Steve Chryssos
04-17-2009, 08:35 AM
Following on the success of our adjustable shifter sticks, is this new Adjust-A-Stick™ kit that provides the same benefits, but works with any stick as long as it has the traditional 7/8" bolt spacing.
Sometimes the simplest ideas are the best. You've converted your car from a side mount shifter (i.e. Muncie 4 speed) to an internal rail top mount shifter (Tremec, Richmond, etc.) but you just can't seem to get the stick ergonomics quite right. What do you do? Most people just deal with it. Others buy three or four sticks in search of perfect ergonomics. Custom console? You guys have an even tougher time finding the right stick.
Here's an easy, affordable solution that puts the shifter ball right where you want it without breaking the bank:
The new Twist Machine® Adjust-A-Stick™ Kit permits fore/aft adjustment of your shifter stick. Additionally, it allows for center (shown) as well as 3/8" left or right offset. Price will be $42.95 including cad plated adapter and hardware or from $119.00 when purchased with one of our ProStyle™ shifter sticks. Adjust-A-Stick™ pre-orders are being accepted by phone. You will not be charged until the kit ships. ETA on or about May 15th. Currently undergoing field testing (thanks Mike Bassi)
The steel adapter plate bolts to your shifter stub:
And your stick bolts to the adapter:
Center mount is shown below, or you can offset left or right:
Adjust 'til your happy and tighten bolts. It's that easy.
Thanks for looking
/Steevo
Patent Pending :look:
Thanks for looking
/Steevo
