dharrod
04-21-2009, 02:53 PM
I forgot to update everyone with the finished product last summer. Engine pictures to follow
https://static1.pt-content.com/images/pt/2009/04/blk69ss250-1.jpg
https://static1.pt-content.com/images/pt/2009/04/blk69ss259-1.jpg
https://static1.pt-content.com/images/pt/2009/04/blk69ss413-1.jpg
https://static1.pt-content.com/images/pt/2009/04/blk69ss299-1.jpg
https://static1.pt-content.com/images/pt/2009/04/blk69ss506-1.jpg
Here are some of the specs. I had planned to finish of the transmission/rear end but kept it stock due to the economy and job outlook. Things keep going the way they are I'll have to sell it to pay the morgage.
Engine / Drivetrain
Original 396 block and steel crank
Dart Pro 1 Heads
Aluminum Roller Rocker Arms
PBM Eliminator Hydraulic Cam
Edelbrock Air-gap Intake
Mallory Ignition Box
MSD Pro-Billet Distributor/Coil
PowerMaster Starter
750 Barry Grant Mighty Demon
Holley Peformance Fuel Pump
Aeromotive regulator
Stainless Steel Gas Tank direct from Rick’s Hotrod Shop TX
Stainless steel gas lines by Right Stuff Detailing
Aluminum radiator by Alumitech Reproductions
Fex-a-lite dual 27” electric fan
Munci 4-Speed (M-21)
Hayes Performance Clutch
Stainless Steel Hooker Super Comp Headers
Magna Flow 2-1/2” Stainless steel exhaust
Stainless Steel exhaust tips by Pypes Performance
Fan-shroud by Undercover Solutions
Suspension
Silver powder coated frame by Top Coat Inc. Raleigh NC
Original 12 Bolt (3.31 gears) with Eaton Posi
KMA 1-1/8” Front sway bar
KMA Rear sway bar
Upper/Lower Rear Tubular Control Arms by UMI Performance
Tubular Upper/Lower A-arms by BMR Fabrication Inc
Moog Steering Components with Solid Aluminum couplers
Hotchkis F/R springs 1” lower
Edelbrock Performer IAS Shock Rear
QA-1 Font Coil Overs
Energy suspension bushings/body mounts
Front Wilwood 13" 6 piston Superlite Drilled and slotted
Rear Wildwood Brakes - 12.2" 4 piston Dynalite Drilled and slotted
Wilwood Master Cylinder with Hydratech Braking System
Stainless steel break lines – Right Suff Detailing
Energy Suspension bushings and body mount
Stainless Steel body mounts & bolt kits
17” Budnik Rims
Nitto 255/50 front 275/50 rear
Body/Interior
Original Sheet metal
DuPont paint system: Primer, Sealer, Jet Black Base, Clear
Black Interior; bucket seats 4-Speed
Tilt Wheel
Gauges by Autometer
Original AM/FM Radio – modern internals/IPD ready
Digitails LED – tail lights/front blinkers
Modern dual beam head-lights
Engine / Drivetrain
Dart Pro 1 Heads
PowerMaster Starter
Suspension
KMA Rear sway bar
17” Budnik Rims
Body/Interior
Tilt Wheel
Gauges by Autometer
