View Full Version : Kenne bell owners
67 ls1 vert
06-02-2009, 06:41 PM
How many guys have the Kenne Bell set up? What kind of power are you making and with what set up?
RSX302
06-04-2009, 08:38 PM
Can't say that I still have, but my factory computer 93 Ford Mustang LX 302 with GT40X alum heads, stock cam, headers, 2 1/2" custom H-Pipe and cat back, 75mm Mass Air, 70mm Throttle body, 91 oct and a KB 1.5 blower at 8psig made 350rwhp/400rwtq. Peak torque by 3200 rpm. Needed sticky tires to get it to hook in first and second.
i have one on a 4.6 4v cobra stock with headers makes 380 to te wheels
67 ls1 vert
06-05-2009, 05:57 PM
I have one for my LS stroker and was wondering if the stock ecm will handle all my needs. shooting for 900 + and was told by turnkey that I should change it.
I dont mind changing to a different ecm if I knew I really needed it.
Patrick
06-05-2009, 06:35 PM
I have the KB 2.6 on a stock LS1 and comp cam. I made 524hp and 498tq to the wheels using the stock ecm. Frank @ Prodigy is working on '69 that has a Turnkey KB LS motor-- it's making some pretty big numbers.
67 ls1 vert
06-07-2009, 10:25 AM
hey pat, what did you do to your wiring harness so I can order mine to fit the first time. Hate to order it and forget to make a wire longer somewhere. Can you take a picture of your computer mounting spot please? Oh yeah, where did you install your data port?
Thanks.
Patrick
06-21-2009, 04:13 AM
Thanks.
I had Speartech modify the factory corvette harness. I ran the harness through a hole in the trans tunnel. My computer is sitting behind a custom made center console. You can mount the computer just about anywhere...just make sure it is accessible. Some have mounted theirs in the engine compartment-others behind the glove box.
Patrick
