View Full Version : Power Steering noise
67LS1T56
05-26-2009, 04:15 PM
My power steering box on the LS1 engine is making noise after car warms up. I have a power steering cooler which is stock that came with the engine from a WS6, 4 wheel disk, hydrobooster and late '80 fast ratio steering box. Lines are teflon with stainless braid.
I read somewhere that those lines make noise. Is that true? and why not as soon as doesnt make noise but after wams up? Or do I have another problem?
Rybar
05-26-2009, 04:25 PM
Have you checked to see if the fluid level is low?
67LS1T56
05-26-2009, 04:57 PM
Yes, fluid level is fine.
silver69camaro
05-27-2009, 05:00 AM
Air in the system? What does it sound like? Does it make the noise at idle, or while turning the wheel? How hot is the fluid when it starts to make noise?
67LS1T56
05-27-2009, 05:07 AM
Whining noise when driving. it doesnt do it when started.
67LS1T56
05-27-2009, 08:21 PM
As far as I know if there is air it should make noise as soon as the engine starts.
MuscleRodz
05-27-2009, 10:03 PM
what pump are you running? What size lines?
67LS1T56
05-28-2009, 06:19 PM
1 . I have an inline WS6 power stering cooler on the upper radiator hose which was stock on the engine. Lines are I beleive -5 aerokuip power steering lines with teflon inside and braided steel outside.
MuscleRodz
05-28-2009, 06:21 PM
1 . I have an inline WS6 power stering cooler on the upper radiator hose which was stock on the engine. Lines are I beleive -5 aerokuip power steering lines with teflon inside and braided steel outside.lines need to be -6 on pressure side, we prefer -6 on the return as well
67LS1T56
05-29-2009, 11:04 AM
Lines are -6.
silver69camaro
06-01-2009, 11:32 AM
Are you running a remote resevoir? What fluid?
Does the noise pitch change with RPM?
MonzaRacer
06-07-2009, 05:31 PM
have a flush done and use a full synthetic dot 3 power steering fluid.One shop I worked for ,we started usin g it and had great results with it in noisy ford ps pumps.
jpdeuce
06-08-2009, 07:24 PM
Do you have a remote reservoir? If so is it baffled? It might be aerating.
Roadrage David
06-09-2009, 01:14 AM
I have a DSE powerstearing pump with remote oil resevroir and \hydra boost afther start up the stearing wheel is lockt til i rev it a bit, then when it comes loose it sqeels when i try to turn the stearing wheel. when im of driving its perfect , when i come back to park the car it squeenls at times ..
megaladon6
06-09-2009, 01:01 PM
it almost sounds like the pump is cavitating, creating bubbles. what fluid is in there?
jpdeuce
06-09-2009, 05:15 PM
I know its probably not but it almost sounds like the pulley is too big. Like the pump needs more rpms, or its aerating.
Roadrage David
06-09-2009, 11:00 PM
Jeff i gues your right as i have 15% under drive pullys!!, i could also go for a high rpm at idle i gues..
