View Full Version : Firewall seam...how to fill?? with what??
Topless69
04-13-2009, 04:18 AM
Guys I have read through the archives and didn't find an answer.I'm about to get started on smoothing the firewall. Now i'm going to do a 3/4 panel not a total coverage panel witch will leave from the wiper motor hole over open. This will leave the seam showing and will need to be filled with something.
QUESTION 1.) does this seam flex?
2.) If it flexes than bondo type filler will not work do to cracking..correct?
i was thinking about a lead based filler what did you guys do or what would you recomend. Thanks guys.
GetMore
04-13-2009, 03:48 PM
Fill it with seam sealer?
Topless69
04-13-2009, 04:51 PM
Jason is seam sealer like a calk or does it harden like bondo?
GetMore
04-13-2009, 06:17 PM
It is non-hardening. Tougher than caulk, but still flexible.
qwik1320
04-13-2009, 06:19 PM
I welded mine and ground down close, then used a little bondo to smooth out the imperfections. A few spots I didn't weld I used seam sealer, put a piece of tape on both sides of the seam to give a nice clean edge and then smoothed it in like caulk (wet finger with alcohol). After it dried I lightly sanded the tape edge to feather it in and painted. Looks good.
class67
04-13-2009, 06:29 PM
I welded mine up!
Topless69
04-14-2009, 01:15 PM
So there is a bit off flex going on. Have you guys who welded and then used bondo have any cracking issues down the road. Thanks for the info guys.
tillman
04-16-2009, 09:28 AM
I used a product called All METAL. Got it from the local paint store.came in qt can.Worked Great.I read about it on the quick silver project.
https://static1.pt-content.com/images/pt/2009/04/29-1.jpg
Topless69
04-16-2009, 01:36 PM
was that a auto paint store Tillman?
Topless69
04-16-2009, 05:26 PM
Ignor the last question....I MUST have hit my head or somethink.:Alchy:
67speedfreak
04-16-2009, 05:41 PM
I would weld the seam solid before adding filler.
Brian
opnwide
05-08-2009, 02:34 PM
I tacked the seams together tight and used AllMetal followed by filler. The allmetal is tough to sand. If I was to do it again, I would've done more body work (too many high and low spots).
