View Full Version : What is the compression ratio??
WELTERRACER
03-24-2005, 02:27 PM
PROTC (a memeber on this site) has a 396 BBC bored to a 408 or .060 over!
It has the .550 dome forged pistons.. Supposed to yeild 11-1 compression with closed chambered heads.. (but he has open chamber heads)
anyone know what the compression is??
rkcuda
03-24-2005, 07:47 PM
You would have to know the CC of the heads and how far in the hole the pistons are to be sure.
True compression ratios for some pistons turn out to be significantly lower than advertisied.
But
As a reference... switching from open chamber to closed chamber heads on my BB mopar yeilded about 1 full point of compression increase.
So in your case, a rough guess? 10.1 compression.
Rob
rkcuda
03-24-2005, 07:55 PM
Do a search for compression ratio calculators.
Here is an example http://www.csgnetwork.com/compcalc.html
chicane67
03-24-2005, 08:41 PM
Displacement= Bore x bore x Stroke x 0.7854 x 8
Compression ratio= (D + PV + DC + G + CC) / (PV + DC + G + CC)
D= Displacement
PV= Piston volume
DC= Deck clearance volume
G= Gasket volume
CC= Combustion chamber volume
ProdigyCustoms
03-25-2005, 02:48 AM
Brian, pull a valve cover and get me the casting number for the head and a date would be nice too. Then see if it still has the original engine code stamped in the pad on the block in front of the right head. Just write down whatever you find. I should be able to get you darn close.
