View Full Version : squirter too big?
TMat
05-10-2009, 03:29 PM
I have a brand new 850 mighty demon with annular boosters. With the engine idling and up to temperature. If I lightly blip the throttle it will bog and then rev up, bog and rev up. Sounds like it's getting too big of a shot from the squirter?
Any ideas?
Timing is 18 initial
BBC with a 234/248 620 lift hyd roller.
perform oval port manifold.
Shaker455
05-11-2009, 08:37 AM
is that carb jetted 80/88?
Is thete any play in the pump arm between the cam & the pump housing lever?
TMat
05-12-2009, 08:14 AM
I haven't checked the jet sizes, but it's supposed to be jetted 80/88. Do you think it could be jetted wrong from the factory?
I will have to check the cam to housing slack also.
Vegas69
05-12-2009, 08:41 AM
I'd make sure your jetting is correct first. Then you can make a squirter change. I had to increase mine by .003 front and back. What size engine?
TMat
05-13-2009, 10:49 AM
Its a 496
Vegas69
05-13-2009, 11:26 AM
I'm running a 489 and .037 primary .040 secondary squirters. My float levels are dead on and so is my jetting. I'm at 2500 ft so my jetting will be slightly different than yours.
