View Full Version : 4l60e to a sbc
ls173camaro
06-04-2009, 03:22 PM
i did a search and the posts i found were really old and it seemed like the swap was new at that tim. wanted to know what you need to mount a ls1 4l60e to a sbc. more on the bellhousing, flex plate and converter. i scored tci new controller and harness. i know i need the tps setup and the crossmembers an easy fix. thanx for the help.
Taylor1969
06-05-2009, 05:16 AM
not sure.... the better approach might be getting an LT1 Style 4L60E
Steve Chryssos
06-05-2009, 07:38 AM
Bellhousing's fine. Most important thing to do is determine the year of the case. It should have a late style input shaft where the O-ring is at the base of the shaft--not closer to the tip. Early input shafts are stepped at the tip and have an O-ring right there. If you're not sure, just post a pic of the input shaft.
