View Full Version : My LS7 67 camaro build with all the goodies.
ironworks
06-10-2009, 03:06 PM
I have been working on putting this project togther for quite a while. Travis (Red Rocker) from Muscle Car Power and I talked about doing a build series article on how "Fabricators" Like us might build a Pretty "Bolt togther" camaro. And what parts we would combine to make a very well balanced and capable street car and track car. Would we build it just to Autocross or actually haul ass on the track, would we just say it works or would we put it to the test. Would we just show the parts in the picture and say they work great because we got them for "FREE". Or would we work and show all the advantages for the parts choices we made.
So on to the parts selection for today. I decided to use the Chassisworks suspension parts system for the Camaro. For a few reasons, Nobody seems to have any solid numbers, but I think the Chassisworks might be lightest front clip on the market. (camaros have a lot of weight on the front). Plus I felt it would give me the most aggresive ride height. Liked some of the trick features in the front end. like on the fly camaber/caster adjustments, no shims. Plus I think I can fit a 295/17 or 18 on the front. I will work to show you guys the reasons I choose the parts I choose here and in the magazine.
So on to the the build, 1967 Camaro.
Gm Performance Parts LS7, 600 hp and all aluminum..... need I say more
Lemons headers for the LS7, Great Quality premade header
FAST EFI system -Tuning ability and will plug directly into racepak.
Anvil Auto Carbon parts to get more weight off the nose, and make it cool.
BFG Tires 295/35/18 and 335/30/18's KDW's and R1's
Wheels will be a "ONE OFF" design between Ironworks and Shaun @ EVOD wheels.
Clayton Machineworks has some really bitchin Pedals come out and We are on the list for those. They will be start shipping in July.
We will be running Wilwood 13" brakes front and rear. With a Wilwood master cylinder.
Marquez Design will be showing off alot of new products to add to their highly sought after product line.
Ring Brother Hinges and Hood pins should help finish out the front Billet accesories quite well.
Of course with out the helpful guidance of our own Carter Hickman. Who is Currently hammering out another Camaro rendering for this project.
I will keep you guys updated as the parts arrive and my credit cards help stimulate the Economy. Tommorrow she hits the scales to get a base line.
Enjoy
1971CHEVELLE
06-10-2009, 03:11 PM
Awesome project keep us posted
BaddestBuick
06-10-2009, 03:29 PM
Damn those pedals are hot hot hot!!
ironworks
06-10-2009, 03:55 PM
Here are some of the selling points that made me go with the Chassisworks Front Subframe.
I really like the fact I can change camber / caster adjustments with out a having a floor jack. And if you spent some time at your local alignment shop, you could count the revolutions between your street set up and your track set up.
I also like the fact I could clock the rack and pinion to optimise header clearance with the steering shaft and also improve U joint angles if needed to smooth out the steering.
For a track car I like the bumpsteer adjusters, The front suspension is all computer designed and laid out for the best bumpsteer but this would let you tune for your desired specs.
The front sway bar on the Chassisworks front subframe has 2 options, 1.25" or 1.285" We choose the 1.285" bar. I liked the fact the sway bar would not have issues with the oil pan.
Alot of these design advantages are due to the fact of a clean sheet design. Nothing is based around already existing parts. Everything is designed from a clean slate.
Here is a picture of the bed of my F-450 full to the brim with Chassisworks Products last Saturday.
Rodger
oestek
06-10-2009, 05:51 PM
Great stuff Rodger, looking forward to seeing more!
67 ls1 vert
06-10-2009, 08:14 PM
oh man, I was hoping to see more pictures. Nice start. Good luck with your project.
Rhino
06-10-2009, 08:21 PM
Is it just me, or is that a rather large bump steer spacer? It just seems like that much vertical separation between your rack end and steering arm would cause deflection in the steering. One would think that since it was a clean slate build they would either raise the rack or lower the steering arm.
Maybe it's much smaller than the picture makes it out to be?
BossaNova
06-11-2009, 05:05 AM
Wow. Those are some beautiful parts.
Anxiously waiting updates!
compos mentis
06-11-2009, 05:10 AM
Y'use all are very metallic there, aren't ya?
ironworks
06-11-2009, 06:13 AM
I just installed all the shims in the kit as not to loose them. They have not been anything more the just put in there. If you noticed the nuts are not even tight yet so that makes the shaft look that much longer.
Rodger
Rhino
06-11-2009, 08:15 AM
Rodger
Ok, I figured their had to be a reason. I totally missed the nut being loose the first time. Thanks for clearing that up.
ironworks
06-11-2009, 12:23 PM
Today we removed the old sub and installed the new Chassisworks Street machine front clip. We got some weights of the old and the new. The old subframe we pulled out is manual steering and the sway bar is so small it looks like a coat hanger.
It weighs 261 lbs.
The Chassisworks front clip comes with power steering, a big 1 5/16" sway bar and much bigger spindles with Chassisworks bigger bearing front hubs, weighs 230 lbs. I'm trying to get the weight of a stock clip with a bigger sway bar and power steering box, I bet it is another 10-15lbs.
So the stock 1967 camaro you see pictured weighs 1728lbs, in it's semi stripped down state, no windshield, but all other glass intact, most mechanical parts (Brake master, fuel and brake lines, Ebrake cables, etc)
By just removing the front fenders, core support and hood we lost 117 lbs. CRAZY :wow: I would have never guess that stuff weighed so much.
HELLO CAN I SPEAK TO TYLER AT ANVIL.... PLEASE
And finally with the Chassiworks front clip installed and the front sheetmetal back on just like it was in the beginning, we have a total weight of 1646 lbs. So we lost 82 with this just the install of the front subframe. and it lowered the car proababley 2". The ride sticks that come with the Chassisworks clip set the car at exact ride height. You can see the stance is coming togther on the front quite well. Now we need to do something about the rear.
And with the front sheetmetal back in place
Enjoy
wills55
06-11-2009, 12:40 PM
Looking good
redfire69
06-11-2009, 12:47 PM
Can't wait to see more. Goodies indeed!
ironworks
06-11-2009, 03:01 PM
Day 3. The stock sub with Drum brakes and these roller wheels and tires weighs 372lbs.
Since the brake are not here yet, Once we put front brakes on the car, what will it bring the weight in the front back up to?
Which is lighter stock drum brakes or Big 13 brakes from Wilwood?
The Chassisworks subframe contributed to a 31 lbs loss, but how much weight will we put back on when the 13" Wilwood 6 piston brakes arrive?
I was shocked by this number also.
camaro2nv
06-11-2009, 03:26 PM
I love your work and look forward to seeing this bad boy. I thought for sure with what Ive seen out of your shop I would see a custom sub.
Twentyover
06-11-2009, 05:22 PM
I'm looking at the uppr arm adjustment- when you screw the adjusters in and out, is there a ball in the inboard pivot to prevent binding?
ironworks
06-11-2009, 08:37 PM
There is a bushing if that is what you mean.
CliffS
06-12-2009, 02:01 AM
Looking great, nice project!
marinablueSS
06-12-2009, 05:48 AM
This is going to be a very nice 67, I can't wait to see the fineshed product, but the progression is nice as well.
Twentyover
06-12-2009, 10:07 AM
Is the bushing spherical? As you screw the adjsuters in and out to adjust caster, it would appear to me the bushing will bind unless there's a spherical element to it.
ironworks
06-17-2009, 03:12 PM
Well the Wednesday update.
We removed alot of the interior junk and other questionable pieces. The Dog was not found in the car, He just follows me constantly hoping to get in the picture.
I'm debating how to do the windows, I want to do lexan, but the Optima Rules say the windows have to be "Operational". If we ran the roll up glass, I wonder what weighs more, the 67 vent window or the 68 full side glass.
I also think we will resheet the firewall to go to one panel of steel. We will also sink the Dry sump tank into the firewall to put more weigh behind the axle center line. We cut out the cowl vents duct work t loose some weigh. We also cut out the stock dash to build an aluminum unit.
We are down to 1535 lbs.
I'm waiting in the BFG tires to start fitting the 295/35/18 tires on the front. It looks like it will be tight but possible with full steering.
Rodger
DEIGuy38
06-17-2009, 07:47 PM
Rodger,
Could you explain how there was a 31 lb difference in the subframe weights, but when you weighted the car with the 2 subframes there was an 82 lb difference. Seems like it should have been the same lose both ways.
ironworks
06-18-2009, 06:47 AM
Well I guess we will have to answer that question a little early with the info for Day 3. The stock sub with Drum brakes and these roller wheels and tires weighs 372lbs.
So you are Correct the Chassisworks subframe contributed to 31 lbs loss, but how much weight will we put back on when the 13" Wilwood 6 piston brakes arrive?
ironworks
06-18-2009, 10:16 AM
I talked with Carter Hickman a few times about some ideas on this project and he was excited to work with me on some different body mods and looks that we were going for on the car.
Here is a brief run down on the list of mods. We will be running Lexan windows like a prostock drag car. Flush mounted and bolt in with tiny flush allens. We will also be working with Anvil Auto on getting every Carbon fiber piece possible. Flat Hood, cowl panel no vents, hood vents, trunk lid and spoiler. I'm have heard rumors of a front valance and possibly doors. Marquez Design will be handling all the trick billet parts. Ring Brothers is setting us up with a set of some trick hood hinges and some hood pins.
The Wheels are a one off design the Eric turner whipped up in a bout 7 minutes flat. We will be working with EVOD wheels to do our own design.
The BFG R1 Slicks started arriving today and they are almost as tall as me piled up. THAT'S TALL. The slicks measure 285/30/18 and 335/30/18.
The BFG KDW 2's should start arriving soon. Those will me 295/35/18 and 335/30/18.
Bow Tie 67
06-18-2009, 10:37 AM
I love it, great build. I have this front sub, but how in the world are you going to fit the 295 / 35's up front? I have 275 / 40 17's up front and rub the frame, even my 245 / 45 18's rub at full lock. ( back space on the 18's is not optimal )
P.S. Thanks for all the weights.
James OLC
06-18-2009, 10:52 AM
Yeah but where are the VENT WINDOWS???
69Nova
06-18-2009, 11:26 AM
That rendering is killer. I'll be following this build thread for sure.
ironworks
06-18-2009, 11:30 AM
Sorry James, she is a 67 but vent windows are too heavy. Unless we figure out a way to maintain the theme and put a vent window. That would make the window more stable. I'm trying to make the car as light as possible with out having to go on a diet.
Rodger
preston
06-18-2009, 11:39 AM
So you gave up on operational windows ?
I've been intrigued with the idea of buying the pre-formed side windows available from Percy's or Shields and somehow adapting them to stock rollup hardware. I have no idea how this works on a Camaro, my car is a '67 Mustang, but it seems possible. It will mess up the ability to get a good strong window seal due to the flex I imagine, but certainly a possibility.
The vent window on a Mustang is very heavy as well, but it includes the entire front glass channel, so I haven't figured out a way to rebuild it from aluminum as I don't have a pullmax obviously, or anyway to recreate the receiver groove for the window channel felt (I still consider mine a street car).
I like your analytical approach to this build. For those of us who religously weigh everything on the car, its annoying when people throw out weights as in "I"m gonna save 50 lbs by doing this" when we all know its not that easy.
Will this car have hvac ?
ironworks
06-18-2009, 12:07 PM
In the end it is just a rendering and I love the look of the bolt in lexan windows. I have been talking about this idea for months. I have to make the side windows operational for the Optima Shootout. So they need to work in some form of fashion. But man Carter sure made them look good. Now I just have to make it look like that unless I was going for the full on race car looks.
We plan to put a Vintage Air unit in the car and show exactly how much weight that would add to the car. I bet not much, but living in Bakersfield would make it worth while...... MAYBE
Rodger
steelerguy
07-16-2009, 05:04 PM
Any updates on the car?
gvanlaar
07-16-2009, 05:35 PM
We gutted the doors on my buddy's nova and installed lexan. They use the stock tracks and a center mounted stud that protrudes through some aluminum door panels we made. They go up and down pretty easily. Wish I had more pics for ya but this is what I could find.
https://static1.pt-content.com/images/pt/2009/07/stephendoor2-1.jpg
https://static1.pt-content.com/images/pt/2009/07/stephendoor-1.jpg
tones2SS
07-17-2009, 02:23 PM
Looks like a killer project Rodger. That sub frame looks nice.
ironworks
07-17-2009, 02:57 PM
Updates are coming next week. I have to have a mocked up roller at the Pleasanton show in august.
steelerguy
07-17-2009, 03:16 PM
Great! Looking forward to seeing the progress.
wblanton
07-19-2009, 11:45 AM
Those wheels are great. Look a lot like my Forgelines.
ironworks
07-21-2009, 01:25 PM
Well here are some update pics. I got the body lightly blasted last week except for the quarters we are going to replace, the bent up tail panel and rusted out trunk floor. We decided to do the full quarter since there are some small rust spots up top to deal with at the same time. We got a complete trunk floor and quarters from Classiic Industries, they usually have a nice 20%off sale you can get a deal on. We will be building our own wheel tubs to gain the most room possible for the low ride height and 335 tires.
Well some pics of the car and parts.
Enjoy
ironworks
07-21-2009, 01:27 PM
Here is shot of the BFG KDW2's and R-1's tires we plan to run on track days, autocross events and on the street. The slicks are not allowed in certain events due to the low tread wear rating.
Here is a shot of the Ecoated 14" rotors from Wilwood. They sure look sharp.
There will be plenty of updates between now and the end of August. We plan to display the car as a mocked up roller in the Chassisworks booth at the West Coast nationals. Now that Columbus is wrapped up and we are back hauling ass in the shop, we have few cars to get done before we prep the C6-57 for it hopeful booth spot at SEMA.
I need to install the LS7 engine which will happen Saturday with the front sheetmetal and aluminum core support and all the Anvil goodies. We also just got our Ring Bro hinges and hood pins. Once I get the Adapter parts from Chassisworks for the 14" rotors from the 13"s we had planned to run I can install those. I just ordered the axles and rear diff to get those installed in the car. I talked with Hector from Rick's tanks yeaterday and should see a tank in a few weeks. We need to install the Chassisworks rollcage into the car next week and then begin to build the dash to fit the Speedwire switch box unit with the ISIS power system and the Racepak unit with the EFI control unit. We are trying decide if we will install the Kinsler Cross ram unit or if we will run a fully adjustable unit or a factor ECU based system, either way most systems will plug right into the Racepak.
http://www.gallo-teck.ca/speedwire/
http://www.isispower.com/index.html
www.racepak.com (http://www.racepak.com)
Rodger
compos mentis
07-21-2009, 01:49 PM
The rendering has '68 parking lights on it. Do you plan to use those?
67SSDan
07-21-2009, 05:03 PM
Nice! Go with the 67 parking lights though!
Dan
ironworks
07-22-2009, 12:58 PM
Well I told you we would have some Big updates this week.
I finally got all the Carbon Fiber parts from Anvil Auto ( www.anvilauto.com ).
MAN all I can say it they are beautiful. Tyler Delivered the big parts to me at the LA Roadster show, When we opened the box all the wives and Girlfriends were hanging out and not a one of them understand what Carbon fiber is or does, But they all said in at the same time , "UUUUHHHH PRETTY". My thought has always been when you build something and show it to some one who has no clue what they are looking at and they think it is apealing to the eye, your doing something right.
Well check out these master pieces of carbon fiber from Anvil Auto. I wonder if Anvil could combine my Two favorite things, Carbon Fiber and BOOBS?
Check out the underside of the hood, What a way to finish off an engine compartment.
And the trunk and spoiler
Check out the underside, DAMN
Motown 454
07-22-2009, 03:28 PM
Sweet looking parts
Code Red
07-22-2009, 04:29 PM
real nice man
steelerguy
07-23-2009, 06:43 AM
Them are some purrrdy parts!
I don't know though...carbon fiber boobs would just be too rigid. Would make a normally head on collision pretty painful...and forget about motor boating! :)
tones2SS
07-23-2009, 02:09 PM
WOW!!!
They do some great work over at Anvil.:1st:
ironworks
07-25-2009, 12:27 PM
Things have been pretty busy around the shop these past few days, Here are some teaser updates to hold yo over until next week. We are getting the mini tubs built and have the trunk floor ready to spot weld in place. We have the Chassisworks rear suspension pretty much in place. We have the LS7 and T-56 set in place with a synister bracket system and some fancy ATS carbon valave covers. We also have a Performance radiator Aluminum core support and radiator mocked up in place. It is sure coming togther fast. And looks really good.
we took 168 picture in 2 days for 3 different articles for Muscle Car Power Magazine. Plus Eric's convertible got a 4 page spread this month.
ironworks
07-25-2009, 12:28 PM
Here is another for the weekend.
SimplyKC
07-26-2009, 03:30 PM
Nice! Go with Rally Sport lights though!
Dan
Corrected! :)
camaro2nv
07-26-2009, 03:41 PM
Whats the price on that core support?
camaro2nv
07-26-2009, 03:42 PM
BTW The project looks GREAT! Cant wait to see it finished.
tones2SS
07-26-2009, 06:04 PM
Looking good guys. Keep up the great work.:1st:
41565 chevelle
07-27-2009, 08:46 AM
You have a link to your radiator for us....? Looks killer!
ironworks
07-27-2009, 10:38 AM
http://www.autoradradiators.com/
MoparCar
07-28-2009, 03:13 AM
Awesome build. Great!
Could you do me a huge favor? I'm building a Dodge Challenger and I'd love to use the Chassisworks rear suspension you're using in this build but of course they don't make this particular new set up for mopars. Could you measure inside frame rail to frame rail at the shock crossmember and the front where the upper arms mount? I'm thinking I may be able to modify/fab this to fit. The frame rails are very similiar.
Much appreciated.
Wes
orbit
07-28-2009, 07:49 AM
This has to be one of the lightest builds I have ever read about.:seizure: Carbon fiber is a true work of art and weighs nothing!
Please be sure to post up before and after weigh ins!
How did you come up with the design of all of this? There is soo much done. Truly jealous of what you are able to do and have done!
ironworks
07-28-2009, 08:38 AM
Much appreciated.
Wes
The frame rails at the front of the bracket (Front of car) are 34" ID
These brackets are about as far out as they can go.
The frame tapers out to 39" at the back the bracket. You could narrow the rear taper about 2" per side if needed with out affecting the upper shock brackets.
The ID of the front lower inls is about 37 1/8" ID. There are offset spacers on the lower links that would allow you to move this around.
The length of the lower links are adjustable and set to about 24"s at this time.
There looks like there are some provisions to move a few things areound to fit in other cars.
Good luck
MoparCar
07-28-2009, 09:43 AM
Perfect. Thanks for the dimensions. I'll get measuring to see if this would work.
Wes
ironworks
07-31-2009, 02:11 PM
We are finishing up the Rear quarters, tailpanel and trunk floor replacement really soon. But I figured I would give you some teaser pics to Keep your interest.
We have want would equal a 295/35 tire mocked up. It might need a biut of surgery on the fender but it should not be a problem.
Eric (HWY NOVA) and I have been working on some wheel designs for his convertible and we came up with a few designs we are looking to possibly market. They will have a Monoblock design and will be able to have design elements of a Monoblock but be little more affordable. They will be expensive but look at the possible details in this design. Plus they have 11 spokes, not 10.
TA219
07-31-2009, 02:41 PM
I will sound like paris hilton for a second..... THATS HOT! I suddenly have an urge to buy a bunch of CF!!
MuscleRodz
07-31-2009, 02:54 PM
I assume you have something like this in mind without the pie cut?
Motown 454
07-31-2009, 08:37 PM
That is going to look sweet. I wanted to have that done to the rear of mine , but its only in my dreams.
camaro2nv
07-31-2009, 08:54 PM
Odds are Ill be following that path.
ironworks
08-10-2009, 07:06 AM
I guess it is time for the monday morning update.
The Rear quarters, floor and outer wheel tubs from Classic Industries are all landed and tacked in the car. We decided to make our own package tray and the section from the package tray to the rear winodow channel. Our Custom build 35 spline axles from Strange Engineering arrived, We are waiting on our "NEW" 35 spline truetrac to be avaliable to get the built to order center section from Strange Engineering some time next month. The 14" Wilwood brakes have arrived and we installed them for mockup both front and rear. The anodized black Ring Brother hinges have been installed, They work so smooth. We have a set of Ring Brother hood pins, but cannot install them until we get the front sheetmetal fit perfectly. Those beautiful Anvil Auto carbon parts are hard to repair if you damage them, so measure twice cut once.
We had a small problem with getting to run the Silver State Classic next month. The rollcage we had choosen from Chassisworks was an 1.625 cage. We choose that to save weight and in any of the sanctioning bodies we would have ran, they would not have required anything more. Well as soon as we are going to run the Silver State faster then 125, they required a 1.75" x .120 DOM cage. We cannot run that fast our first year, but I hate having to go back and change stuff. Chassisworks said they would get us a 1.75" cage but they were out of stock and it would be 2 weeks. Well when you have 7 weeks to get the car running 2 weeks is alot of time to be set back. So I decided we would pass on the Silver State this year and just focus on being ready for the Optima Street Car Shootout in November. Well Enjoy the pics and lets see how much we get done this week. 10 days till she has to be in Pleasanton in the Chassisworks booth.
ironworks
08-11-2009, 08:49 AM
Well We had to shorten the passenger fender 3/16 of an inch behind the wheel opening to get everything to fit right. You can see the cut line in the sanded away E coating fron the stock fenders that came with the car. So here is where the project is currently at.
The floor was cut out to fit the shifter
Moving right along
tones2SS
08-11-2009, 08:53 AM
That is looking bad ass already Rodger.
ironworks
08-12-2009, 07:35 AM
Some more pics with the 295's installed and a glimpse at the rocker extentions.
Picture of the Setrab Engine and Power Steering Coolers to be mounted in front of the radiator.
Oh and the designer "Ironworks Wheels Stands" are pretty bitchin also.
icebird84
08-12-2009, 09:40 AM
wow excellent work
P.s the build from A to Z is excellent work
RyanG
08-13-2009, 10:36 PM
nice car
hope to see it finished
ironworks
08-17-2009, 04:36 PM
Well we got the Engine and power steering coolers landed and are working on the engine plumbing.
Can you guess what goes here?
And the start of the Rollcage, man these ready made kits are sure easy. We are going to have to do something to clean dress things up Ironworks style.
67 ls1 vert
08-17-2009, 06:44 PM
is that where you are putting the sump?
ironworks
08-17-2009, 07:27 PM
Yes sir :1st:
ironworks
08-18-2009, 01:02 PM
The load of K&N air filters showed up yesterday and so did the Kirkey seats. We went with the Intermediate Seats with the Deluxe seat cover which will be here later this week.
The Intake filter is 12" long has a 3.5" opening and has a stud on the nd to help support the end of the filter, when we install it in front of the core support.
Enjoy
ironworks
08-18-2009, 02:56 PM
Pics of the Dry Sump Tanks installation coming right along.
Pics of the Chassisworks rollcage install.
Rodger
ironworks
08-18-2009, 04:20 PM
I'm not sure AirRide ever intended for this with their gas cap, But hey.......
ironworks
08-20-2009, 05:43 AM
Thanks Guys, I liked the oil filler idea but was not sure how it would be recieved. Well we got it togther with the cage tacked in place and most of the sheetmetal fit and hung. This car is coming along well for what I believe is 18 days of work or so. At least that is what the time journals said late last night when I did payroll.
The Marquez taillights and Ricks fuel tank showed up yesterday. The Taillights really make the back of the car. The Ricks fuel tank with new internal BOSCH fuel pump slipped right in. These bolt togther cars are pretty easy.........:D
We are leaving for Pleasanton and will be displaying the car in the Chassisworks booth all weekend. Stop by and check it out. I will have Musclecar Power Magazines to giveaway. John and Eric should be around for autographs on Saturday and Sunday......:D
James OLC
08-20-2009, 05:55 AM
The car looks like it's coming together great Rodger! Considering where you started, 18 days is awesome - especially with some of the details that you have worked into the car. Have fun at Pleasanton and talk to you next week.
RyanG
08-23-2009, 12:18 AM
the car looking really good hope to see more soon
SatisTraction
08-24-2009, 07:37 PM
LOL. i check this trhead every day looking for new pics. :yum:
srh3trinity
08-24-2009, 08:17 PM
Not bad for a "bolt together car"
SDS MACHINING
08-24-2009, 08:39 PM
I have me a Serious case of Progress Envy :squint: ! sweet stuff you guys are doing there..
Flash68
08-24-2009, 10:15 PM
Awesome stuff Rodger. Love this pic! My new background. :D
zbugger
08-24-2009, 11:19 PM
Saw the car on Sunday at the show. VERY nice. I can't wait to see the continuing progress.
tellyv
08-25-2009, 05:41 AM
that thing is going to be cool!!! I love the rendering so much I'm having carter do mine!!!
ironworks
08-25-2009, 01:53 PM
We built and installed the Air Intake plumbing this morning with 3 90 degree 3.5" bends. The Air filter from K&N fit like a glove.
ironworks
08-27-2009, 11:56 AM
Well our Speedtech switch panel finally cleared customs and arrived this morning. From my Days of Drag racing I remembered a company from Canada that made a really nice switch panel, that was set up with some self diagnosis features that could come in handy on the side of the road or the track. The switch panel connects through a Axial cable like your computer uses. All you do is hook up the power source to the relay panel and route your power wires to the components your running.
www.speedwiresystems.com
Enjoy
ironworks
08-27-2009, 04:32 PM
Rollcage progress
RyanG
08-29-2009, 10:17 PM
The car is looking good
:1st:
Les69
08-30-2009, 12:08 AM
i love everything you did to the car man.... the carbon fiber makes me drool!
ironworks
09-01-2009, 12:38 PM
Time for another update. Things are going pretty smooth. We have 90% of the rollcage welded in place. Most all the parts are under the hood. We have the ATS hydraulics for the clutch on th firewall and Got the Vintage Air LS7 Engine Bracket system Anodized in black installed. We have the Willwood black master cylinder mounted on the firewall. We are going to run manual brakes no booster or hydroboost. We have the Air intake plumbing set up with a K&N air filter. We have alot of the Plumbing done in front of the core support. We got the firewall support bars located and welded to eveything but the male side that welds to the chassis. We got the Drive by Wire Throtle pedal mounted up under the dash. We are going to try and get the Clayton Machine Works gas pedal pad on the elctronic gas pedal. The Drive by wire throttle body has not shown up from Gm yet.
The Vintage air bracket system went on without a single hitch. It is very solidly constructed and seems like a pretty nice piece. We will be installing the Gen 4 unit later this afternoon. We are also working to lay out the window flanges in Solidworks to laser cut the steel flange and water jet cut the lexan windows.
Enjoy.
I will try and get a complete underhood picture later this afternoon.
67 ls1 vert
09-01-2009, 02:14 PM
it look like a great job. keep the pictures coming for us.:1st:
ironworks
09-01-2009, 03:46 PM
As promised, or Threatened
The start of Hanging the AC.
Fedders
09-01-2009, 05:54 PM
I am trying to decide which subframe to install in my 67 RS/SS Camaro. These are the best close up pictures that I have seen.
ironworks
09-05-2009, 02:07 PM
Well here is a Saturday Update for you guys. We are moving right along with some details that take alittle longer then the big stuff. We have Mounted the GM performance parts ECU, Which will be exposed, We mounted the Speedwire Relay panel right above that, We have the Vintage Air unit mounted off the firewall and rollcage also. We also got the Kirkey Seats mounted in the car. The Twist machine shifter is also mount to the shifter.
Have a Good weekend
Rodger
ironworks
09-14-2009, 02:31 PM
Well Time for the Monday update, we have gone alittle bit over board on some items, but we are waiting on some parts and just can't stand to leave it alone. Enjoy
We got the differential from Stange today with the just released to sell 35 spline True Trac positraction. The Chassisworks axle housing is pretty slick lookin also.
Just a picture of the rear suspension completely TIG welded into position, with the Ricks Stainless fuel tank in position. They sure do sell a nice unit. We got this one with their Bosch fuel pump installed inside the tank.
We are starting on the interior panel designs and placement. We will be cutting out the complete interior structure to replac eit with these panels. Wait till you see the doors and the floors panels.
Enjoy
Motown 454
09-14-2009, 05:40 PM
Very nice work it looks sweet...
Rick D
09-14-2009, 07:29 PM
Hay Rodger Awsome work Love the inside panels But I have a question for you CAN I HAVE IT????Just woundering :) Keep up the great work. Also where are you at with cost I know you said you were going to keep track of everything?
ironworks
09-15-2009, 06:55 AM
So I borrowed the scales again yesterday. Most all the parts are on the car, We lack, fluids, plumbing, and lexan windows, exhaust, mufflers, driveshaft, light weight floor insulation, wiring and and few other
small items. We also do not have the actual wheels and tires on the car
For not making any adjustments to the coilovers to move weight around it is coming out nicely. Our goal of under 3000 lbs without 260lb driver should be pretty easily done. Maybe 3100lbs with driver??????
Here is a picture of the start of the dash, We plan to get busy on the engish wheel to build the rest of it very soon. The interior panels are continuing.
I'm getting nervous about some parts we cannot live without.
ironworks
09-18-2009, 07:52 AM
Some pics for a Friday
Enjoy have a nice weekend.
preston
09-18-2009, 09:27 AM
Amazing how fast a shop can move. Very clean execution although I prefer the full fab cars myself of course.
Is that a pretty standard way of attaching lexan ? I've seen several different approaches. Focusing on the back window, I assume that frame is mounted ~1/8" below the surface so the lexan is flush with the sheet metal ? Do you just get a nice tight fit and weld to whatever metal its touching ? How do you compensate for the weld bead without creating a gap between the window and the panel ? (bevel the lexan on the bottom surface ? grind the weld down ? Never easy on an inside corner). Will you use plastic fasteners or SS screws and will there be silcone in there ?
Being able to spec out those laser cut panels is awesome, I should get the tools and find a vendor to do that, beats the crap out of a sawzall and grinder LOL.
nvr2fst
09-18-2009, 09:58 AM
Preston
I believe the cut window panels are for mock up only for the shape of the lexan, but I could be wrong.
ironworks
09-18-2009, 10:24 AM
Well 4 weeks ago I had the gran idea that I would lay out the pattern in Solidworks and it would fit like a glove. Well Quickly found out after 75 bucks in full side print outs that making a precision piece fit a not precison part like a camaro body, you have to throw the tape measure away. So I cut it just tic big, with the bolt flange and then sanded it to fit the opening. I pan to weld the famge from behind and the side windows flanges will bolt in and out from behindI have thought about doing the same in the front and rear with pan head bolts so the lexan would set on top. But now that we have the flange fit very tightly I have a stout pattern to clamp the lexan to and then drill all the holes and use the steel as a pattern. I was hoping at one time laser cut the flange and it would fit perfect and then water jet the lexan. But I can not fill the factor imperfections with the welder.
We laser cut panels and pieces all the time, Check out Daves Camaro in this project section and you will see how high my laser cutting bill has been. If we tried to make these parts by hand it would cost 10 times more. I can cut all the complicated parts for a project for the price it would take to make some of the the large complicated with all the labor involved. I got some more parts last night.
I will post them in Daves thread later today.
Thanks Guys
ironworks
09-23-2009, 10:15 AM
Well a Sneak peak for the wheels from Budnik for you guys.
ironworks
09-25-2009, 04:26 PM
Here is pic that Sheila from Budnik sent me. Wow looks better then expected.
MoparCar
09-26-2009, 05:18 AM
Awesome wheels!! Are they one off or will they be available through Budnik?
Nice.
Wes
TGVettes
09-26-2009, 07:13 AM
totally in style of what I want on my 68 Camaro. Awesome wheels.
Tonny
SDS MACHINING
09-26-2009, 08:47 AM
Eveytime I see check out this thread it gets better, Awesome Wheels!!!!:yum:
Motown 454
09-26-2009, 11:54 AM
Sweet wheels.
L & H Kustoms
09-26-2009, 11:58 AM
wheels looks awesome the cars looking sweet
ironworks
09-27-2009, 08:21 AM
Nice.
Wes
Thanks Guys, they are the GTB wheels. Off the shelf with a little creativity.
Capown
09-27-2009, 12:36 PM
OMG!! So are u adopting or hiring? Im a fast learner!! I love this build.
Flash68
09-27-2009, 02:10 PM
Killer shoes!
454bug
09-27-2009, 05:36 PM
Looking GREAT!! :1st:
Jim Nilsen
09-27-2009, 07:12 PM
This is a build right out of my own head and heart. If I could start over and had your tools I would be right behind you with a yellow version of this car. Total purpose built and all of the right components to make a man want to make them all.
first gen fan
09-27-2009, 08:46 PM
You guys do some killer work! We built my pro touring camaro in 14 months and I thought that was good. Where are the carbon valve covers from? Keep up the good work.
ironworks
09-27-2009, 09:19 PM
ATS had the carbon valve covers
MCMLXIX
09-28-2009, 09:51 PM
What is the plan for the coil packs?
ironworks
09-29-2009, 06:50 AM
I have a few ideas for the coil packs. That is one of the next thing on our list.
ironworks
09-29-2009, 05:19 PM
With out making any body wait anylonger and the 5 phone calls I got today asking to see pics, HERE YA GO.
Drum Roll Please...........
This is a really go idea of the actual color of the wheels and those 295 front tires look awesome. The wheels are 18x10 and 18x12.
The Budnik steering wheel looks awesome. Same finish as the wheels.
I just want to say Thanks to Jay and Sheila at Budnik for working with me to get these wheels set up. Jay really helped pic the center color and Sheila was patient enough to work with me to get it done.
Flash68
09-29-2009, 06:27 PM
Sick Rodger!
ironworks
10-02-2009, 09:26 AM
These pretty much speak for them selves.
I like this picture.....:thumbsup:
67 ls1 vert
10-02-2009, 10:10 AM
That's funny... Brown Material road sign pointing at the bathroom.
1BADRS
10-04-2009, 01:31 PM
Jinx!
rat_rod_russell
10-04-2009, 03:18 PM
Seriously, Your not going. I should have bought stock in Monster and Red bull for all the caffeine I've been taking in to get the PT-57 knocked out and your backing out? That sucks, I was hoping to see one of your cars go around the track.
-Russell
ironworks
10-04-2009, 07:38 PM
Oh we will be there, We are helping with teching cars for the event. Since you can only run the event once, I don't want to go to a gun fight with a pistol I just picked up yesterday. My sponsors felt the same. The car was intended for 2010, SEMA and the Optima Shootout where a step up in the plan.
Russell -
I Checked out your build thread and you have your work cut out for ya. Hope to see the truck in line for Tech at the shoot out. My truck will be in the trailer at the event, but still all dressed up from the Meguiars both. My truck turned out "TOO" nice.
JohnC
01-24-2010, 03:55 PM
Hey Roger,
Any updates?
Very cool...
T_Raven
01-25-2010, 03:36 AM
Just read through this. Awesome ideas. I love the oil tank placement. Rendering looked awesome too.
cobraguy65
01-25-2010, 05:40 AM
Awesome build! what happened to the rocker extensions?
Vicinity
01-25-2010, 03:32 PM
I've been waiting for updates to this one for a while as well, I hope it didn't get put on hold! :guilty:
kochevy67
01-26-2010, 03:12 PM
Awesome job. I love the carbon hood.
MoparCar
05-15-2010, 05:53 AM
What happened to this build? Did I miss the finished product?
Wes
ironworks
05-17-2010, 09:17 AM
We have been slammed working on Customer jobs. We just built the exhaust a last week. We have the lexan windows installed and just need to figure out how to do the lexan windows in the doors. Then I can get it Epoxy primered and get all the suspension and components powder coated.
Soon I hope, Things have been way to busy for the last few months.
Conrad283
05-17-2010, 08:13 PM
Nice build guys ... You guys do some top notch stuff.
ironworks
07-17-2010, 12:28 PM
Well we got the car back from the blaster and painter. I had the entire body epoxy primered gray for now. I had the bottom and the firewall painted Dove gray. I have always liked the Nascar look. The car is not detailed to the moon, just business. I don't want it to be too nice, we want to drive it without reservation. We used the super lightweight Dynamat Insulation and set up some aluminum floor pans to help with the heat and give it a cool look. We have started on the Engine wiring harness and milspec connectors. At this point it looks like we will put a cheap paint job on the car to paint the door jambs and roof, and will vinyl wrap the exterior. We found out to run in the suspension shoot out next month they want roll up windows and some kind of interior. We have quite a bit more to go but we are getting there.
Well on to the pics.
ironworks
07-22-2010, 11:29 AM
Progess
The door got to get blaster and primered next week. It looks like we will paint it Orange and just riddle it with stickers.
We had this old valance just laying around from an Old "ALMOST" forgotten project with really cool taillights and decided to give it a try to see what we like and what we don't...hhhmmmm
...... Aluminum or Carbon or Carbon with aluminum vents....
Tyler can I use a sharpie on you fancy Valance? Please
paulgurley
08-08-2012, 06:45 PM
Awesome build! did this ever get finished?
Mr.VENGEANCE
08-08-2012, 06:59 PM
i thought this got sold..
paulgurley
08-08-2012, 07:23 PM
Oh bummer. did it sell as a project? or was it finished
Mr.VENGEANCE
08-08-2012, 09:14 PM
i dunno.. i saw it as almost a completed but i think it was a project if it did in fact sell..
Samckitt
08-09-2012, 05:17 AM
Great work.
cashed
08-09-2012, 06:38 AM
I picked up the car a couple of months back. It was never completed, and is still a work in progress.
Ron.in.SoCal
08-09-2012, 07:10 AM
Finished last year and ran GGuys Columbus along w coverage in the Super Chevy Suspension issue. Almost certain it's sold...
Carl @ Chassisworks
08-10-2012, 07:51 AM
It's been good talking to you. Let me know if you need any more tech help.
~Carl
ironworks
08-10-2012, 11:45 AM
I sold the car a while back in what was a completed state for my tastes and desire for the car but unfinished for most. The car went to Texas and the new owner has been doing some mods to it for his taste.
Rodger
