jaybee
06-15-2009, 08:39 AM
"Because it was laying around" is a poor reason to choose any particular material or part for use, but...
I'm in possession of some used semi-trailer floor crossmembers, cut out due to damage on the ends so they're at or nearly 102" long. They are fabricated I beams made from material that's roughly the thickness of an automobile frame, 2" top and bottom plates, 4" tall.
Can this material be used to construct crossmembers and X-members sufficient to beef up a chassis for street performance? They're plenty strong enough to carry loaded forklifts, but I wonder how much torsional rigidity is lost, and if proper design can help compensate.
I know it'll work for my other potential use, which is to set it across the base webs of multiple roof trusses in the garage to spread lifting loads across the width of the ceiling. Kind of like a poor man's overhead crane.
