BigBlockOlds
07-03-2009, 03:10 PM
Anyone else have an issue with clearance between your LS1 rear brakes and notched frame on a G-body?
I had to cut apart my watts link to redesign how it attaches just so that it would clear the bleeder screws. Stinks when you find a clearance issue AFTER you've already had it powder coated. :(
So I managed to get the watts link to clear, but if I jack the rear end up to my desired ride height (see picture below), it end up with the bleeder screws almost hitting the frame during suspension travel. I probably have a 1/4"-1/2" clearance between them and the face of the frame.
https://static1.pt-content.com/images/pt/2009/07/IMG_1321-1.jpg
Being that the watts link isn't supposed to let the rear end move much at all side to side, I'm not too worried about that. My concern is how the brakes react when you step on the peddle. With brand new pads, I imagine the caliper won't move much at all but with worn pads, I'm worried its going to hit.
Anyone know how much a typical disc caliper will move when applying the brakes?
Thanks for the help,
*EDIT* Upon further inspection, I don't have the 1/4"-1/2" clearance I thought. Its more like nothing at all. It appears that the actual bleeder screw is missing the frame but the rubber cap is just barely kissing it. I guess my only option is to install a bump stop between the rearend axle tube and frame somehow.
