View Full Version : Info on a disc brake upgrade for a Gbody
Stg1Regal
05-07-2009, 03:42 PM
I remember reading here or on one of the other forums, about upgrading the front brakes on a G-body .
I was about keeping your current spindles, and machining down an old brake rotor to adapt/fit a Covette rotor over it, or something like that.
It was also required to cut something off the spindles to fit a bracket for the correct caliper to mount
Sounds familar?
TIA
Stg1Regal
05-09-2009, 05:43 PM
I found those links..whewww!!!
For the front brakes......
http://www.turbobuick.com/forums/brakes-suspensions-tires-wheels/172762-ls1-brake-mod.html?referrerid=1864 (http://www.turbobuick.com/forums/brakes-suspensions-tires-wheels/172762-ls1-brake-mod.html?referrerid=1864)
And for the rear brakes...
http://www.turbobuick.com/forums/brakes-suspensions-tires-wheels/206369-ls1-f-body-rear-brake-swap.html?referrerid=1864 (http://www.turbobuick.com/forums/brakes-suspensions-tires-wheels/206369-ls1-f-body-rear-brake-swap.html?referrerid=1864)
chevy42083
05-14-2009, 11:16 AM
I am doing that swap on my S10, except going with the camaro stuff so I can still run my 16s. Same deal though, just a different adapter bracket.
I don't have any pics yet though, sorry.
I bought the brackets and hubs from Bad94 (pretty sure he goes by that on this forum also), and sourced the calipers, abutments, and rotors elsewhere. I also had a local place machine the spindles for me, but bad94 offered modded spindles too.
In case you didn't know, Gbodies and S10s use the same spindles.
Eric Howell
05-14-2009, 11:18 AM
bad94 goes by that name here.
Ed Miller is another name that comes up, here is his site.
http://www.flynbye.com/index.html
