View Full Version : Modified Chassis
SDS MACHINING
05-27-2009, 09:04 PM
Now that the true ride height has been established we have made these changes to chassis,
Sectioned the front and raised it up a total of 2 1/2 inches
https://static1.pt-content.com/images/pt/2009/05/CIMG2442-1.jpg
raised the rearend and the 4 link up a total of 2 inches.
https://static1.pt-content.com/images/pt/2009/05/CIMG2435-1.jpg
Vegas69
05-27-2009, 09:20 PM
You better make some room in that tunnel for the driveshaft and u joints. I've had mine lightly contact under full accel when I had the coil overs a little low.
SDS MACHINING
05-27-2009, 10:17 PM
very true, we just discussed that today and are making provisions for that very issue, we are going to modify the tunnel and square it up some which will help not only for clearance but also give us a better platform for the center console which is going to split the back seat as well.
jackfrost
05-28-2009, 08:31 AM
you might want to post updates to the same thread, so people have some idea what you're talking about.
SDS MACHINING
05-28-2009, 09:02 AM
my apologies, I will keep this in mind.
SDS MACHINING
05-28-2009, 03:38 PM
I received pictures today from the fine people at AutoRad that my core support is near completion, I should hopefully have sometime late next week, as this is the only missing piece to finishing the metal work, there will be a few suttle changes made to the chassis to accomodate this support since we have raised the front section of the chassis up 2.5". were still trying for the early July paint date.
core support
https://static1.pt-content.com/images/pt/2009/05/dsc01018-1.jpg
the top core is the standard unit with two 1" lines, we are going with the other core which offers two 1 1/2" lines. this combined with dual electric fans should keep things pretty cool.
https://static1.pt-content.com/images/pt/2009/05/dsc01020-1.jpg
Motown 454
05-28-2009, 08:47 PM
Very nice.!
SDS MACHINING
06-28-2009, 10:46 PM
A few more changes to the rear were needed to get the ride height in position,
from this
https://static1.pt-content.com/images/pt/2009/06/DSCN0993-1.jpg
to this, custom made box sections were installed to widen out the mini tubs and create more clearance
https://static1.pt-content.com/images/pt/2009/06/DSCN1023-1.jpg
https://static1.pt-content.com/images/pt/2009/06/DSCN1024-1.jpg
https://static1.pt-content.com/images/pt/2009/06/DSCN1038-1.jpg
https://static1.pt-content.com/images/pt/2009/06/DSCN1030-1.jpg
Motown 454
06-29-2009, 03:17 PM
Wow that should be low
Twentyover
06-29-2009, 10:35 PM
Any way to combine this with the other build thread(s) or can you provide a link to the ther threads?
