View Full Version : Header Suggestions
Riderz Cycle
07-07-2009, 01:07 PM
Engine is close to being completed and still have a few things I need ...So this is what I got and any suggestions would be great.
SBC 400 going into 69 Camaro with 700R4 trans should be around 525-550HP soon will see on the dyno. Not sure of the exhaust and header set up I want or should use. I assume a good stepped header but what size to start with 1 5/8 and how about exhaust 2.5 oe 3 inch what brand headers, again suggestions welcome
WS6
07-07-2009, 03:39 PM
What heads are on the engine? What is your power band going to look like? For an all around street driven car with a broad power band, I'd go just simple 1-3/4" primaries into a 3in collector. I wouldn't worry about stepped but I don't build high RPM engines. dual 2.5" with an x would work well for the exhaust too.
Riderz Cycle
07-09-2009, 08:28 AM
Thanks that is what I was looking for...Have Dart Iron eagle heads should be a good running street car...
WS6
07-09-2009, 06:04 PM
1-3/4" primaries will be fine. I've just finished a C5 that's heads/cam/magnacharger. It should be around 500 hp at the wheels. The last combination minus heads was at 460. 1-3/4" primary headers are whats on the car now and what was on the car when making 460 rwhp.
Pro Stock
07-09-2009, 11:13 PM
Stahl headers are great, his stuff is pricey but not as high as Kook's. I would talk to Jere Stahl (pronounced Jerry) about your combo and let him make some recommendations. If it was my car I would probably go with 1 3/4" primary and a 3" merge collector. This is just a guess because of the lack of information.
Dale
Riderz Cycle
07-10-2009, 07:11 AM
Thanks guys sounds like 1 3/4 primaries with 2.5 exhaust with X pipe should work great for a street car..I just want to use good parts and not have to do the job twice....Sorry for not including all the engine specs don't have everything here at work but I thank you guys fo the input...
Badley
07-11-2009, 02:57 PM
I used DynaTech headers in my 68. They fit perfect. They step up from 1 3/4 to 1 7/8.
NvrDun71
08-16-2009, 10:10 AM
Have any pics? No clearance issues at all? Are you running an auto or manual trans?
