View Full Version : Wheel hop, how/why?
Samckitt
05-04-2009, 03:23 PM
What causes it & how to stop it. I noticed it today on the Monte but have never noticed it before.
Did I make changes to rear suspensin? Yes.
What? Tubular control arms, adjustable uppers, poly bushings, Bilstein shocks, different springs.
How to prevent it?
Derek69SS
05-05-2009, 06:50 AM
Did your springs raise the ride height at all? You can fix it by lowering. :)
Samckitt
05-05-2009, 09:32 AM
I didn't measure it but should be lower if not the same.
slowcamaro
05-05-2009, 09:49 AM
Torque everything with the suspension loaded? Poly bushings where? How are the LCA's angled?
GetMore
05-05-2009, 03:27 PM
I'm gonna guess it's an angle issue. Perhaps the lengths are off between the uppers.
Tony_SS
05-05-2009, 06:06 PM
Pinion angle possibly? I never wanted to do adj rear uppers myself.. too much room to set an incorrect angle.
Samckitt
05-06-2009, 04:13 AM
When I had the front end aligned, the guy said he set he adjusted the arms & set the pinion angle. So I dunno.
GetMore
05-06-2009, 03:04 PM
I wouldn't be sure on the pinion angle either. What did he set it to?
I would imagine that the proper angle with your new parts would be a bit less than with the old ones, since there is less flex possible, so it shouldn't go negative as easily.
Samckitt
05-06-2009, 03:54 PM
Not sure what he set it to. What should it be at?
GetMore
05-06-2009, 04:08 PM
To be honest, I just don't know. I've forgotten what I've read about pinion angle.
If I remember correctly you want it at zero when it is at maximum torque. The reason you usually set it a few degrees negative is so when it twists it will just get to zero.
modular93fox
05-10-2009, 04:42 PM
about 3-4* neg is a good start. you do not want to set it at 0 becuase that will kill u-joints. im betting if you looked at your pinion, its pointed upwards, thats whats causing the wheel hop. check it out..
