View Full Version : Power Steering Lines How are you routing them?
SamHatco
06-03-2009, 10:03 AM
69 Firebird with LS1 and factory steering box. How are you guys routing the power steering lines? I just installed my front drive system and was wondering what you guys used to route the lines. There is not a lot of room to come with a 90 between the pulley and the reservoir. But there is plenty of room behind the reservoir. Does anybody make a hard line that would be routed behind the reservoir? Pictures and part nos. would be helpful. Here is a picture of my pump.
You thoughts and comments are greatly appreciated
Sam
06-03-2009, 04:30 PM
DSE has a few on line.
You can come out the pump in to the box out of the box to a cooler then back to the pump.
http://www.detroitspeed.com/productpages/indproduct/steeringprod/hardline_tube_banjo_prod.htm
SamHatco
06-03-2009, 04:52 PM
THANKS MrQuick:jump:
That's exactly what I'm looking for!
Sam
SamHatco
06-11-2009, 04:09 AM
The DSE banjo fitting doesn't fit. The banjo bolt is too short. When I remove the -6 fitting in the pump there is no way the banjo bolt is going to work. Is there another adapter fitting that works?
Sam
