View Full Version : Fesler And Baer Brakes Team Up For The 2010 Camaros
Fesler built
06-24-2009, 03:48 PM
We just got one of our cars back from Baer with the new Fesler 6 Piston front and rear brakes on it. We are working on a few different models of brakes but to start with we have 15-inch rotors front and rear with 6 piston calipers and they clear the factory wheels.
Check out the link
http://www.baer.com/announcements/20090620/index.php
This car is supercharged, lowered on adj coil overs and the new Fesler Brakes, body kit and wheels will be on very soon, along with the new Fesler SS exhaust system from Billy Boat. We have teamed up with some of the best names in the buisness to build the cars right. Will post up more shots as we get farther along.
BADNBLK
06-25-2009, 08:57 AM
Looks great Chris! Who would have thought 15" rotors clearing factory wheels would ever happen? Can't wait to see the rest of the kit come together :1st:
LateNight72
06-25-2009, 09:12 AM
Factory Wheels = 20's.
andrewb70
06-25-2009, 09:44 AM
Bigger must be better...
BADNBLK
06-25-2009, 09:58 AM
Understand. Many factory wheels even though they have the diameter to clear, wont have the caliper clearance at the spokes for a 15" diameter rotor and a 6 piston caliper. Just nice to see factory wheels planned out with caliper clearance enough to be able to upgrade a whole inch in rotor diameter and add two caliper pistons.
JEFFTATE
06-25-2009, 12:39 PM
Wow , that's huge !!
Damn True
06-25-2009, 12:44 PM
The car looks really nice at that height.
What happens though, to the ABS system when you change significant bits such as calipers and rotors and alter by means of changing springs the rate of weight transfer under braking?
BADNBLK
06-25-2009, 02:45 PM
The brake rotor should not change the wheel speed sensor mounting or operation. As long as the pulse ring is still the same size should work? I don't think ride height would effect anything either unless tire size was changed, and it effected overall rolling diameter.
YancyJohns
06-26-2009, 06:53 AM
Those Baer brakes look great. Which Fessler wheel design are you going with?
