View Full Version : A/F gauge
kenhaw
04-30-2009, 02:11 PM
Hi guys
Just wondering how much your a/f gauges fluctuates in your carburated engine. Mine never seems to stay at the same place even at a steady speed, is that also what you experience?
I have an wide band autometer gauge with one sensor.
recklessnova
05-29-2009, 09:46 AM
mine stays prety steady within .2 or so if throttle is the same and not climbing hills or anything
josh
Im running the fast dual wideband
68Formula
05-29-2009, 10:44 AM
I've used professional grade lambda sensors and experienced some minor fluctuation. If the sampling rate is fast and accurate, you should expect to see variation as a result of slightly different combustion in each cylinder.
