View Full Version : digi-tails help
blackwidow
06-13-2009, 02:25 PM
can someone post wiring diagram for digi-tails for 69 camaro, i can`t find mine. turns are not working. have the led flashers help mike
MuscleRodz
06-13-2009, 03:22 PM
pm me you email and I will foward you a copy
blackwidow
06-13-2009, 06:04 PM
thanks. but i found them. may be you can help me out. everything works but the turns and emergency flashers. had the hd flashers in that came with the new harness, they lit but did not flash at all. so i put in electronic led flasher (EF32RL 2p 12V LED FLASHER) with grounds, now nothing lights. was gett`in mad so i stoped working on it.going to go over all the grounds sunday, do you have any idea that might help mike
MuscleRodz
06-13-2009, 09:22 PM
Did you get a good ground on the flasher pigtails?
blackwidow
06-14-2009, 04:27 AM
going to go over all the grounds today, but the only thing that bugs me is that when the other flashers were in that they just stayed lit, i think i seen others where they blinked real fast. after a bowl of cap`n crunch going back out to go over grounds mike
MuscleRodz
06-14-2009, 10:31 AM
going to go over all the grounds today, but the only thing that bugs me is that when the other flashers were in that they just stayed lit, i think i seen others where they blinked real fast. after a bowl of cap`n crunch going back out to go over grounds mikeThey just stay lit because the flasher does not reconize the LED's at all and they light up. The mechanical flasher allows voltage to pass through and light them up, but their is no amperage load to activate the flasher so they stay on. With electronic no load flashers, they operate off voltage. As soon as they seen voltage, they begin to flash, but they have to be grounded to complete the circuit.
blackwidow
06-14-2009, 11:16 AM
well mike nothing.clean metal the new connectors with shrink tube. do you think its the new flashers, they say led flasher but don`t have no load on them. this is what they have on the flasher(electronic- ef-32rl 2p 12v led flasher. this is frustrating. thanks for helping, my friends have no clue on wiring. mike
MuscleRodz
06-14-2009, 09:20 PM
Call me tommorrow late morning early afternoon and I will go over everything on the phone with you
blackwidow
06-16-2009, 08:11 AM
got it. the wiring harness was wrong, they must have put the wires in the wrong way. thats why the one`s that came with it just stayed lit and the electronic one`s would not work at all. just did not think the harness was wrong. but have turns now mike
