View Full Version : TrueTrac squeak or squeal
parsonsj
06-01-2009, 04:23 PM
I just took my brand new TrueTrac differential out for its maiden voyage. All seems well: no leaks, and the Locker banging is gone.
But: on left-hand U-turns, I hear a squeak/squeal coming from the differential. Is that normal? Should I be concerned?
jp
Vegas69
06-01-2009, 04:39 PM
I've never heard mine squeak or squeal in over 2000 street miles. Put a few more miles on it and see if it goes away.
silver69camaro
06-02-2009, 10:41 AM
No squeek here either. Did you call the manufacturer JP?
parsonsj
06-02-2009, 11:40 AM
I exchanged email with Moser (Rocky Van Note) this morning. They recommend 80W90 mineral-based oil (I was using Mobil 1 75W90 synthetic) to break the new differential in. I'll switch over to that and see if that makes a difference.
jp
Vegas69
06-02-2009, 12:06 PM
Yep..I run dino 80w90.
RSX302
06-02-2009, 09:32 PM
Same here...Currie say not to use anything but plain old 80-90w gear oil. Too slick of oil will not allow the diff to work properly.
I can actually start feeling my rear tires lightly skip in a very tight radius.
1969CamaroRS
06-03-2009, 05:07 AM
Same with Moser plain 80w90 gear lube.
parsonsj
06-18-2009, 12:14 PM
I changed my fluid. It made no difference. At all.
I talked to Moser, and they said the noise wasn't unusual, and that it might go away as the unit breaks in. But even if the noise doesn't mitigate, it wasn't an indication of a problem.
So I'll just drive it like this, and change it back to synthetic fluid when I get a couple thousand miles on it.
jp
