View Full Version : Flowmaster to dyomax ultra flows. WOW
67LS1T56
05-24-2009, 09:12 PM
I just changer from Soundbox to Dynomax ultra flows and difrence is day and night. An d even car feels better. what a diffrence , If you guys dont like loud mufflers dynomax does the job.
hifi875
05-25-2009, 06:36 AM
what flows did uhave and what dynomax did u get?
77thor
05-25-2009, 12:42 PM
Yeah. I've heard that about DynoMax. I have been thinking of changing over to their Super Turbo mufflers (even quieter).
67LS1T56
05-25-2009, 07:36 PM
I had the flowmaster 40 series mufflers before, changed to Dynomax ultraflow welded racing mufflers.
Steelrat
06-05-2009, 03:35 PM
that is good info. I posted an inquiry on better flowmaster mufflers. I have flowmaster 40's..hate the drone. May need to change brand
https://www.pro-touring.com/forum/showthread.php?t=56525
what is the highway, constant speed sound like?
70camaro406
07-03-2009, 04:12 AM
Yeah, that IS good to know. I was planning on using the Dynomax Ultraflo's in a 3" with a full exhaust and x-pipe. What size did you use?
a73formula
09-17-2009, 09:08 PM
Yeah theres a guy in our firebird club that did this and it quieted the car way down at cruising but it is still really loud when he gets on it.
My427stang
09-18-2009, 03:37 AM
Dynomax, Borla ProXS, Magnaflow, they all work significantly better than the Flows.
Once you switch, you'll never go back.
Samckitt
09-18-2009, 03:51 AM
Got a video or audio recording of the Dynomax?
EFI69Cam
09-18-2009, 09:26 AM
Careful on the Dynomax. They use a glass fiber matting inside the muffler that gets blown out after awhile. They get louder as they age.
Tony_SS
09-18-2009, 10:17 AM
doesnt magnaflow use the same?
tonykim
09-18-2009, 01:21 PM
yes the dynomax ultraflows and I think the magnaflows use a fiberglass matting. I have magnaflows on a 500 hp SBF fox mustang and at first they were very quiet and after about 3-4k miles got louder and then have been the same for about 20k miles. I've also used dynomax superturbo mufflers on a sbf stang and they were quieter than flowmaster 3-chamber but did drone a little.
MonzaRacer
09-19-2009, 04:57 AM
Well I ahd a set of Corvette dual outlet Dynomax Super turbos on my 70 Monte got them for 60 bucks a pair nearly new(ran about 5 hours total.
Put about 350k miles between 2 vehicles till they finally got stress cracks in the stainless. Had stock 350 4bbl made car sound big, then my high compression 402 with 1 7/8 headers, Flowmaster Force 2 Scavenger collectors and 3 in pipes then smooth NAPA reducers to 2 1/2 in into the muffs, then on both of the Roller motors in my 78 C10 till they blew apart. Then got pair of used Flowmasters from buddy for truck. on my roller motor they sound pretty good.
but I probably will buy Flowmasters from work for Monza and maybe even the Caprice.
MonzaRacer
09-19-2009, 04:58 AM
On a side note I really do want to try Edelbrocks SDT mufflers just for the heck of it.
MonzaRacer
09-19-2009, 04:59 AM
also used Flow techs on my old Monza VERY NICE for a cheaper welded muffler.
pitts64
10-06-2009, 05:31 AM
I like the Dynomax 17749 Super Turbo. I like to be able to hear what's going on with my car...
mjdwyer23
10-10-2009, 10:21 AM
I'm looking to quiet down my 427, I'll look into those dynomax's. Thanks!
tonykim
10-12-2009, 05:33 AM
anyone have video clips of the new Edelbrock SDT mufflers?
rentedmule
10-13-2009, 04:15 PM
The superturbos use fiberglass matting inside but I think the ultraflows are just chambered. I've had superturbos on a bunch of vehicles and they don't hold up well to winter driving/salt - I never got more than 1.5 years out of one. They rot out from the inside at the folded joints. They may do fine in a dry climate though.
I've been running a 2.5" in/out ultraflow welded on my truck for 2.5 years and it still looks like new. It is definately quite too, especially for something that flows so well.
oestek
10-13-2009, 04:35 PM
MagnaFlow uses a metallic packing (I think it's called Rockwell) that outlasts fiberglass... it's like stainless packing. I'd run them over glass packs every time.
pitts64
10-14-2009, 05:51 AM
Try the Dynomax #17749 mufflers with turn down tips at the tail pipes.... Quiet while cruising around town with it sounding like a 60s gasser with the hammer down... There nice and light too..
In the video, I mistakingly bumped my MSD timing control and was running 0 degrees inital... They sound even better at 14 inital....
http://www.youtube.com/watch?v=dz8_yhT8tNE
cheapthrillz
10-14-2009, 06:32 AM
Kevin, Rockwell or Rockwool?
Rockwool is used as a packing material in building construction for pipe and conduit penetration on fire rated walls.... It is the backing material for firecaulk. I wonder if that is what you're talking about? I don't think it is metallic though...
Ron L
10-17-2009, 08:31 PM
At 30 I realized I wasn't 19 anymore so I went from FM 40s to Magnaflows on my Mustang. I didn't like the sound with the tailpipes, sounded like a UPS truck but when I went to dumps it was awesome. Of course the fumes weren't great so I converted it to side exhaust and it still sounds really nice and deep. I had cheapie 2.25" tailpipes then so it would've probably been better with some mandrel-bent 2.5 inchers. It's amazing how much noise is removed considering the simple construction.
https://static1.pt-content.com/images/pt/2009/10/Muffler_Cutawayvi-1.jpg
https://static1.pt-content.com/images/pt/2009/10/magnaflow_insidevi-1.jpg
Side exhaust parts. Dynomax "sidepipe connector kit".
https://static1.pt-content.com/images/pt/2009/10/DSCF0941vi-1.jpg
Zero drone, no gurgle/popping on decel (I thought the engine died the first time), and sounds like a Cup car at WOT.
