View Full Version : Power Steering Reservoir
mdprovee
08-23-2004, 09:37 AM
I have coverted to power steering on my 67 camaro. I used a an AGR power steering pump and box. AGR said they did sell reservoirs so I need a rerservoir to put the pump into. I do not want one that gets mounted remotely, I want one that mounts like the stock one. What type and year do you guys suggest using?
Mike
08-23-2004, 06:36 PM
Hi Mike, try Matt @ RFR he's up north and he's looking to make a unit...isn't it weird that the pump guys don't sell resivoirs???? later
08-25-2004, 08:02 PM
Try a wrecking yard, look for one with an oval neck soldered onto the main reservoir housing. Make sure it isn't damaged in the O ring area or on the bottom where the bracket connects. You need two studs from the rear of the pump, lower is the pump bracket stud, the top is the adjuster bolt.
I have more info on my web page with photos of the brackets.
David
