View Full Version : wilwood dynalite calipers
mjp01243
04-25-2009, 11:45 AM
I just installed a rear brake kit from wilwood with dynalite calipers and noticed that they come with four bleed screws and no crossover tube. I know that i need to take out the lower two screws and install a crossover tube but does anyone know if wilwood makes a prebent tube? Has anyone make their own crossover tube and if so what fittings did you use?
Tito
04-25-2009, 12:05 PM
The newer billet dynalites have the internal crossover tube, so you don't need to add an external one... For the "lower" bleeders, you can either leave them in (they won't hurt anything) or replace them with 1/8" NPT plugs I think...
Billet Dynalite Caliper Highlights:
The Billet Dynalite caliper is powerful, compact, and super lightweight. Advanced computer engineering keeps this caliper extremely rigid resulting in incredible brake torque at a bare minimum in weight - only 2.5 pounds. Internal fluid crossover eliminates external tubes and the four position, two-piece bleed screws allow for convenient mounting and easy bleeding. The Billet Dynalite uses standard quick change Dynalite pads, deep cup stainless steel pistons and high temperature seals, and has a black anodized finish. The time proven Dynalite caliper design is stronger and lighter than ever - ideal for Late Models, Modifieds, Sprints, Road Racers and Dragsters. (http://www.wilwood.com/Products/001-Calipers/020-BDL/index.asp)
Skip Fix
04-25-2009, 03:28 PM
What he said:) New ones don't have the tubes.
ProdigyCustoms
04-26-2009, 03:14 AM
Echo!
