.5" wheel? That's simply untrue. Using the widest recommended rim width is the ideal way to run low-profile tires for best handling and response.
If you can't fit a wider wheel than 8" on the front of your car then you'll have settle for that, but a wider wheel would always be better for handling.
If you think it won't look good, then that's just your opinion.
I'm also running 275/40-18s on the same 9" wide wheel, a compromise because I can't fit a wider wheel on the back of my car. The recommended rim width for that size is 9" to 11", I'd much rather be running the 275/40-18 on a 10" or 11" wheel.
class67
07-18-2009, 07:06 AM
Dude.....take a pill and calm down, I know all that you are saying is true but that IS my opinion. There is no need to attack me for it.
b-man
07-18-2009, 08:32 AM
Dude, you're the one that needs to calm down.
I didn't attack you, I just pointed out that your statement about the wider rims being unsafe for that tire size was untrue. If you think that was an attack on you then maybe you're the one who needs a pill here.
You passed on some bad info and I pointed that out rather than just let your statement stand. Sometimes when you post something on the forums you'll find that someone disagrees with you.
69projectKAOS
07-18-2009, 09:39 AM
guys please, i dont want anyone to argue, im probably going to run 8.5" in the front and 9.5" in the rear! would that work? and what tires would look good? thanks-dom
b-man
07-18-2009, 09:55 AM
Dom,
You can run that 245/40-18 on either one of those rim sizes and it would work just fine.
Tire choice is up to you, only you can decide which brand looks best to you. Check out the various tires in that size on the Tire Rack website, they show some pretty good detail pictures of the tread and sidewall.
Bart
69projectKAOS
07-18-2009, 08:27 PM
thanks b-man , i really appreciate everyones input! thanks again-dom
