View Full Version : thirdgen power steering on 1st gen
zboss86
03-25-2005, 02:11 PM
"I recommend going the simple stupid route. get a fast ratio gearbox from a second or third gen f-body. Quick ratio steering arm from Rick's First Generation or similar supplier, (they have the correct arm). This is a direct bolt on proven system for improving your steering. " - Tom Welch
https://www.pro-touring.com/forum/showthread.php?t=2889&referrerid=677
Is this really a direct bolt in for a first gen? Has anybody done it?
I just happen to have a complete power steering set up from an 86 model IROC laying in the corner of the shop from an older project.
Shad
BA.
03-25-2005, 02:34 PM
From what I've read here and at other places it's most definitely true. I believe you just have to plan/prepare for proper hose connections. I expect our original is standard and maybe the 3rd gen is metric?? Either way, I'm pretty sure leepowersteering.com has any extra parts needed. He's referenced frequently here.
TitoJones
03-25-2005, 06:41 PM
BA Barackus (A-Team reference) is correct. The differnece in fittings is the 3rd gen box uses an O-ring, and the 1st gen uses a flare type.
Tyler
03-25-2005, 07:19 PM
The input shaft spline is smaller so you need a later model coupler. I have the part number for it on my web page:
http://www.pozziracing.com/first_gen_suspension.htm
gmachinz
03-25-2005, 09:33 PM
Be careful when ordering headers for it though. The cheapies seem to be awefully tight-unless you like to pre-heat your ps fluid. :scared: If there is a footnote for it-make sure to include that it is a ps car when requesting headers. -Jabin
rocketrod
03-26-2005, 01:46 AM
This is a link to all of the information concerning this swap.
http://69camaro.nextmill.net/steering.html
zboss86
03-26-2005, 04:52 PM
thanks guys
Tom Welch
03-26-2005, 06:13 PM
I have done the swap with a 2nd gen fast ratio box and it fit with no unusual problems or hitches at all. If you need a steering box look at A1Cardone reman boxes, they sell the fast ratio box for first thru third gen f-bodies. I know that Lee makes excellent parts but I believe that A1Cardone makes a less expensive version. Napa also has the boxes.
zboss86
06-07-2009, 07:38 PM
I just happen to have a power steering box off my old 86 IROC Z. Back in the day I swapped to a manual to loose weight.
I wonder how well the power steering box will work with all my manual linkages...
texasdvldog
06-08-2009, 02:37 PM
Good info in that link! :1st:
