View Full Version : back of fuse panel/block question
Topless69
05-06-2009, 01:26 PM
hi guys , on the firewall where the wiring harness plugs into the fuse panel there are 2 plugs and inbetween them there is a bolt. I want to unplug the wires so I can clean and sand down around the area. Does this bolt come into play? Or do the wires just pop off on there own?......any info will help, I don't want to mangle anything. Thanks.
Jeoff J.
GetMore
05-06-2009, 02:55 PM
The bolt holds the plugs to the fusebox. To remove the connector you must remove the bolt. Then, you can disconnect the two halves of the wiring harness connector.
One half is for the engine wiring, and the other is for lighting, wipers, etc.
Topless69
05-06-2009, 04:06 PM
Thats
Topless69
05-06-2009, 04:10 PM
Oops..!! Thats what I needed to know. Thanks Jason.
