View Full Version : Mmmm - 2006 Shelby Cobra GT500 (PICS)
GT350Clone
03-22-2005, 04:24 PM
Available next year...
Not sure how long until Ford pulls the plug, but here's "tomorrow's press release"... :smoke: http://media.ford.com/products/presskit_...&make_id=92 (http://media.ford.com/products/presskit_display.cfm?vehicle_id=1269&press_subsection_id=423&make_id=92)
POWERTRAIN
Just as the big-block GT500 from 1968 was a step up from the GT350, the Ford Shelby Cobra GT500 show car's 450-plus-horsepower, 5.4-liter V-8 is a step up from the 4.6-liter V-8 used in the previous-generation SVT Mustang Cobra.
In fact, the 5.4-liter, 32-valve, supercharged V-8 configuration is similar to that of the 2005 Ford GT supercar, offering the right combination of classic Ford big-block power and modern technology. Using the Ford GT as a blueprint, SVT has given the GT500 more total horsepower than any factory Mustang in the muscle car's celebrated 41-year history.
"We are applying our Ford GT engine experience to the GT500 to bring over 450 horsepower to a much bigger enthusiast audience," says Jay O'Connell, SVT chief vehicle engineer. "It really delivers on the essence of two great names in Ford performance – a mix of SVT's modern-day experience with supercharging and the Shelby GT500's heritage of big-block power."
The result: More than 450 horsepower and 450 foot-pounds of torque.
Under the bulging powerdome hood lurks the most potent factory Mustang engine ever: A supercharged, 5.4-liter, 450-hp
V-8.
Engine upgraded for supercharger's power increase
With the stout cast-iron, 5.4-liter Triton V-8 engine as a starting point, the Shelby Cobra GT500 adds a screw-type 8.5-pounds-per-square-inch supercharger and water-to-air intercooler.
But, adding forced-induction power is more than just a bolt-on proposition. The engine's internals need upgrading for the sake of strength and durability. To that end, the Shelby Cobra GT500's powerplant benefits from unique connecting rods and forged pistons to handle the extra strain on the lower end of the block.
An all-new intake manifold helps to efficiently channel the supercharged fuel-air mixture into the cylinders. The low-profile manifold design also effectively packages the entire induction system under the GT500's special air-extraction hood. Fuel comes from a dual-bore electronic throttle body borrowed from Ford's 6.8-liter truck engine program. To manage heat produced by more than 450 horses, a larger radiator and increased-capacity cooling system also are installed.
Aluminum, high-performance Ford GT heads tout "Powered by SVT"
While supercharging is a key element in the Shelby Cobra GT500's ability to generate so much horsepower, another major contributing component is the design of the cast-aluminum, four-valve cylinder heads sourced from the Ford GT supercar.
Cast "Powered by SVT" coil covers finish the four-valve heads sourced from Ford GT.
Developed specifically for supercharged applications, these high-performance heads use high-flow ports and specially calibrated dual-overhead camshafts to deliver optimum engine "breathing" along with surprisingly good fuel efficiency and emissions. Also borrowed for use in the GT500 are the Ford GT's proven piston rings and connecting rod bearings.
To enthusiasts, the real beauty of any performance car rests with its engine. That idea certainly wasn't lost on Carroll Shelby because Mustangs that bore his name have traditionally brought his unique sense of style and personality right into the engine compartment. One Shelby signature feature – special finned valve covers embossed with "COBRA Powered By Ford" – soon became the envy of so many Ford V-8 owners that they quickly became one of the best-selling dress-up accessories on the market.
With that in mind, the GT500 is equipped with special "Powered by SVT" finned cam covers to hint at the beauty of 450 horses lurking in the engine below. Mated to the Ford GT four-valve cylinder heads are unique exhaust manifolds that help to better scavenge spent gases out of the cylinders and into the custom-tuned mufflers and dual-exhaust system.
Strong transmission for powerful engine
Few transmissions exist in the marketplace today that can handle the torque loads generated by the supercharged GT500, so SVT engineers are opting to stick with the proven heavy duty performance of the T-56 six-speed manual gearbox. The T-56 first appeared in the 2000 SVT Mustang Cobra R, powered by a naturally aspirated 5.4-liter V-8 with 385 horsepower, and later in the supercharged 2003 SVT Mustang Cobra whose DOHC 4.6-liter produced 390 horses. For the Shelby Cobra GT500 show car, the T-56 will be geared to make the most out of the supercharged 5.4-liter's broad power band.
Restomod
03-22-2005, 04:35 PM
SWEEEEEEEEETTTTTTTTTT better start saving and selling EVERYTHING..........NOW!!!!!!
Nutsy
03-22-2005, 04:48 PM
Ill take one... no make that two!
Bill Howell
03-22-2005, 05:36 PM
My only complaint is the missing headlights. I think it needs the other two grill mounted lights. Other than that it is a great looking and sounds like a great performing car.
kmcanally
03-22-2005, 06:47 PM
and what about the sweet looking super crew in the background? is that the replacement for the canceled or delayed lighting?
will69camaro
03-22-2005, 07:00 PM
Yes that is the ford sport track adrenalline or something like that, i saw it at the houston auto show and it looks pretty good in person ( i saw a white one). Not sure it can replace the lightning (not a fan of extended cabs) but with 390hp it will perform nicely. I like the GT500 without the grill lights. If i bought a GT that would be the first thing to go. I really like the new Cobra and i WILL own one in the future....
William
ProdigyCustoms
03-22-2005, 10:52 PM
They really blew it not doing the inboard lights, huh Bill? I like it though.
ViperBlue68
03-23-2005, 12:35 AM
If I could force myself to own a Ford :hammer: this car would be sitting in my garage next to the Cadi and Camaro for sure.... :icon996: looks to be a sweet car....
JohnnyGMachine
03-23-2005, 03:49 AM
Boy I'd love to have one of those parked next to my 2 stangs in the driveway. It's a good day for Mustang enthusiasts! I was hoping somebody would have sneak peaks of this car before friday's unvieling. I can't wait to see one of those things run. I'll bet that car is dangerously close to running 11s down the 1320 in stock form. I'd also like to see them do a 500 hp. version (might sound good with GT "500") and call it the GT 500KR!!! That would be the Cobra R replacement that would be the icing on the cake in my opinion.
Bill Howell
03-23-2005, 04:51 AM
I guess having been around in the late 60's and early 70's and being a kid at that time, that is how I could separate the "good" ones from the regular ones. Even now when I see a 65, the first thing I look for is the extra headlights to see if it is a GT. That was like SS badges, people added them to plain cars but no one EVER removed them from a true car.
GT350Clone
03-23-2005, 05:01 AM
65 & 66 Shelby did not have inboard headlights. That was a 67-only thing.
ProdigyCustoms
03-23-2005, 05:47 AM
The 67 inboard light thing was short lived, but is legend but had to be stopped. Maybe they could not get away with it on this new one? Surely they considered it? Maybe I should be designing a inboard light set up?
Rick Dorion
03-23-2005, 06:00 AM
A friend of mine had a GT350 back in the day and it was awesome. Someday I'd love to own a new GT. Between that and my 69, morning's would present an interesting choice!
Bill Howell
03-23-2005, 06:33 AM
I guess I am talking mustang GT and not Shelbys because I know the GTs had them thru the early 70's. Sorry, I am not a FORD man, I just like the lights.
rob07002
03-23-2005, 06:34 AM
I second that, Ah tis a sad day to be a GM fan......
Chuck Byram
03-23-2005, 06:52 AM
Wow! Whatta machine! I love seeing Shelby's name back on a pavement ripping Mustang.
mdprovee
03-23-2005, 07:59 AM
Where does the line start. Now, how to convince my wife that we need this car, maybe pass it down to the son when he turns 16 as his first car. That is only 15 years away. I am not a Ford fan, but that is a BAD car. Gm has a lot of catching up to do.
Mike
Bill Howell
03-23-2005, 01:49 PM
Mike
I had it figured out why to convince her until I read the one year old part. It is not why "we" need it , it is why "she needs" it. But she will have trouble seeing that logic when she knows she will have to fight a car seat in and out of that tiny back seat. You may have to convince her she "needs" the convertible instead. Yeah, that's the ticket!
Bill Howell
03-23-2005, 01:50 PM
Mike
I had it figured out how to convince her until I read the one year old part. It is not why "we" need it , it is why "she needs" it. But she will have trouble seeing that logic when she knows she will have to fight a car seat in and out of that tiny back seat. You may have to convince her she "needs" the convertible instead. Yeah, that's the ticket!
mdprovee
03-23-2005, 02:44 PM
Thanks Bill for trying to help me out. She wants an Explorer, or something similar, because of the car seat issue, and being able to haul around 2-3 kids.
Now let's see...but babe, we need it becuase...
The funny part is she would probably let me buy it if I really wanted it, and could afford it.
Mike
Steve Chryssos
03-23-2005, 03:23 PM
That car is hot. Chevy fan or not--I'll take one.
ViperBlue68
03-23-2005, 03:32 PM
Have they said what MSRP is or a ballpark?
JLM
03-23-2005, 04:05 PM
Well, it looks like my 03 is out-dated now. Time to upgrade!
MSRP is said to under 40K. based on pricing on the 05 GT's I would say pricing should be in the 37K neighborhood.
Restomod
03-23-2005, 05:38 PM
Well with the Z06 having 500hp this should have the same,450hp will only have it doing catch up with the Vette!! BTW I recall that driving lights were an option up to 68.
Bill Howell
03-23-2005, 05:48 PM
Mike
Unfortunately, it sounds like you are in those minivan/SUV years that we all go thru.
Don't get down about it though because there are benefits those kids offer that no car will ever match :icon996: .
GT350Clone
03-23-2005, 06:27 PM
Here you go - SUV meets Cobra...
2007 SVT Adrenalin SUV (http://www.stangnet.com/content/view/66/)
"With a supercharged, 390-horsepower V-8, the first six-speed automatic ever featured in an SVT vehicle and an SVT-tuned fully independent suspension, Adrenalin promises the acceleration, agility and utility that made the legendary Ford SVT F-150 Lightning the best-selling, longest-running performance truck ever. "
JLM
03-23-2005, 06:39 PM
There's also a 30-40K price difference between the 2 cars. Based on the moddability of the previous 03/04 Cobra's the 2006 model should have no issue putting a Z06 in it's place for about 1500.00
intake, mid-pipe, cat-back, pulley and tune. On the new car I'm guessing those items will account for rwhp levels around 550. Assuming it mods anything like the 03/04 Cobra's that is.
The Z06 is badass car, but it's in a completely different class than the new Cobra, not really cars that you can compare, especially considering the huge price gap between the two cars.
mdprovee
03-24-2005, 08:39 AM
Yeah Bill,
I wouldn't trade one of his smiles for anything in the world. Besides my wife lets me buy anything I really want for the camaro anyway. Just NO mininvan!
Mike
Restomod
03-24-2005, 05:04 PM
JLM ,True bolt ons will push the HP up easy. You could almost buy two Cobras for the price of the Z06!! BUT Ford making the car 500hp would not raise the cost of the car much.
Beige
03-24-2005, 05:34 PM
I really don't like the car, but I could think of plenty of things to stick the drivetrain in.
Stangonline.com
03-24-2005, 07:30 PM
Yeah, but I've heard the weight is close to 4000lbs. Ford also ditched the IRS for the same panhard bar setup that is in the GTs...and it STILL weighs a lot :(
Thinking about getting one.
Jeff
JLM
03-24-2005, 07:45 PM
Jeff
The car probably won't weigh any more than the current 03/04 Cobra. my race weight with me in the car, a 1/4 tank of gas andnothing taken out of the car was 3725.
Ralph LoGrasso
03-24-2005, 11:44 PM
What kind of times are you running? 460rwhp from those mods makes it scary to be a Camaro these days, heh. How many psi of boost?
As for the weight, doesn't a stock '05 GT weigh 300-400 lbs. more than an '04? I thought remember reading that despite the 40hp incrase, the extra weight kept the cars pretty even in the 1/4.
JLM
03-25-2005, 10:53 AM
My car runs a pulley that is good for 15psi. I normally only see about 12psi because of the altitude I live at. The car went 12.841 @ 112.5mph. The DA on that day was about 8700 above sea level. Traction is an issue even up at this altitude, but at sea level the car would likely lick off a mid 11 at around 123-125 mph. This seems to be the norm for bolt-on 03/04 Cobra's.
The new 05 GT weighs about 150 lbs more than the previous model. The big shortcoming on the new 05's is the computer programming. It's a drive by wire system and to save parts theres somre pretty insane stuff the computer does. Even at WOT as you start getting close to redline the computer starts closing the throttle butterflies, it also has what's known as "torque management" build into the computer that retards timing on shifts past certain RPM.
Bolt on cars with intake, mid-pipe, cat-back and a tune to get rid of the above mentioned computer items are going very low 13's on street tires, and well into the 12's on drag radials. At sea level of course.
Ralph LoGrasso
03-25-2005, 03:22 PM
Those times are impressive for your Cobra. Mid 11s with just bolt ons is pretty incredible. I wish the general would build a new Camaro that was S/C.
I didn't realize it was only 150lbs more. That's not much. The torque management on new cars is a problem. The C6's have the same thing, and it's slowing them down pretty significantly. There was an article in PHR, where Cartek ran something like 12.6 stock, and all they did was add some headers, 17" ET streets, and remove the torque management and then went 11.5's.
Steve1968LS2
03-25-2005, 05:14 PM
When this story came out I got to do the "STOP THE PRESSES" so I could add it real fast to the Speed Reading news section..
First Story = GM cancels the 2007 Camaro by killing Zeta
Second Story = Ford announces 2006 450hp Shelby Cobra GT500
Ironic huh???
I saw a saleen 2005 mustang the other day.. I think it looked even better than the GT500.. very nice cars!!
Todds69
03-26-2005, 08:29 PM
Very nice ride.....Chevy is really missing the boat here. Still makes me want to cry. :banghead:
Rick Dorion
03-27-2005, 03:54 AM
I just saw the Saleen and GT500 at the NY Auto Show. Nice cars!
