yevgenievich
05-10-2009, 11:14 AM
This is my 67 Camaro that i bought to build up. I've been trying to stay under 10k simply because i can't really afford to spend more money on it. Bought it before the economy went down so it cost me a lot of savings.
First are pics of what i started out with. When i bought it i was told that it was all original car with 327 and powerglide, when i started working on it found out that somebody swapped a motor out for a 69-70 350 with a set of double hump heads 10:1 compression and forged trw pistons. Trans originally was a manual and been swapped for a th350. One of the pistons turned out to be cracked so i pulled the motor for a rebuild. Then came the rust, the trunk floor is basically gone, the driver side back floor pan is gone as well, both rear qarters need to be replaced, which i will some day. Right now my goal was to kill all the rust that is there, get the car cleaned up and running and then worry about patch panels and such.
