MuscleRodz
06-07-2009, 06:41 PM
Just released from Spaghetti Engineering is the 86-92 Camaro Sequential Tail Lights. The 1986-92 Camaro kit uses 378 high intensity wide angle LED’s which makes the lights much brighter than the original lighting to match modern automobile intensity.
In addition, the working functions of the taillights have been changed from the original factory use. The inner lens to remains as a constant brake light while the outer lens is used for both brake and turn signal operation. This outer lens turns on and off with a sequentially illuminating cascading effect which is simply stunning. If you prefer standard (non-sequential) operation, there simply flip a switch on the back of the circuit board.
Kits are priced starting at $299, electronic flashers are recommend and are $19 each, 2 required, one for turn signal, other for hazards. Their is also a full kit available which includes LED side marker bulbs, 2 reverse bulbs, and 2 flashers. Retail price on that kit is $349
We are running a special on these for the rest of June, these kits will be 10% off in our store. here is the link to their operation. http://spaghettiengineering.com/distributorcontent/Videos/1100186v2.wmv
