View Full Version : Who's running a 15/16 bore with manual brakes?
mnm99
06-04-2009, 09:10 AM
Just ordered my Stainless flex lines and Hawk HPS pads from Tobin ( Thanks for your help ). Also ordered a 15/16" master from CPP. Tobin, I ended up just getting the one with (2) 3/8 24 threads. I'll just make up a couple new lines to the prop valve.
Anyway. I'm using single 2 15/16" front pistons with drum rears. Just wondering how your similar setups are working out. I have a week or so before I swap over.
Apogee
06-04-2009, 09:18 AM
Thanks for the heads up that CPP has the small port version of their 15/16" C3 type master cylinders in stock...I thought they were BO'd on both the small port and large port versions.
Tobin
KORE3
mnm99
06-04-2009, 09:23 AM
He said they have like 10 left.
Bryce
06-04-2009, 09:34 AM
i have a wilwood chrylser style MC with a 15/16 piston. Dynalite 4 piston calipers in front and drums in the bake. Its manaul brakes and i like it alot. always stops great. but it only weighs 2700.
TitoJones
06-04-2009, 10:15 AM
I have a 15/16" bore master with 4 piston Alcon brakes and drum rears in a manual setup. It is fantastic in all respects from pedal feel to leg force needed to stop.
Tyler
mnm99
06-04-2009, 10:39 AM
Sounds great guys. Keep'um comming. Making me feel like I made the right choice so far.
mnm99
06-04-2009, 03:53 PM
Drove the car today with the booster vac disconnected (Still mounted) just for the heck of it. LOL... I have a 1 1/8" master stock pads and rubber lines. I was able to stop and even skid with some force. Took some effort though. Looking forward to see what the 15/16 master , steel lines and Hawk pads do.:)
ks71z28
06-11-2009, 09:39 PM
I wouldn't go any smaller than 15/16 bore with that monster single pistom GM caliper. It was designed for power use, and can be funny as a manual brake. I recomend the GMiii direct replacement caliper, it is nice and light. I run 3/4" bore with my c5 style brakes, but use a dual master cylinder with a balance bar, the ONLY way I could get manual brakes to work really well, check out www.customworksproducts.com (http://www.customworksproducts.com) under the brakes tab. it is expensive, but changing master is cheaper, and it is very adjustable.
My 2c
