View Full Version : sway bar bushing bolts for 69 camaro
mushman
05-04-2009, 12:00 PM
Hey Guy's anyone know where I can get new sway bar bushing bolts for a 69 camaro?
05-04-2009, 04:58 PM
Energy Suspension has link kits, stock type kits are made by Moog, most hardware stores should have an equivalent bolt, get grade 8 fine thread bolts.
mushman
05-04-2009, 05:19 PM
Thanks for the help David, you wouldnt happen to know what size bolts to get would you? My car did not have a sway bar on it when I got it so I am starting from scratch. Thanks again.
05-04-2009, 07:15 PM
For better handling, I would get a matching set of aftermarket stiffer front and rear bars and the end links and frame mounts should come with them.
Here is a good set of end links from Moog:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MOG-K6217&N=700+4294844371+4294925082+4294908216+4294908198+ 115&autoview=sku
mushman
05-05-2009, 11:50 AM
I just got my new front bar 1 1/8 from DSE it does come with end links, hardware and frame mounts but no bolts to attach them to the frame I did call them but they do not sell the frame bolts. I am going to run to the hardware store and see what I can come up with.
redfire69
05-06-2009, 02:38 AM
http://www.rickscamaros.com/product.asp?pf%5Fid=SS%2D414&dept%5Fid=3516
JEFFTATE
05-06-2009, 05:03 AM
You gotta be careful with those bolts that screw into the sub-frame.
They 're easy to strip.
The ones on my car had been hammered with an impact gun at some point before I got the car .
The frame was stripped.
I had to go to a larger size bolt.
