View Full Version : bottom of the hood color???
lt1chevelle
05-23-2009, 04:05 PM
here is a pic should i go flat black or the color the cars going to be?
https://static1.pt-content.com/images/pt/2009/05/000_0803-1.jpg
Throttle
05-23-2009, 04:10 PM
I usually do satin black, but must of my engine bays are also satin black.. I think I would do it satin anyways, there is such a thing as to much of one color.. :D
class67
05-23-2009, 04:23 PM
I vote for same color as the car!
Topless69
05-23-2009, 05:04 PM
Same color all the way.
Yelcamino
05-23-2009, 05:44 PM
If your engine compartment was flat black, then I'd say do the bottom of the hood the same, but since it's not, go with body color.
minendrews68
05-24-2009, 11:56 AM
X2 just my .02
CROMAN69Z28
05-24-2009, 05:55 PM
paint the main part of the hood body color and then flat or 40% or so black the cut out areas. it will really make the blue POP.
CROMAN69Z28
05-24-2009, 05:58 PM
paint the main part of the hood body color and then use a flat-40% black for the cut out areas. it will make the blue POP.
manicmechanic
05-25-2009, 03:58 AM
X2! then if it doesn't look good to ya, you can fill in the area with ss panels.
derekf
05-25-2009, 09:25 AM
I believe "correct" for 65 is flat/satin black.
Mine will be "correct", although I do think I favor body color.
Throttle
05-25-2009, 09:42 AM
I Know I said to paint the bottom side of the hood black earlier, I change my mind..
My car will be all satin black sheetmetal under the hood and the bottom side of the hood will be Body Color..
nightrunner
05-25-2009, 09:56 AM
i vote for body color since the bay is painted body color. however i think, depending on the whole situation, i might just go satin black or even just let it over spray on it and put some dynamat hoodliner on it to protect the hood from heat
2 lane blacktop
06-08-2009, 03:58 AM
I agree, body color with black inserts. It would give your engine the "jewlery box" effect.
Happyfunballs
06-08-2009, 04:37 AM
If you're gonna paint it body color, better shoot the hinges and core support as well.
